Johny London Posted September 29, 2017 Report Share Posted September 29, 2017 Hoping to forage a few branches this year (having decided against going down the log ie axe/chainsaw/petrol/saw horse rout). I picked up a pair of 55mm ratchet loppers in Wickes the other day, only for the handles to bend immediately I tried testing them on a dry old bit of 40mm branch So, they're going back. Wonder if anyone knows a type that are still properly manufactured? I used to have a fairly basic pair from Homebase and you could practically stand on them - never bent and always cut. Maybe the ones with extending handles are not the way to go? What is the difference between Anvil and bypass? I had hoped to get a pair that would give me some sort of leverage advantage over the standard type. Everything seems like Chinese poor quality metal these days. Link to comment Share on other sites More sharing options...
tree monkey Posted September 29, 2017 Report Share Posted September 29, 2017 Depends on how much you want to pay, Fiskars or felco come well recommend but sandvick or bulldog should be ok. Anvil, have one blade that presses down on an anvil Bypass have an action similar to scissors. Anvil are rather dependent on a sharp blade but tbh for rough branch foraging I would go bypass Link to comment Share on other sites More sharing options...
rasputin Posted September 29, 2017 Report Share Posted September 29, 2017 40mm is a bit on the big side for loppers, I always used to tell my trainees, nothing thicker than your penis Link to comment Share on other sites More sharing options...
Johny London Posted September 29, 2017 Author Report Share Posted September 29, 2017 (edited) 24 minutes ago, rasputin said: 40mm is a bit on the big side for loppers, I always used to tell my trainees, nothing thicker than your penis Yes well you see... actually... no never mind..... There's not much point in something opening up much wider than it can cut though, is there? Hey Tree Monkey, thanks for that - the good pair I used to have were scissor type so might go for those again. I don't think anvil suit my style. Will definitely look at the brands you mention - after all I want to get a good bit of use out of them so don't mind spending a bit. PS: some seem to have like a dual pivot point type mechanism - is that so you can apply more pressure or something? I guess if I just get a big expensive pair I'll be ok. Edited September 29, 2017 by Johny London Link to comment Share on other sites More sharing options...
mark99 Posted September 29, 2017 Report Share Posted September 29, 2017 You may need a lot of lopping to keep you warm. My rule of thumb was two carrier bags per night when I used to scavenge only branches when dog walking. Link to comment Share on other sites More sharing options...
Mac of Cygnet Posted September 30, 2017 Report Share Posted September 30, 2017 Really dry wood is much harder to cut with loppers, and you wouldn't want to be cutting or burning live wood, would you? A saw, hand or chain, deals with dry wood far, far better. Link to comment Share on other sites More sharing options...
X Alan W Posted September 30, 2017 Report Share Posted September 30, 2017 As M of C says you don't want to be lopping off live branches & then burning more or less straight away a saw is a much better bet for dead wood Have you thought about a" Leccy" chainsaw they will cut wood better than loppers Link to comment Share on other sites More sharing options...
WotEver Posted September 30, 2017 Report Share Posted September 30, 2017 Cordless chainsaws are quiet and convenient if you’re only going to use one for short-ish periods. https://www.toolstation.com/shop/p16796?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=syH8YTgWQ_dm&pcrid=142476648874&pkw=&pmt=&product=16796&gclid=Cj0KCQjwgb3OBRDNARIsAOyZbxC5WZEqLywu4Z4m4sUmuZb-ndoSL196Zj-nlNBQ5FWVXyoP_5qYLKgaAukvEALw_wcB Link to comment Share on other sites More sharing options...
