bigcol
Diesel heating 5kw new for £163
7 minutes ago, alvicchas1 said:
Amazing price but I think I would be concerned abouty safety approval accreditation and spare parts.
Interesting comment, given the fifth photo in the listing shows the heater apparently engulfed in flames!!!!
Share this post
I can’t beleive how this hasn’t been pounded on??
amazing giveaway price for a complete kit
the bits are worth more than that, let alone the heater.
if I think I needed one, if I wanted mine serviced I would buy this as a spare unit.
in fact I may buy one just for the crack
col
Hi Mike
yes I saw this, but I don’t know what else they could put in the background
Snow?
Naked woman?
yep naked woman would have been better.  Brrrrrrrr but hot in here!
Share this post
col
One of the ways they make it so cheap is by having no form of control. It just runs flat out all the time.
Webastos and other more expensive air heaters are controlled a room thermostat.
Share this post
You need to google Planar heaters
you will find that planar sell these through known company’s   Ie pf Jones plus
ifmyou go to the manufacturer is seems they come from the Russian federation.
and these will not be covered by their warrentee if inside Europe.
but if buy on eBay PayPal you would have some security.
col
if you go to the manufacturer is seems they come from the Russian federation.
col
Edited by bigcol
Share this post
I've been looking at these too, the stats are actually quite impressive, but as others have said the lack of safety approval is slightly concerning, as is this article:
https://www.google.co.uk/amp/s/www.sailmagazine.com/.amp/cruising/voe-a-faulty-heater-nearly-leads-to-tragedy
Although the cause of their issues was largely poor installation rather than an inherent fault.
Share this post
37 minutes ago, bigcol said:
Here’s their site
https://www.planarheaters.co.uk/
Although the eBay links state "unbranded", so probably a knock off, especially as coming from Hong Kong. Planar heaters are made in Russia (as stated above!)
Share this post
I see the listing also states import duty 'may' be payable.
I just had to pay nine quid import duty on an ebay item costing £70, dispatched from China. So perhaps £20 will need to be paid to get one of these heaters through customs in addition to the purchase price.
Share this post
If you only paid the duty you got away lightly - items with a declared value of over £15 are subject to VAT in addition to any Duty payable.
It was a bit of a shock when I purchased an expensive camera from the USA - it turned out to not be such a bargain as I had hoped.
Edit to add link :
https://www.royalmail.com/sites/default/files/International-customs-charges-leaflet-Jan-2017.pdf
Edited by Alan de Enfield
Share this post
How are these air heaters installed? I assume the combustion unit goes into the engine room somewhere and then the air is somehow ducted into the cabin? It's that bit that I don't understand. For a cruiser style NB would you just cut a hole in the bulkhead and have a fitting coming through? I can see these heaters being suitable for smaller GRP and steel cruisers but would the heat get down the length of a NB by convection - or are you meant to install a series of ducts? In that case the installation sounds a bit more difficult.
I have a set of redundant radiators on my boat which I used to heat with an eberspacher. I was thinking of installing a Webasto (water heater) as a replacement which I suppose would be easier than installing an air heater?
Edited by blackrose
Share this post
Plus, according to Rachel, it makes a huge difference to efficiency if the ducting pipes are well lagged, which I guess makes it even harder.
Share this post
As far as I make out the heater dosent come with a controller, but is as the same as a ebespacher
so works exactly the same.
all you need is more ducting, and a hull fitting for exaulst and your away.
but again this is a 5kw It is important to mention this price is for a 5Kw heater
Not 1.9 kw  2 kw or the 4 kw sized Webasto or eberspacher
again for 177 pounds you get in grey with a controller.
i think it’s a bargain I think
well worth the try
Share this post
Yes - you have a duct(s) running the length of the boat(under the floor ?), you then have 'skirting board' vents that can be opened/closed as required branching off the duct.
We have 6 outlets running of our blown-air heating system.
Share this post
Be had this heating for years, the ducting dosent need lagging as the whole point is that it provides heat simpler to a fire flue.
i have  a eberspacher, and somthing simpler in size to this planar unit is a  airtronic 4kw is lots of money
i beleive this is a real bargain, we haven’t heard of these because they are sold with in the east.
col
Edited by bigcol
Share this post
Well  I’ve put a offer in
You've submitted an offer: £167.00 for 12V 5000W LCD Monito... (202160706811)
this is one the same but grey with a controller
hopefully offer gets accepted if not I just buy the one at the start of posting.
what ever I do I will get one, and when I do, will let you know if and how it works.
col
Share this post
You would have a few outlets on any boat - My 33ft cruiser  has three outlets (Eberspacher 4kW heater) and all within 10 feet or so from the heater.
On bigger cruisers there may be two heaters.
The heater on my cruiser is located under the saloon floor so the heat loss from the metal ducting is not wasted since the heat rises into the living spaces. The floor becomes nicely warm. My air supply is via the cockpit area so bringing in external air. The input air may be from the boat interior but this risks condensation - such as when you recirculate air with a car heater.
The very cheap heater from China ,seems to be an incomplete kit - not a marine kit and virtually no ducting. It is a copy of a Russian made Planar  heater which is in itself a copy of Eberspacher/Webasto type heater. The genuine Planar heaters are available in the UK .
https://www.planarheaters.co.uk/4kw-diesel-air-heater/
Edited by MartynG
Share this post
Remembering I have a warrentee of some sorts from eBay and PayPal, which somhow is a better warrentee you get any where
Share this post
I had a Webasto air heater in a campervan. There were two controllers - one a thermostat for temperature and one a programmable time clock.
Every time the heater flashes up the glow plug heats up to start the combustion process and this can draw perhaps 20 amps from the battery.
It is important that the thermostat is sited in a place without drafts so that the heater does not keep cycling on and off and running the battery down too much - it was sometimes a problem in the campervan but should not be too much of a problem with greater battery capacity on a boat.
If a 5kw heater is used to heat too small a space there could also be a problem with the heater cycling on and off too much.
Share this post
Looks like the Planar heater has a low heat setting, but running it too long on low may cause it to soot up:
(The comments are worth a read too)
However the one in the OP doesn't look like the planar one, but there's at least a couple of videos on it:
Again the comments are worth a read.
Maybe the read and black one is a fake of the planar which is a fake of the eberspacher. :)
Edited by smileypete
Share this post
Well Martyn reckoned so when he wrote...
Share this post
