Scholar Gypsy Posted January 5, 2018 Report Share Posted January 5, 2018 My engine (Mitsubishi K4D) has recently started to lose coolant, which is most unusual. It's not ending up the floor, as that is bone dry. The engine was also rather hard to start at the weekend - again most unusual. And I noticed steam (I think - I didn't sniff too closely) coming out of the dipstick tube. I am assuming this is going to be a head gasket issue - any other possibilities? I have read a few websites on this, which mainly list the various symptoms you can get, depending on precisely which part of the gasket has failed, but also stress that diagnosis can be quite difficult! Many thanks in advance. BOAT, I suspect? Link to comment Share on other sites More sharing options...
zenataomm Posted January 5, 2018 Report Share Posted January 5, 2018 Google suggests .... Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted January 5, 2018 Author Report Share Posted January 5, 2018 2 minutes ago, zenataomm said: Google suggests .... Thanks - all helpful stuff. I'm not going to do this job myself - it's beyond my skills/experience level, I think. Link to comment Share on other sites More sharing options...
zenataomm Posted January 5, 2018 Report Share Posted January 5, 2018 If you use the sniff test, and it comes up with exhaust fumes then it's the head gasket. If it doesn't but you are gathering water in the sump then it's going to be some'at cracked internally. I suggested a sniff kit because of your question. 1 Link to comment Share on other sites More sharing options...
Bod Posted January 5, 2018 Report Share Posted January 5, 2018 4 hours ago, zenataomm said: If you use the sniff test, and it comes up with exhaust fumes then it's the head gasket. If it doesn't but you are gathering water in the sump then it's going to be some'at cracked internally. I suggested a sniff kit because of your question. What colour is the oil in the sump? Black=no fault grey=fault Bod Link to comment Share on other sites More sharing options...
zenataomm Posted January 5, 2018 Report Share Posted January 5, 2018 If he's losing coolant and has seen steam coming out of the dipstick, I guess it's safe to say he has a breach between the two somewhere. His question was is it the head gasket or other possibilities. 1 Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted January 21, 2018 Author Report Share Posted January 21, 2018 Panic over - the yard have had a look now. The pressure cap was somewhat knackered, and (despite several checks in the autumn) there were some small leaks on one of my jubilee clips. I think the steam/vapour was just a bit of condensation inside the engine, I gave it a good run on Friday and it stopped pretty soon. Also changed the fuel filters, the fuel was very clean and dry. I think I do now want a pressure tester kit. Can anyone recommend one please that fits on a standard Bowman heat exchanger ? Link to comment Share on other sites More sharing options...
WotEver Posted January 21, 2018 Report Share Posted January 21, 2018 11 minutes ago, Scholar Gypsy said: the fuel was very clean and dry. Dry? How does that work then? Link to comment Share on other sites More sharing options...
alan_fincher Posted January 21, 2018 Report Share Posted January 21, 2018 13 minutes ago, Scholar Gypsy said: the fuel was very clean and dry. 1 minute ago, WotEver said: Dry? How does that work then? Steam driven, running on solid fuel? Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted January 21, 2018 Author Report Share Posted January 21, 2018 16 minutes ago, WotEver said: Dry? How does that work then? Ah sorry, I meant dry as in no detectable amount of water. Link to comment Share on other sites More sharing options...
BWM Posted January 23, 2018 Report Share Posted January 23, 2018 If you have an oil cooler they can cause symptoms similar to yours. I'm not familiar with the engine that you have but some do suffer with condensation in the crankcase, i've had a couple of Volvo 850s and had my heart sink on pulling out the dipstick, finding it coated in custard and assuming the worst-only to find there was nothing wrong. Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted January 23, 2018 Author Report Share Posted January 23, 2018 1 hour ago, BWM said: If you have an oil cooler they can cause symptoms similar to yours. I'm not familiar with the engine that you have but some do suffer with condensation in the crankcase, i've had a couple of Volvo 850s and had my heart sink on pulling out the dipstick, finding it coated in custard and assuming the worst-only to find there was nothing wrong. Thanks, that is reassuring. I don't have an oil cooler. There's no sign of anything odd or custard like on the dipstick or under the oil filler/rocker cover. I guess the puff of vapour from the dipstick tube has been going on for years, I have just never noticed it. I will look closely at the oil when I next change it. Indeed I think on my next trip I will pump a bit out to inspect and return... Link to comment Share on other sites More sharing options...
