Gender
Location
The Black Fen
Occupation
Lazy bugger
Boat Name
Saskia
Boat Location
R Nene
Mat B's Achievements
Collaborator (5/12)
10
The reason you have not had a reply to this might be because Boat Mail are under new ownership and people are reluctant to recommend them until the new management has proved themselves. For my part, I have had a couple of minor queries since the new regime took over, and found them very helpful and efficient on both occasions so I have no hesitation in recommending them. MB
THIS ↑ ☺☺☺☺
Here you go: #!/usr/bin/python import numpy as np #import matplotlib as mpl import matplotlib.font_manager as font_manager import matplotlib.pyplot as plt import matplotlib.dates as mdates from pylab import * import spidev import time from time import gmtime import RPi.GPIO as GPIO import os import ftplib Save = 1 # 1 = Save data to file print_data = 1 # Print data to stdout TimeSleep = 5 # Sleep time ftp_out = 1 # 1 = upload, 2 = verbose # Set timers period_get_data = 60 * 10 period_graph1 = 60 * 30 period_graph2 = 60 * 60 * 12 period_fridge = 60 * 15 period_aux = 60 * 6 # Initialise timers time_get_data = int(time.time()) time_graph1 = int(time.time()) time_graph2 = int(time.time()) time_fridge = int(time.time()) time_aux = int(time.time()) # Font path = '/home/pi/PythonProgs/YanoneKaffeesatz-Bold.ttf' prop = font_manager.FontProperties(fname=path, size=13) # Use Broadcom pin numbers (as printed on Humble Pi) GPIO.setmode(GPIO.BCM) # set up GPIO input/output channels GPIO.setup(17, GPIO.OUT) # LED on pin17 for i in range(22, 26): GPIO.setup(i, GPIO.OUT) # Relays on pins 22-25 # Define relay on/off functions def relay_on(pin): GPIO.output(pin,GPIO.HIGH) # print 'Pin ', pin,' on' def relay_off(pin): GPIO.output(pin,GPIO.LOW) # print 'Pin ', pin,' off' # Set up Serial Periperal Interface spi = spidev.SpiDev() spi.open(0,0) def read_spi(channel): spidata = spi.xfer2([1,(8+channel)<<4,0]) # print("Raw ADC: {}".format(spidata)), data = ((spidata[1] & 3) << 8) + spidata[2] # print("Data: {}".format(data)) return data # Set up data file try: f = open("data.csv", "r"); f.close() # Check if file exists except IOError as e: # If not, write headers f = open("data.csv", "w"); f.write('tt,year,month,date,day,hour,ttt,balanceI,solarI,boatI,data3,auxV,panelV,startV,battV,temp0,temp1,temp2,temp3,temp4,AhSolar,AhConsumed,AhAux \n'); f.close() # Set up log file try: f = open("log.txt", "r"); f.close() # Check if file exists except IOError as e: # If not, write something f = open("log.txt", "w"); f.write('This is not an EMPTY FILE'); f.close() # Set up stats file try: f = open("stats.txt", "r"); f.close() # Check if file exists except IOError as e: # If not, write something f = open("stats.txt", "w"); f.write('0,0'); f.close() #make global variables data0 = data1 = data2 = data3 = data4 = data5 = data6 = data7 = 1 temp0 = temp1 = temp2 = temp3 = temp4 = 1 thour = tdate = tmonth = tyear = tday = ttt = 1 log1 = log2 = log3 = log4 = log5 = "." AhSolar = AhConsumed = AhAux = 0 tday_old = str(time.strftime('%a')) # tday # Read stats file ##f = open("stats.txt", "r") ##f.read (AhSolar, AhConsumed) ##f.close() ##AhSolar, AhConsumed = np.genfromtxt('stats.txt', delimiter = ',', unpack = True, usecols=(0,1)) ##print 'Test: '+AhSolar+AhConsumed ################### Temperature ################ os.system('modprobe w1-gpio') os.system('modprobe w1-therm') temp_sensor = '/sys/bus/w1/devices/28-0000056ed968/w1_slave' def temp_raw(): f = open(temp_sensor, 'r') lines = f.readlines() f.close() return lines def read_temp(): lines = temp_raw() while lines[0].strip()[-3:] != 'YES': time.sleep(0.2) lines = temp_raw() temp_output = lines[1].find('t=') if temp_output != -1: temp_string = lines[1].strip()[temp_output+2:] temp_c = float(temp_string) / 1000.0 temp_f = temp_c * 9.0 / 5.0 + 32.0 return temp_c #, temp_f ########################### Update log file ######################### def log(log0): global log1, log2, log3, log4, log5 log4 = log3 log3 = log2 log2 = log1 log1 = log0 if Save == 1: f = open("log.txt", "w") f.write(log4+"<br>"+log3+"<br>"+log2+"<br>"+log1) f.close() ########################### ADC and One-Wire Inputs ############## def get_data(): global data0, data1, data2, data3, data4, data5, data6, data7, AhSolar, AhConsumed # Read the ADC channels (0-7) : ([0 to 1033] * Correction for divider resistors data0 = (read_spi(0) - 525.0) * -0.074 # Balance I data1 = (read_spi(1) - 495.0) * -0.0685 # Solar I data2 = (read_spi(2) - 510.0) * 0.074 # Boat I data3 = read_spi(3) data4 = read_spi(4) * 0.0365 # Aux V data5 = read_spi(5) * 0.333 # Panel V data6 = read_spi(6) * 0.0365 # Start V data7 = read_spi(7) * 0.0367 # Boat V global temp0, temp1, temp2, temp3, temp4 # Read the 1-wire inputs temp0 = read_temp() temp1 = 0 temp2 = 0 temp3 = 0 temp4 = 0 tempC = int(open('/sys/class/thermal/thermal_zone0/temp').read()) / 1e3 if print_data > 0: print("Balance: {0:0.1f}A,".format(data0)), print("Solar: {0:0.1f}A,".format(data1)), print("Boat: {0:0.1f}A,".format(data2)), print("Aux: {0:0.1f}V,".format(data4)), print("Start: {0:0.1f}V,".format(data6)), print("Domestic: {0:0.1f}V,".format(data7)), print("Panels: {0:0.1f}V,".format(data5)), print("Ext Temp: {0:0.1f}".format(temp0)) + u"℃", print("Core Temp: {0:0.1f}".format(tempC)) + u"℃" #Eliminate small readings if data0 < 0.15: data0 = 0 if data1 < 0.15: data1 = 0 if data2 < 0.15: data2 = 0 if data3 < 0.15: data3 = 0 if data4 < 0.15: data4 = 0 if data5 < 0.15: data5 = 0 if data6 < 0.15: data6 = 0 if data7 < 0.15: data7 = 0 # Time values for graph global thour, tdate, tmonth, tyear, tday, ttt tyear = str(time.strftime('%Y')) tmonth = str(time.strftime('%B')) tdate = str(time.strftime('%d')) tday = str(time.strftime('%a')) thour = str(time.strftime('%H:%M')) ttt = time.strftime('%y%m%d%H%M') # print tday, stats() if Save == 1: f = open("data.csv", "a") f.write(str(time.time())); f.write(',') f.write(tyear); f.write(',') f.write(tmonth); f.write(',') f.write(tdate); f.write(',') f.write(tday); f.write(',') f.write(thour); f.write(',') f.write(ttt); f.write(',') f.write(str(data0)); f.write(',') f.write(str(data1)); f.write(',') f.write(str(data2)); f.write(',') f.write(str(data3)); f.write(',') f.write(str(data4)); f.write(',') f.write(str(data5)); f.write(',') f.write(str(data6)); f.write(',') f.write(str(data7)); f.write(',') f.write(str(temp0)); f.write(',') f.write(str(temp1)); f.write(',') f.write(str(temp2)); f.write(',') f.write(str(temp3)); f.write(',') f.write(str(temp4)); f.write(',') f.write(str(AhSolar)); f.write(',') f.write(str(AhConsumed)); f.write(',') f.write(str(AhAux)); f.write('\n') f.close() f = open("is.txt", "w") f.write ("SOLAR CHARGE: {0:0.1f} Ah".format(AhSolar)) f.close() f = open("ic.txt", "w") f.write ("CONSUMED CHARGE: {0:0.1f} Ah".format(AhConsumed)) f.close() f = open("vb.txt", "w") f.write ("CORE VOLTAGE: {0:0.1f} V".format(data7)) f.close() f = open("time.txt", "w") f.write ("DATA UPDATE: " + thour + ' ' + tday) f.close() #log('Test message '+str(time.strftime('%H:%M'))) print'.', ################### Statistics ################## def stats(): global AhSolar, AhConsumed, AhAux, tday_old if tday_old != str(time.strftime('%a')): # detect midnight AhSolar = 0 AhConsumed = 0 AhAux = 0 tday_old = str(time.strftime('%a')) # reset day