Johny London Posted September 30, 2017 Author Report Share Posted September 30, 2017 My plan was to pop out each morning for an Ikea bag full - only takes about ten mins as I've already been doing that. Currently I just snap the bits and chuck them in the bag, but I wanted to "scale up" production a little, hence the loppers. A little and often strategy also saves on storage plus most people don't bother with branches so there's lots around. Didn't think of the electric chainsaw - that would work for me but the battery and charger adds another £100 to it, so maybe something to go to if the loppers don't work out. I should add that I want to use a bit of coal plus branches - so I have flame from the wood and staying power from the coal. I've got a bow saw too so can tackle slightly bigger bits of wood It's nice to cut it all up in situ then bring to the boat, to save making a mess - I've seen people at the towpath using chainsaws and saw horses but personally I think that is a tad inconsiderate to other users. It's a bit messy, noisy and potentially dangerous. Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2017 Report Share Posted September 30, 2017 Or arm yourself with a good quality pruning saw, they are fiercely sharp and will go through reasonable sizes branches rapidly. Light to carry, quiet and easy to store. Link to comment Share on other sites More sharing options...
Jess-- Posted September 30, 2017 Report Share Posted September 30, 2017 31 minutes ago, Meanderingviking said: Or arm yourself with a good quality pruning saw, they are fiercely sharp and will go through reasonable sizes branches rapidly. Light to carry, quiet and easy to store. I use one of these when gathering wood from local woodland (with permission) http://www.ebay.co.uk/itm/231836513356 anything up to 8 inches is quick and easy to cut and the blade doesn't get pinched easily. they come with a clip on plastic blade cover, use it at all times as the teeth on the blade are ridiculously sharp Link to comment Share on other sites More sharing options...
Johny London Posted September 30, 2017 Author Report Share Posted September 30, 2017 Excellent idea - infact someone I came across a while ago had something similar and said it was very good. Definitely putting one on the list. Link to comment Share on other sites More sharing options...
tree monkey Posted September 30, 2017 Report Share Posted September 30, 2017 If you want the dogs in pruning saws http://www.silkysaws.com Be very careful, after many years of using I have decided they demand a blood sacrifice everytime they are used Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2017 Report Share Posted September 30, 2017 2 hours ago, Jess-- said: I use one of these when gathering wood from local woodland (with permission) http://www.ebay.co.uk/itm/231836513356 anything up to 8 inches is quick and easy to cut and the blade doesn't get pinched easily. they come with a clip on plastic blade cover, use it at all times as the teeth on the blade are ridiculously sharp I use the Wolfgarten saw for work, superb quality for the money. 1 hour ago, tree monkey said: If you want the dogs in pruning saws http://www.silkysaws.com Be very careful, after many years of using I have decided they demand a blood sacrifice everytime they are used I usually stick to cutting branches not body parts ............... Definitely the mutts nuts of saws though! Link to comment Share on other sites More sharing options...
mark99 Posted September 30, 2017 Report Share Posted September 30, 2017 At home I use an extendable lopper, must extend to 20 foot, on which you can remove lopper and screw in a saw pruner. Will extend your range! Link to comment Share on other sites More sharing options...
Ssscrudddy Posted September 30, 2017 Report Share Posted September 30, 2017 (edited) That greenworks chainsaw is excellent, & not scarily powerful like a petrol 1, but powerful enough. Uses an Oregon chain. The 45 mins runtime works out at about 2 hours work, & by the time you've then finished splitting that lot as well you'll probably want to call it quits for the day. Just 1 comment about the chain, it seems to be a weird sized 1 only available in asian (oriental) countries. Edited September 30, 2017 by Ssscrudddy Link to comment Share on other sites More sharing options...
tree monkey Posted September 30, 2017 Report Share Posted September 30, 2017 20 minutes ago, Ssscrudddy said: That greenworks chainsaw is excellent, & not scarily powerful like a petrol 1, but powerful enough. Uses an Oregon chain. The 45 mins runtime works out at about 2 hours work, & by the time you've then finished splitting that lot as well you'll probably want to call it quits for the day. Just 1 comment about the chain, it seems to be a weird sized 1 only available in asian (oriental) countries. If its bog standard oregon chain any decent dealer would be able to make one up 2 hours ago, mark99 said: At home I use an extendable lopper, must extend to 20 foot, on which you can remove lopper and screw in a saw pruner. Will extend your range! Can I just make a geeky request to leave deadwood in the trees and not cut it out Ideally deadwood would be left on the ground and not burnt but I am pragmatic enough to understand how important keeping warm is Link to comment Share on other sites More sharing options...
