Canal World is currently fundraising. Please click here to find out more.
Bazza954
Webasto Thermotop C Fuel pump
Hi all,
my webasto failed to fire up this morning.
Had a look, plenty of fuel in tank, power supply ok. Turned on again and went into engine bay to listen to boiler firing up, or not, it went through its start up sequence but I noticed the absence of the pump "ticking", it carried on through the start up sequence, but no action from the pump, unit shut down.
I ran it again and checked the voltage at the pump connector, it was 9v. I am presuming (although I know I shouldn't and I'm probably wrong !! ) that the voltage to the pump on start up is lower as the pump pulses slower before increasing to full speed, at which point I think the pump must be getting the full 12v.  I  couldn't check this as boiler fails to fire.
I removed the pump to test with a direct 12v connection, nothing, not even a click.
Is it sounding like a new pump is needed ? or have I missed something ?
Thanks for any responses.
Bazza
Share this post
Have you tried removing fuses ? Obviously putting them back in works for me
Share this post
Yes, failed to mention in OP, did try the fuse removal to reset didn't make a difference.
I think the pump is buggered, looking for replacement, ooooooooo pricey
Bazza
Share this post
Unless I've misunderstood the situation, I'm not surprised it doesn't fire. Surely you need 12V or more?
Share this post
I believe I’ve read here that 9V is correct for the pump.
Share this post
The pumps work on a pulsed supply-each pulse is a little squirt-I thought they were 12v though. Certainly doesnt sound very hopeful though-I got the last one I changed from Germany/Ebay. It was a lot cheaper..
Share this post
I believe you’re right ;)
This post is informative...
Share this post
Thanks for all the replies, tried tapping with power applied to pump no joy, looks like a new pump then.
Bazza
Share this post
Did you try the sharp taps and the paraffin bath?
Share this post
Have you put the multimeter across the contacts to measure resistance? They are a solenoid pump, and if the coil is open circuit then it will never work.
Share this post
Hi, yes soaked, rattled, shaken, tapped, all to no avail I'm afraid.
Ex Brummie , yep a big fat 0 using the UT 203
The pump has worked fine right up to this point, it isn't as if it had been stood for a long time, the heating gets used very regularly.
Anyway, got a replacement pump, installed, third attempt at firing, off it went, ran for 3 hours all ok, just out of pocket by a fair old lump, boats !!!!!!!
Cheers
Bazza
Share this post
9 hours ago, Bazza954 said:
boats !!!!!!!
Hole in the water into which you throw money.
Share this post
Marina, hole in the water into which others throw money for you :D
Share this post
Don't run this type of pump dry as it will quickly destroy them by impact damage to the internal piston. Fill the pump and pipework before applying power.
Share this post
