Power generation
Chris Pink
  • 1 year later...
21 minutes ago, zenataomm said:
I've just had a Eureka moment in Aldi.
If this had been 3 days ago I'd have given it a sideways glance.
However as it's not, I think we've cracked it!  Anybody want to come in with me?
BUT it says it connects to a car battery .. so unless you park your car on the deck you're going to need a long cable :rolleyes:
  • 1 year later...
On 31 December 2011 at 11:16, Chris Pink said:
http://www.victronenergy.com/orderbook/
It's been posted a couple of times in various topics but, having just read it, I think it deserves a topic of its own.
It looks like the Victron website doesn't like Safari since I just get a blank screen (no 404 message)
On 31 December 2011 at 11:40, MJG said:
Same applies :(
Happy to report that Chrome works fine :)
Same applies :(
I'm amazed they work at all after seven years
1 hour ago, George and Dragon said:
Not sure how this might help...
Did it work?
also try Safari menu > Empty Cache and then Cmd R on the page.     If no menu option do a opt + cmd + E as this is the shortcut for the option.
If still not then try Safari > Reset Safari
if reset Safari not showing use Safari > preferences > privacy > remove all website data
Edited by Robbo
4 hours ago, Robbo said:
Did it work?
The iMac has been misbehaving since I first tried the link.
I've taken the plunge and updated from 10.9 (unsupported) to 10.11 (still supported even though it's almost 3 years old).
This should bring a whole load of security updates and a newer version of Safari so I will see if anything has changed once the system has settled down
6 hours ago, cuthound said:
Interestingly he has only made two posts. I seem to remember way more that two from him ?
I think it is a different G&F. The old one used to be a mod too!
Edit to add:
Yes the original G&F used the word 'and', not an ampersand. Last visited here in aug 2017.
https://www.canalworld.net/forums/index.php?/profile/5979-grace-and-favour/
Edited by Mike the Boilerman
Edit to add:
Unless it’s a imposter, the location is correct for our old delightful mod.
1 minute ago, Grace & Favour said:
The 'and' is because I mislaid my password for the '&' identification - - - but yes - 'tis me folks!
(And still on the Aire Navigation . . are you all well?)
Welcome back
The good news is the whole system is much more responsive. Malwarebytes discovered and dealt with one problem, some adware that had found its way in.
I haven't tried the Viltron website again...
bLUMMINN ECKERS, you dont know what you missed...:D
I tried to message you.
I still have the mud-weight you lent us in Leeds, but sadly all 25Kg of it are now in Hertfordshire.
A bit expensive to post, methinks...................
Suggestions ????
