Did you know Canal World is funded by our valued members? You may make a voluntary donation by clicking here
Mikexx
Mysterious object - what is it?
Mikexx    4
As per topic title
Its in the flow side between calorifer and engine.
I've googled the numbers and letter and haven't comeup with anything.
Any ideas?
Share this post
Jon12345    3
It's a check valve which allows water to only flow one way. Like a non return valve but Check Valves operate in a different way but perform the same job.
Share this post
mross    279
If you Google "crane d140" you will find lots of info.  As said, it's a bronze swing check valve.
Share this post
Mikexx    4
I genuinely thought I had put various combinations of letters and numbers into google and hadn't come up with anything.
Thanks, its purpose must be to make sure no hot water circulates into the engine when it's not running.
Share this post
mross    279
I'm an engineer, so I knew which numbers would get results!  Also, the quotation marks make a big difference with Google.
Share this post
nicknorman    1,972
Just to mention that the advantage of a swing check valve over the more normal Non-Return Valve (NRV) is that the pressure required to open the valve is much lower. The high pressure required to open a NRV often results in an annoying disparity between the flow rates of hot and cold taps when both are open at the same time,
Share this post
WotEver    687
24 minutes ago, Jen-in-Wellies said:
It has "Made in Gt Britain" on top and not "Made in China", so obviously rather old and been there for a while.
Jen
And will no doubt still be there and functioning well for many more years to come :)
Share this post
Laurie.Booth    169
3 minutes ago, Tony Brooks said:
Probably fitted to prevent thermo-syphoning backwards through the engine when it cools down at night.
It was actually fitted so that 30 years later we could talk about it on the internet which had not been invented yet.
Share this post
<pedant_mode> Actually the internet was around 30 years ago, but the world wide web hadn't been invented yet. CWDF, if it had existed then would have been a bulletin board or some such.</pedant_mode>
Share this post
Laurie.Booth    169
OK 34 years ago
Share this post
Mikexx    4
It has a  Nitrile Rubber disc, so after 30 years I would say its a close call.
Share this post
Bobbybass    193
Yup...stops thermosyphoning. If you have a nice tank of hot water...you don't want it keeping your engine toasty    :-)
Edited by Bobbybass
Share this post
