Jrtm Posted October 8, 2016 Report Share Posted October 8, 2016 Just dipped my oil and is low want to add a bit but the only sae 30 oil i can get local is a sae 30 horticultural oil designed for stationary engines and generators. Will this be ok going to do oil change after once i can get the correct stuff as i want to change the oil lines as one has a slight leak. Link to comment Share on other sites More sharing options...
David Schweizer Posted October 8, 2016 Report Share Posted October 8, 2016 Just dipped my oil and is low want to add a bit but the only sae 30 oil i can get local is a sae 30 horticultural oil designed for stationary engines and generators. Will this be ok going to do oil change after once i can get the correct stuff as i want to change the oil lines as one has a slight leak. I had to use some of that in an emergency, many many years ago, when the oil filter on my BMC1.5 (not originally fitted by me!!) developed a leak, and I had run out of the correct oil. However, I replaced it as soon as I could get the correct stuff, and had re-fitted the oil filter. To get better advice we really need to know either which engine you have, or what the API rating should be. If it is an old engine requiring CC rating, Classic Oils of Aylesbury often offer a good deal on Morris Golden Film SAE 30 Oil. Link to comment Share on other sites More sharing options...
Geo Posted October 8, 2016 Report Share Posted October 8, 2016 What is the engine? Link to comment Share on other sites More sharing options...
Jrtm Posted October 8, 2016 Author Report Share Posted October 8, 2016 I happen to go past my local has everything small garage shop asked (hold on a wee sec) 10 mins later 2 cans or classic motor oil sae 30 Its a national Link to comment Share on other sites More sharing options...
David Schweizer Posted October 8, 2016 Report Share Posted October 8, 2016 I am not an expert, but if your engine is a National as fitted to many GUCC boats, I guess it will require a low grade API:CC/SF grade oil:- http://www.classic-oils.net/Morris-Golden-Film-SAE-30 Link to comment Share on other sites More sharing options...
by'eck Posted October 8, 2016 Report Share Posted October 8, 2016 I happen to go past my local has everything small garage shop asked (hold on a wee sec) 10 mins later 2 cans or classic motor oil sae 30 Its a national Most chandelries and marinas sell Morris Golden Film low detergent in that grade. Link to comment Share on other sites More sharing options...
Jrtm Posted October 8, 2016 Author Report Share Posted October 8, 2016 Yes was more a case of it got low and i hadnt looked and disnt wanna move the boat without adding anything Link to comment Share on other sites More sharing options...
