Everything posted by Drayke
Sloe Gin recipe. 2-3 pounds of sloes 4-6 ounces of sugar 1ltr cheap gin Wash and destalk sloes then place in freezer for a week or so, if you don’t have a freezer then you are supposed to prick several times all of the sloes, very tedious. Place the sloes, sugar and gin in large Kilner jar seal lid and give it a good shaking, the shake every day for a couple of weeks or until sugar has dissolved. Place somewhere cool and out of the way for 3 months or so, longer if you can, then taste adding some more sugar if you think it needs it. Very pleasant to drink on a cold winters evening, or any time. Sloe Gin recipe. 2-3 pounds of sloes 4-6 ounces of sugar 1ltr cheap gin Wash and destalk sloes then place in freezer for a week or so, if you don’t have a freezer then you are supposed to prick several times all of the sloes, very tedious. Place the sloes, sugar and gin in large Kilner jar seal lid and give it a good shaking, the shake every day for a couple of weeks or until sugar has dissolved. Place somewhere cool and out of the way for 3 months or so, longer if you can, then taste adding some more sugar if you think it needs it. Very pleasant to drink on a cold winters evening, or any time.
But if you do that it must create condensation inside the boat will it not?
I think this, in red, means that there is no water in the filler pipe and not the pipe work after the pump. hope that makes sense.
I have a 240v pull cord light switch for my gulper shower pump and its been working for the last 15years or so, that's the switch not the pump, touching wood with crossed fingers.
Just to make it clear, my bow thruster batteries are in a bow locker, 2x110amh, that are charged via the engine that has an 80amp alternator with a slit charge relay that also charges the engine start battery, plus I do have an old 20amp charger fitted that runs of off 240v. I was just asking the preferred batteries to use. Thanks for all the replies.
What batteries would you fit for an electric bow thruster? I would presume starter batteries and not leisure ones.
Had boat in dry dock 6th August to 12th August just gone, so I could re-black the hull with another two coats of two pack, Hempadur. Last had the boat out in 2014 for blacking. The only problem found this time was flaking on the rubbing band, but that was no surprise. The original anodes that came when the boat was new 2006, where take off and replaced with the new ones, although the ones i had welded on in 2014 still had quite a bit of meat on them. So, two pack works. Sorry no pictures as I forgot to take any.
No hot water but new immersion heater?
Drayke replied to NealSmith100's topic in Boat Building & Maintenance
Maybe its the thermostat playing up. -
No. Copied and pasted from thier webb site. Traditional rope fenders, made by ourselves, in either natural sisal or black polypropelyne. Specials can be made to order Delivery can be arranged.
You could also try ukboatyard.com and speak too Victoria.
No mushrooms should be sliced quite thickly so you see them as well as eat them.
Pork Chops with creamy mushrooms sauce Recipe. Learn how to make this recipe for a creamy sauce filled with mushrooms, Worcestershire sauce, onion, and garlic. Servings 4. TOTAL TIME: About 40 MINUTES Ingredients 4 thick-cut, boneless pork chops or pork loin cut into medallions, you can also use chicken breasts,thighs or strips, salt & pepper to taste. 2 tablespoons cooking oil, divided 1 onion, chopped 8 ounces white or brown mushrooms, sliced 1 or 2 clove garlic, crushed 1 tablespoon flour 1 ½ cups chicken stock ½ cup cream 1 dash Worcestershire sauce that's, about a tea spoon. Directions Place a large, deep pan on the stovetop over medium-high heat and add in 1 tablespoon of oil. Liberally season your choice of meat with salt and pepper, then add them to the pan. Allow each side to brown for 3 to 4 minutes, then remove from the pan. Set the meat on a plate to one side. Add the remaining tablespoon of oil to the pan, then add the sliced onion and mushrooms, sauté until they are softened and coloured. Add the crushed garlic to the pan and cook for a minute or 2 longer. Stir the flour into the vegetables, then add the chicken stock. Stir everything together, and then add the cream and a dash of Worcestershire sauce, and stir everything once more. Return the browned meat to the pan and allow them to simmer in the creamy mushroom sauce, lid off, for 10 minutes, or so until thoroughly cooked through, giving it a stir now and again. Serve the meat hot and fresh from the pan, with extra sauce spooned on top. Store leftovers in an airtight container in the fridge. Served over a bed of mashed potatoes with veg, or you can have it on a bed of rice.
Enter lock close gates, move boat back to gates, tie off forward line backwards from bow, tiller over to side of lock that you are moored against and run engine in forward gear, then have crew member on bankside open paddles. I know of a fuel boat that always did it this way and it worked every time. This going up the locks.
This sounds like you have a damaged seal so you can also expect after a sort while for it to start dripping again, so check on a very regular basis, When you squeeze in the silicon only put a very small amount in, about the size of a pea. If you put too much into it you can blow the seal out of its housing, been there done that. There is a thread on here somewhere about these seals, perhaps someone with the know how can point you in the right direction, and even how to replace them with the boat still in the water.
Don't forget to check under the flooring (Bilge) to see how much water is there that will need to be removed.
Just found this topic and thought that others may be interested.
As do the Boatyard on the K&A at Hilperton.
More pictures here www.walkerboats.com
I had the pleasure of selling this one when I was at the T&K marina.
No I haven't and yes I would agree with you that you probably are one of the few that have.
Why do they check if its not mandatory?
No need for a strainer as Gulpers can handle all that sort of stuff, my one has been doing that for about 8 years without a strainer. I do hope I haven't spoken to soon.
Just out of curiosity and as I don't know and I'm not sure if it has been asked before but, what surcharges will someone with a wide beam that is a continues cruiser have to pay? I think C&RT should base the standard licence fee on the length X width of a boat, The same as the EA do, that would seem much more sensible.
Where abouts in Brentford is that as I don't recognise it and I born and bred there 1948-1973. I also went to the gas works on a Saturday morning with me homemade hand cart to buy sacks of coke [not the kind you put in a roll-up] for the week.
