Canal World is currently fundraising. Please click here to find out more.
jmanton
Beta narine alarms
I have a Beta 43 and the alarms and warning lights are continually sounding and lit when the ingnition is off and the engine not running, any ideas hiw to cure the problem.
Thank you.
Share this post
Does it have an 'ignition' key?  Have you left it switched 'on'?  Might you have been able to remove key when it was still in the 'on' position (damaged switch)?
Share this post
Thank you.
Has it always happened?
Has it just started?
Have you been doing any work on the boat ? (not just on the engine)
Is it possible you have Kicked / knocked / trodden on a sensor when doing your 'morning engine checks' ?
Is it ALL warning lights (Overheating, oil pressure, alternator, low-fuel and anything else you may have) ?
Share this post
Thank you.
Can you post a photo of the instrument panel?
Share this post
This has only just started
Yes on a leaking water pump. Seals changed.
That is always possible
It is all engine alarms and lights only.
I am currently away from the boat and it does have a ignition switch.
Share this post
Did it start at the same time as you worked on the pump ? (maybe not  instantly, but within a short period ?)
Where is the pump located ?
Did you disconnect the electrics to the pump whilst working on it ?
The alarms are 'picking up' power from somewhere - have you removed the instrument panel (or looked behind it) for any poorly made connections or loose wires ?
Share this post
It has an ignition key and it is off and removed
Share this post
Can you get to behind the ignition switch?  If the whole switch had got loose and twisted, the wires behind may be shorting.
Did you turn off the battery isolator when you left the boat?  Or is it still driving your neighbours insane?  :)
I don't mean to teach granny to suck eggs.
Edited by mross
Share this post
The alarms started after I worked on the pump.
The pump was not electrically disconnected
The instrument panel was not removed before the alarms sounded, but I had a quick check behind after the fault to check it looked alright.
The pump is in the front of the cabin next to the water tank.
A short could be the issue but have not fully checked the switch out.
The boat electrics are totally isolated and the boat is at peace.
Share this post
How do I check if a sender is faulty?
Can I put  on ohmmeter between the sender connection and earth and check for a reading?
Share this post
What should happen is that there is a power feed from the engine battery to the ignition switch. When the ignition is off this goes no further. Turning the ignition on should send power to the various lights and the alarm. So one explanation is that there is a short circuit / wire come off behind the ignition switch, or a faulty switch.
But also, the power comes from the engine (originally, from the starter battery of course) and from the engine there is a multi-wire bundle of cables, one carrying the power feed from the engine up to the panel, and one sending power back to the engine. A short circuit between these wires anywhere in the cable run (due to chafing etc) is a possibility but it’s mostly worth checking the multi-way connector that is in that cable run somewhere. These multi way connectors have a habit of getting corroded if they are in a damp engine bay. Pull the connector apart and check the contacts for corrosion.
Finally, as a diagnostic aid, if you start the engine is everything normal?
It depends on the sender. But that isn’t your issue. With the ignition off, there shouldn’t be any power going to the senders. A faulty sender might manifest itself as the alarm sounding when the engine was running.
Edited by nicknorman
Share this post
But also, the power comes from the engine (originally, from the starter battery of course) and from the engine there is a multi-wire bundle of cables one carrying the power feed from the engine and one sending power back to the engine. A short circuit between these wires anywhere in the cable run (due to chafing etc) is a possibility but it’s mostly worth checking the multi-way connector that is in that cable run somewhere. These multi way connectors have a habit of getting corroded if they are in a damp engine bay. Pull the connector apart and check the contacts for corrosion.
What you say makes plenty of sense and I will check the multiplug and the ignition switch as best I can.
The alarms still sound when the engine is running.
Share this post
I think you can discount the 'pump' then.
I'd suggest that you get behind (or remove) the instrument panel, witch on the power and start 'wiggling' about each wire individually and try and find something (switch, wire, fuse, connection)that could be shorting out.
Share this post
Yes there seems to be starting a consensus on the switch.
Thanks
Share this post
Thanks
It might be worth checking the cable plug first - if only because it's easy to check and eliminate before you dismantle the rest of the boat (!) It's one of the weak points in the Beta system and IME the plug and socket look solid - but they aren't.  You have been down the engine bay and so could easily have dislodged a connection. Then of course carry on with other folks' suggestions.
Share this post
will check the multiplug as easy and is basics so a good starting point.
Share this post
If the alarms continue to sound with the engine running, it won’t be the ignition switch. Much more likely to be the multi plug corroded. How old is the boat/engine? Cruiser stern or trad? (the former being likely to suffer damp and corrosion more than the latter).
Share this post
That is very helpful, the boat is 30 years old and the engine is around 15 so corrosion of the multiplug could be an issue.
Share this post
Do let us know what you find.
Share this post
OTOH, if the alarms stop sounding when the engine is running, it could still be the switch or multiplug!
Share this post
Can you explain how a fault in the ignition switch could cause the alarms to sound with the engine running?
Share this post
I'm not saying that!
I said that if the alarms STOP sounding when the engine is running, it could still be switch or multiplug.
e.t.a. If the alarm still sounds with engine running, then I think it has to be a multi fault scenario
Edited by Iain_S
Share this post
Oh yes I see, misread it. But the alarm is still sounding with the engine running!
Share this post
