Walsall lock flight
AMModels
Walsall Canal
Starts At: Lock 1, Walsall Top Lock
Ends At: Lock 8, Walsall Bottom Lock
Thursday 20 July 2017 12:00 until further notice
Type: Navigation Closure
Reason: Vandalism
Update on 20/07/2017:
Please note that this is due to the balance beam being sawn off and we will provide an update as soon as we have a plan to resolve the issue.
Some pics of the damage to the beam of lock 2, doesnt look like random vandalism. Cuts very clean and as you can see in the second pic theres a services line marked in white on the brickwork that lines up with the cut.
Could CRT have tried to refuse access to a contractor and upset someone?
Edited by AMModels
photo source: BrownhillsBob
On 22/07/2017 at 08:13, Sea Dog said:
That can't have been an easy cut! Someone certainly needed a lump of wood like that for a particular purpose: let's hope it doesn't become 'a thing'. :(
Prolly quite easy.  It looks like a chain saw job and quite neat.
I wonder how the beam was carried off, if it was?
I have new garden feature it is heavy but.................
Someone who knew what they were doing though, very neat and squared off the split as well. Not some kids with a chainsaw messing about.
There are service lines under the area the beam extended over, fresh surveyors markings on the ground too.
3 hours ago, john6767 said:
Was the beam actually removed?  If it was there seems no logic to cut off the top bean, the bottom lock is closer to the road.
yup no sign of the beam anywhere. That wouldnt have been easy to move it must have weighed a couple of hundred kilos.
Just seen on Twitter that it is both the top and bottom beams that have been cut off!
edited to add, this is LOCK 4, i.e. They have done another one it seems, madness.
Edited by john6767
58 minutes ago, AMModels said:
John I think I may have been in error, this is the same lock but the second beam being cut off is new according to the people who were there the other day.
Ok so was it always lock 4 then, but someone has now come back and done the bottom gate?
John6767 – yes, it is now both ends of the same lock (the last photo steps top right shows it is lock 4)
I visited "the scene of the crime" on Saturday but have not been back to see the result of the second event – I've got no idea what is going on!
At least one beam is pictured floating in the water on FB which makes the whole thing even more bloody pointless.
Hopefully they don't go back and have another go somewhere.
32 minutes ago, furnessvale said:
Lace the new beams with hidden nails and barbed wire!
George
Metal bar down each side, give them a bit more to think about if they try again.
These are some of the additional pictures from FB, for those that don't do it.
20369106_461051080925112_492866707681490
20280603_461051887591698_549551652476563
20287177_461052000925020_484843498215780
Looking at the beam floating in the water, it is vandalism pure and simple.
Looks like some yobs have stolen themselves a chain saw.  With a bit of luck, one of them will not be used to using one and take his own leg off!
I still prefer hidden nails.  Much more chance of a snatch causing the effect outlined above!
George
Looks like repairs are now underway.
Let's hope they don't cut off the replacement beams.
Notice Alert
Walsall Canal
Reason: Vandalism
Update on 26/07/2017:
Despite further acts of vandalism to locks on this flight we are pleased to confirm that works are now underway to replace the damaged beams.
We hope that the flight will be open by close of play tomorrow (Thursday 27th) at the latest but we will update the notice as soon as the works are complete and we have any more information.
Original message:
Due to vandalism the Walsall Lock flight will be closed until further notice.
Alternative routes are via the Tame Valley Canal and along the Rushall,Canal or the Birmingham Mainline Canal to Wolverhampton and continuing on to the Wyrley & Essington Canal.
Steel beams bolted onto what's left of the balance beams would stop the yobs.
That is until they steal a petrol powered angle grinder to do the job!
George
