foleyhancox Posted May 7, 2017 Report Share Posted May 7, 2017 By any chance could some tell us whether you can use rubber grommets on the pipes through bulk heads instead of using bulk head fittings? Will it pass the boat safety? Link to comment Share on other sites More sharing options...
WotEver Posted May 7, 2017 Report Share Posted May 7, 2017 3 hours ago, foleyhancox said: By any chance could some tell us whether you can use rubber grommets on the pipes through bulk heads instead of using bulk head fittings? Will it pass the boat safety? The BSS states that a cable gland fitting can be used, no mention of grommets. The problem with a grommet is that it can wear through, unlike either a cable gland or a bulkhead fitting. https://www.boatsafetyscheme.org/media/268789/ecp-private-boats-ed3_rev2_apr2015_public_final.pdf Considering that the gas system is the only system on the boat which can blow you up my personal preference would be for bulkhead fittings. Link to comment Share on other sites More sharing options...
foleyhancox Posted May 7, 2017 Author Report Share Posted May 7, 2017 Many thanks, that really helps. Looks like we're off to sort bulk head fittings. Thanks again. Link to comment Share on other sites More sharing options...
MtB Posted May 7, 2017 Report Share Posted May 7, 2017 3 hours ago, WotEver said: The BSS states that a cable gland fitting can be used, no mention of grommets. The problem with a grommet is that it can wear through, unlike either a cable gland or a bulkhead fitting. https://www.boatsafetyscheme.org/media/268789/ecp-private-boats-ed3_rev2_apr2015_public_final.pdf Considering that the gas system is the only system on the boat which can blow you up my personal preference would be for bulkhead fittings. Bear in mind the last boat mentioned on here for blowing up. The cause was petrol fumes being ignited IIRC. Nothing to do with the gas system. Link to comment Share on other sites More sharing options...
WotEver Posted May 7, 2017 Report Share Posted May 7, 2017 16 minutes ago, Mike the Boilerman said: Bear in mind the last boat mentioned on here for blowing up. The cause was petrol fumes being ignited IIRC. Nothing to do with the gas system. Yoghurt pot with petrol engine if I recall correctly. Diesel engined sewer tubes don't tend to explode from fuel fumes Link to comment Share on other sites More sharing options...
Murflynn Posted May 8, 2017 Report Share Posted May 8, 2017 thing is, can we instill in people the belief that if gas pipes are correctly installed, then anyone using the boat will feel instilled with confidence about the installation? Link to comment Share on other sites More sharing options...
MtB Posted May 8, 2017 Report Share Posted May 8, 2017 Qué? Link to comment Share on other sites More sharing options...
cuthound Posted May 8, 2017 Report Share Posted May 8, 2017 (edited) Spelling in title. Instillation viz installation. Edited May 8, 2017 by cuthound To unmangle the effects of autocorrect. Link to comment Share on other sites More sharing options...
MtB Posted May 8, 2017 Report Share Posted May 8, 2017 R I C ! Link to comment Share on other sites More sharing options...