matty40s Posted September 30, 2017 Report Share Posted September 30, 2017 13 minutes ago, tree monkey said: Can I just make a geeky request to leave deadwood in the trees and not cut it out Ideally deadwood would be left on the ground and not burnt but I am pragmatic enough to understand how important keeping warm is This must be a sitting on a wooden fence moment for you. 1 Link to comment Share on other sites More sharing options...
Johny London Posted November 7, 2017 Author Report Share Posted November 7, 2017 Just a quick update - I had a good look around the shops and got to handle a few different types of lopper. aw a few models of fiskar but I didn't like them as the handles bend a bit and gave me the impression they might suddenly snap - though I bet someone will tell me its the same stuff as used in F1 so they wouldn't snap - but that's how it felt to me. Wilkinson Sword had some pretty tasty ones but then I remembered some garden snippers I had that soon rusted so I decided to keep away from chinese steel. Bunnings (the new version of Homebase and coming to a store near you, soon) had the best selection and I settled on a pair of Gardena, German made loppers. Not come across the brand before but could easily feel the quality - I won't break these. So far very successful and they cut up to and beyond their stated max - as a good tool should, not the other way round. I also picked up a cheap folding pruning saw - Draper £7 and going strong - if I get a season out of it I might go for one of those £30 ones next winter, just wanted to prove the usefulness of it first. Currently snug and warm with todays forage Sorry about all the trees and that... Link to comment Share on other sites More sharing options...
Murflynn Posted November 7, 2017 Report Share Posted November 7, 2017 I have 2 Fiskars loppers, one is a simple lopper and one is a ratchet lopper - both of them broke (the plastic head) when I tried to cut something too thick (not my d*ck ) and twisted them to try to break the branch off. I sent Fiskars a photo of the broken loppers and both of them were replaced without any hassle. I would buy again, but as said before, don't try to cut dry wood or anything wider than can be accommodated by the throat of the loppers (as opposed to the open end). Link to comment Share on other sites More sharing options...
bastion Posted November 7, 2017 Report Share Posted November 7, 2017 The nursery where I used to work at started stocking fiskar tools and quite frankly they were rubbish not what I expected from such a famous brand. They must of been taken over for the brand name. Link to comment Share on other sites More sharing options...
matty40s Posted November 7, 2017 Report Share Posted November 7, 2017 just nip up the Trent and Mersey East of the Alrewas river section or the North Oxford, wood lying everywhere. Link to comment Share on other sites More sharing options...
Johny London Posted November 7, 2017 Author Report Share Posted November 7, 2017 Hmm, glad I went with my instinct - I'm sure I won't break the Gardenas, they are stronger than I am. Link to comment Share on other sites More sharing options...
BWM Posted November 7, 2017 Report Share Posted November 7, 2017 On 30/09/2017 at 13:27, Meanderingviking said: Or arm yourself with a good quality pruning saw, they are fiercely sharp and will go through reasonable sizes branches rapidly. Light to carry, quiet and easy to store. Good quality being the key, the cheaper ones don't last when regularly used to cut dry timber. Link to comment Share on other sites More sharing options...
bizzard Posted November 7, 2017 Report Share Posted November 7, 2017 (edited) Fix a small sharp panel saw to a long stick, while standing on the ground offer up to branch and pump it up and down. Electricity boards use this method with a little saw on the end of, like screw together aluminium sweeps rods for really high branches that are interfering with the overhead power cables. Edited November 7, 2017 by bizzard Link to comment Share on other sites More sharing options...
