Johnjo123
Everything posted by Johnjo123
  1. They might not like it but I don't think any one would wrestle you to the ground. What are the self pump out kits like? are they worth the money?
  2. The radio will need a positive + 12v supply, a negative 12v connection, usually a minimum 2 speaker connection (1 pair of wires for each speaker ) the aerial if attached to your roof will also need a negative supply (ground -) as the battery negative is not connected to the metal of the boat, as mentioned in one of your other replies if you have your batteries switched off you will need a permanent + positive supply from the battery to a memory wire to keep the memory alive, unless your radio has a non-volatile memory (one that doesn't need a power supply - a bit like your mobile phone. Car wiring is beginning to be more standardised for certain circuits, positive is normally red, negative brown or black, speaker wire can be any colour, memory wire sometimes orange, if your not confident just leave it until you meet a fellow boater with the knowledge and share a bottle of wine.
  3. Its a matter of personal choice, do you pay nothing and tip it in a tank or pay £10.00 to £15.00 to get a machine to do it ( bloody exorbitant considering it ends up in the same tank) or in the case of Whilton marina pay £2.50 to use the elsan. Use the pub or BP petrol station (BP can definately afford the toilet paper)
  4. I'd guess at this point we all know what we are talking about, but I'll take on board the replies and will leave this subject to the experts. Thanks anyway.
  5. Just to add when the engine is running with no load (no electrical consumers switched on) you should be charging the batts even at idle speed, once your engine is running at cruising speed your alternator will generally not supply more than 14.6v, when you apply a load to the engine such as putting it into gear from neutral at tickover the charge rate will drop but so long as it is over 12.5volts its charging, when you switch on an electrical load such as lights, pumps etc the charge level may drop slightly, the alternator will deal with the load with a slight drop in engine speed, however as soon as you take the engine speed back up to over tickover speed the alternator will be charging at anything between 13 to 14.6v again the only problem you will have is, if you demand more from your batteries than the alternator can deal with in a short period or exceed its rated output, ie if your alternator has an out put of 85amps dont expect it to charge the batts and supply 85amps it will just wear out quicker. I think some of your replies were relating to running the engine in gear at higher revs, (you dont need to do this for optimum charging) the manufacturers recommend doing this to clear the combustion chamber of soot due to the constant low running speeds, it has nothing to do with charging! In the old days people use to rev there car engines up before switching off so as to clear the cylinder of unburnt fuel and clean the plugs a bit, however modern engines have moved on but they do benefit from the occasional high speeds under load, better to do this in a marina, well tied up for at least 10 to 15 mins so long as the noise doesn't cause a nuisance to your neighbours.
  6. Hello mate, just to let you know we made it back to the marina at Whilton on Sunday 2nd August, left on Monday 3rd to cruise the Ashby and back, poor weather most of the time but the last few days of sunshine made up for it. How u doin.
    John NB Miss Ellie
