linnit    5
Having just viewed a Sabb in a previous thread.. Are any of our members prepared to post pics of their engines?..purely to satisfy me an engine polisher anorak:D
Share this post
linnit    5
Hahaha..obviously not...time to pour the Brasso away:P
Share this post
PaulJ    11
Well its another Sabb- a 30 hp 2J-HR- but inside which is even pornier I reckon :D
1st pic engine in situ but with fuel pump cover removed, heads,pistons and rods removed etc .Two round holes in the centre are where the fuel pumps fit into and are driven straight off the camshaft.
2nd pic shows the inside of the fuel pump cover- governer top left and lift pump bottom right with fuel pumps and mechanism in centre. No need to readjust anything- remove fuel pipes and it just unbolts and bolts back on. Brilliant!
3rd pic showing pistons and rods- the big end shells on these engines are an impressive 10mm thick! Well it impressed me anyhow.
Share this post
linnit    5
21 minutes ago, Mike the Boilerman said:
Here's one of my pistons....
Off?:)
Share this post
koukouvagia    97
Since this thread is developing into a "who's got the biggest pistons?" contest, I thought I'd post the ones from a Kelvin. :P
Share this post
LEO    44
1 hour ago, linnit said:
But they look smaller than MTB's:D
Like everything - size doesn't matter it's what you can do with it........or them in the case of a Kelvin.
Share this post
linnit    5
Ballast:D
Share this post
Tom766 Contributor    2
I have my first boat, it has a Bukh 10hp single pot diesel. Even for a narrowboat I think it's slow......old ladies pushing zimmer frames walk past me on full throttle :blush:
And I discovered why theres a full size set of ear defenders in the cupboard. I'm in the process of sound deadening the engine bay...
Share this post
Lol I think the piston from my dead Skandia beat 'K' series Kelvin pistons. About 9" in diameter and 12" tall, cast iron and almost too heavy to pick up. I took a photo but can't find it now.
On a related front, I am now the proud owner of a lovely K2 and well as a K1 :)
On 8/5/2017 at 17:42, linnit said:
Off?:)
Off, or rather in, my Gleniffer DB2.
Share this post
koukouvagia    97
Let's have some pictures.  I'm suffering from withdrawal symptoms.
Share this post
6 hours ago, dave moore said:
Here is Resolute's J3. A modest bit of grunt...
I know I am showing my ignorance here, but I know almost nothing about Kelvin engines apart from the fact that I believe they are all Diesels. I notice that your engine has spark plugs , does that mean it is petrol start with changeover to diesel when hot.
The farm where I used to help out when I was a boy, had an old Fordson tractor which started ( often failed to start!!) on petrol and changed over when hot, except that it was paraffin rather than diesel
Share this post
hughc    17
See post 17. Kelvin made more petrol paraffin engines than they did diesels and continued to do so until I believe the late sixties.They are well engineered reliable and so quiet. The F4 in the photograph produces 30 H.P. at 700 RPM albeit from 6 litres. It has considerably more torque than many traditional boat diesels and is so, so quiet. Tom posted a video clip on you tube of an F2, admittedly with rudimentary silencing and that has, as you would expect,  half the power at the same revs. We have a number of these beautiful engines and are in the process of developing a cold start on paraffin adaptation. If you search for a video of Joel you will see an exceptional boat powered by an exceptional engine HughC.
Share this post
dave moore    189
The J3 in our boat was a petrol start as originally configured. The idea was to allow hand starting with no more effort than starting a car with a handle. We had a starter ring fitted to the flywheel and used a starter motor from the beginning. Magneto problems, with expensive solutions, prompted the conversion to diesel start using glow plugs fitted to the air intake. Dick Goble, the Kelvin guru, gave much advice with this. To be honest, I'm not sorry to be without the petrol start.
Dave
Share this post
Irob    26
I,ve been trying to shoehorn this little baby into Alchemy but its too heavy as is. I suppose i,ll have to remove some pistons first. I think its 12 litres all up but developed a bit of a wine. Story of my life : piston broke !
Share this post
AndyV    15
On 11/08/2017 at 22:50, Mike the Boilerman said:
blob.png.785eb313949f858a0d7504871f256a18.pngblob.png.e60e807dd81ded55752c37f6fa92431b.png
Mike. I believe that to be Oak? If so I am glad it's ended up with someone who appreciates the Kelvin. I was the first owner.
Share this post