AhSolar = AhSolar + (data1 * period_get_data / 3600) AhConsumed = AhConsumed + (data2 * period_get_data / 3600) AhAux = AhAux + (data0 * period_get_data / 3600) # print AhSolar, AhConsumed ## f = open("stats.txt", "w") ## f.write (AhSolar, AhConsumed) ## f.close() ################################################# get_data() # Initial run ###################### Draw Graphs ##################### def graph(type): print '' print 'Graphs ',str(time.strftime('%H:%M')), if type == 1: period_list = ['6 hours', '24 hours'] else: period_list = ['6 hours', '24 hours', '7 days', '30 days', '90 days'] for period in period_list: # plt.xkcd() tt, day, hour, balanceI, solarI, boatI, auxV, panelV, startV, battV, temp0, AhSolar, AhConsumed, AhAux = np.genfromtxt('data.csv', delimiter = ',', unpack = True, usecols=(0,4,5,7,8,9,11,12,13,14,15,20,21,22)) tnow = time.time() if period == '6 hours': tlimit = tnow - (60 * 60 * 6) if period == '24 hours': tlimit = tnow - (60 * 60 * 24) elif period == '7 days': tlimit = tnow - (60 * 60 * 24 * 7) elif period == '30 days': tlimit = tnow - (60 * 60 * 24 * 30) elif period == '90 days': tlimit = tnow - (60 * 60 * 24 * 90) # mpl.rcParams['font.weight'] = 500 # Sets heading and legends only mpl.rcParams['text.color'] = '#ff9900' mpl.rcParams['axes.edgecolor'] = 'red' fig = plt.figure(figsize=(8,20)) ax2 = fig.add_subplot(5,1,1, axisbg='black') plt.title("MASTER SYSTEMS DISPLAY", fontproperties=prop) plt.plot(tt, solarI, label='Solar', color='blue') if (tnow - tlimit) < (60 * 60 * 24 * 7): plt.plot(tt, boatI, label='Consumed', color='green') ## plt.plot(tt, balanceI, label='Aux', color='deepskyblue') legend = ax2.legend(loc='best', prop={'size':11}) # frame = legend.get_frame() # frame.set_facecolor('black') # frame.set_edgecolor('red') plt.legend(prop=prop, framealpha=0, loc='best') plt.grid(color='red') plt.ylabel('Current (A)', color='#ff9900', fontproperties=prop) setp(ax2.get_xticklabels(), visible=False) setp(ax2.get_yticklabels(), color='#ff9900', fontproperties=prop) plt.gca().get_xaxis().get_major_formatter().set_useOffset(False)# remove sci notation ax2.ticklabel_format(style='plain', axis='x') ax2.set_xlim(tlimit, tnow) ax2.set_ylim(0, 20) ax1 = fig.add_subplot(5,1,2, axisbg='black') plt.plot(tt, battV, label='Domestic', color='red') if (tnow - tlimit) < (60 * 60 * 24 * 7): plt.plot(tt, startV, label='Starter', color='darkorange') plt.plot(tt, auxV, label='Aux', color='#c12283') legend = ax1.legend(loc='best', prop={'size':11}) plt.legend(prop=prop, framealpha=0, loc='best') plt.grid(color='red') plt.ylabel('Battery Voltage (V)', color='#ff9900', fontproperties=prop) setp(ax1.get_xticklabels(), visible=False) setp(ax1.get_yticklabels(), color='#ff9900', fontproperties=prop) plt.gca().get_xaxis().get_major_formatter().set_useOffset(False)# remove sci notation ax1.ticklabel_format(style='plain', axis='x') ax1.set_xlim(tlimit, tnow) ax1.set_ylim(10,15) if period == '6 hours' or period == '24 hours': yy = 20 if AhSolar[-1] > yy: yy = AhSolar[-1] if AhConsumed[-1] > yy: yy = AhConsumed[-1] ## if AhAux[-1] > yy: ## yy = AhAux[-1] yy = yy + 20 else: yy = 160 ax5 = fig.add_subplot(5,1,3, axisbg='black') plt.plot(tt, AhSolar, label='Solar', color='blue') #if (tnow - tlimit) < (60 * 60 * 24 * 7): plt.plot(tt, AhConsumed, label='Consumed', color='green') ## plt.plot(tt, AhAux, label='Aux', color='deepskyblue') legend = ax5.legend(loc='best', prop={'size':11}) # frame = legend.get_frame() # frame.set_facecolor('black') # frame.set_edgecolor('red') plt.legend(prop=prop, framealpha=0, loc='best') plt.grid(color='red') plt.ylabel('Daily Charge (Ah)', color='#ff9900', fontproperties=prop) setp(ax5.get_xticklabels(), visible=False) setp(ax5.get_yticklabels(), color='#ff9900', fontproperties=prop) plt.gca().get_xaxis().get_major_formatter().set_useOffset(False)# remove sci notation ax5.ticklabel_format(style='plain', axis='x') ax5.set_xlim(tlimit, tnow) ax5.set_ylim(0, yy) ax3 = fig.add_subplot(5,1,4, axisbg='black') plt.grid() plt.plot(tt, temp0, color='#9898ff') plt.grid(color='red') plt.ylabel(u'Temp (\u00B0C)', color='#ff9900', fontproperties=prop) # \u00B0 = degree symbol setp(ax3.get_xticklabels(), visible=False) setp(ax3.get_yticklabels(), color='#ff9900', fontproperties=prop) plt.gca().get_xaxis().get_major_formatter().set_useOffset(False)# remove sci notation ax3.ticklabel_format(style='plain', axis='x') ax3.set_xlim(tlimit, tnow) # x = [tlimit, tnow] # ax3.xaxis.set_ticks(x) ax4 = fig.add_subplot(5,1,5, axisbg='black') plt.grid() plt.plot(tt, panelV, color='#ffcc66') # ax4.fill_between(tt, panelV, color='#ffcc66') plt.grid(color='red') plt.ylabel('Panel Voltage (V)', color='#ff9900', fontproperties=prop) plt.xlabel(tday + '. ' + period + ' to ' + thour, color='#ff9900', fontproperties=prop) setp(ax4.get_xticklabels(), visible=False) setp(ax4.get_yticklabels(), color='#ff9900', fontproperties=prop) plt.gca().get_xaxis().get_major_formatter().set_useOffset(False)# remove sci notation ax4.ticklabel_format(style='plain', axis='x') ax4.set_xlim(tlimit, tnow) #plt.show() plt.tight_layout() savefig(period+'.png', facecolor='black') plt.close(fig) # close figure to save memory print '.', print 'done' # graph(1) # Initial run ##########Set up ftp upload ####################### def upload(ftp, file): ext = os.path.splitext(file)[1] if ext in (".txt", ".htm", ".html"): ftp.storlines("STOR " + file, open(file)) else: ftp.storbinary("STOR " + file, open(file, "rb"), 1024) ######################## FTP #################### ftp_server = " " ftp_name = " " ftp_pwd = " " def do_upload(type): print 'Uploading ',str(time.strftime('%H:%M')), try: ftp = ftplib.FTP(ftp_server) if ftp_out == 2: ftp.set_debuglevel(1) else: ftp.set_debuglevel(0) ftp.login(ftp_name, ftp_pwd) if type > 1: upload(ftp, "90 days.png"); print '.', upload(ftp, "30 days.png"); print '.', upload(ftp, "7 days.png"); print '.', log('ALIENS DETECTED '+str(time.strftime('%H:%M'))) upload(ftp, "24 hours.png"); print '.', upload(ftp, "6 hours.png"); print '.', upload(ftp, "is.txt"); print '.', upload(ftp, "ic.txt"); print '.', upload(ftp, "vb.txt"); print '.', upload(ftp, "time.txt"); print '.', upload(ftp, "log.txt"); print '.', ## #read the TEMPERATURE file ## tempC = int(open('/sys/class/thermal/thermal_zone0/temp').read()) / 1e3 ## #print tempC ## ## temp_string = '<p>uploaded: '+str(time.asctime())+ \ ## '</p><p>Pi temperature: ' + '%.1f' % tempC + '°C</p>' ## #print temp_string ## f = open('ships_computer.txt', 'w') ## f.write(temp_string) ## f.close() ## ## ## upload(ftp, "ships_computer.txt") ftp.quit() print 'done' except IOError as e: temp_string = 'FTP failed: '+str(time.asctime()) print temp_string print "I/O error({0}): {1}".format(e.errno, e.strerror) time.sleep(2) # Wait a bit for FTP to sort itself out print "Resuming..." ##if ftp_out > 0: ## do_upload(2) # Initial run ###################### Fridge Control ########### def fridge(): data7 = read_spi(7) * 0.0367 # Update Boat V if data7 > 13.3: # Boat batt OK if GPIO.input(25) == 0: # Check if already on bell(2) relay_on(25) print'' print'Fridge on ',str(time.strftime('%H:%M')) log('Fridge on '+str(time.strftime('%H:%M'))) if data2 > (data0 + data1 + 1.0): # fridge off: Balance I + Boat I > Solar I data7 = read_spi(7) * 0.0367 # Update Boat V if data7 < 13.25: # Check if engine running if GPIO.input(25) == 1: bell(4) relay_off(25) print'' print'Fridge off ',str(time.strftime('%H:%M')) log('Fridge off '+str(time.strftime('%H:%M'))) ###################### Bell ##################### def bell(ting): for i in range (0,ting): relay_on(23) time.sleep(0.2) relay_off(23) time.sleep(0.2) time.sleep(3) ###################### Aux Control ########### def aux(): # global data0, data1, data2, data3, data4, data5, data6, data7 data4 = read_spi(4) * 0.0365 # Aux batt data7 = read_spi(7) * 0.0367 # Boat Batt data2 = (read_spi(2) - 491.5) * 0.074 # Boat I ## print data4, data7, data2 if GPIO.input(24) == 1: # Check if on if data2 < 2: # Boat I low bell(1) relay_off(24) print'Aux off ',str(time.strftime('%H:%M')),' Boat current < 2A' log('Boat I low '+str(time.strftime('%H:%M'))) if GPIO.input(24) == 1: # Check if on if data4 < 11.6: # Aux bat low bell(1) relay_off(24) print'Aux off ',str(time.strftime('%H:%M')),' Aux batt < 11.6' log('Aux low '+str(time.strftime('%H:%M'))) if GPIO.input(24) == 1: # Check if on if data7 > 13.0: # Boat bat high bell(1) relay_off(24) print'Aux off ',str(time.strftime('%H:%M')),' Boat batt > 13.0V' log('Main batt high '+str(time.strftime('%H:%M'))) data4 = read_spi(4) * 0.0365 # Aux batt data7 = read_spi(7) * 0.0367 # Boat Batt data2 = (read_spi(2) - 491.5) * 0.074 # Boat I ## print data4, data7, data2 if GPIO.input(24) == 0: # Check if off if data7 < 12.6: # Boat Batt low if data4 > 12.4: # Aux batt OK if data2 > 2: # Boat current bell(3) relay_on(24) print'' print'Aux on ',str(time.strftime('%H:%M')) log('Aux on '+str(time.strftime('%H:%M'))) aux() # Initial run ###################### MAIN LOOP ################ try: while True: # Loop indefinitely if int(time.time()) > time_get_data + period_get_data: # Get data time_get_data = int(time.time()) get_data() if int(time.time()) > time_graph2 + period_graph2: # Do more graphs time_graph2 = int(time.time()) graph(2) if ftp_out > 0: do_upload(2) elif int(time.time()) > time_graph1 + period_graph1: # Do fewer graphs time_graph1 = int(time.time()) graph(1) if ftp_out > 0: do_upload(1) if int(time.time()) > time_fridge + period_fridge: # Fridge control time_fridge = int(time.time()) fridge() if int(time.time()) > time_aux + period_aux: # Aux control time_aux = int(time.time()) aux() GPIO.output(17,GPIO.LOW) # Turn LED off while sleeping, time.sleep(TimeSleep) GPIO.output(17,GPIO.HIGH) # on while working except KeyboardInterrupt: spi.close() GPIO.cleanup()
http://www.savethebarrowline.com/ Waterways Ireland have indicated that they plan to replace the existing grassy surface with mix of surfaces types including bound hard surface, an unbound mix of stones and crushed limestone (currently in place north of the bridge in Tinnahinch) and reinforced grass (grass sown through a plastic mesh)
Quoted from <http://blog.iharder.net/2011/04/15/kalmyk-can-the-kalmyk-unseat-the-bowline-as-king-of-knots/> I am reading the book “On the Trail of Genghis Khan” by Tim Cope. He traveled for 3 years on horseback from Mongolia to Hungary. On page 437 he mentions a knot he describes as a reverse bowline. On his very first night he was taught this knot by a Mongolian herder. As he traveled across the Eurasian Steppe he found the same knot but with the name of the peoples who lived in the area. A Kazakh knot in Kazakhstan, Kalmyk knot for the Kalmyk people, and in Hungary it was called a Cumanian knot. He used this knot for everything So possibly not a Cumberland but a Cumanian knot??
The instructions claim that the pump can be up to 10ft higher than the inlet and still self-prime. m@
Magnets - a 60mm bracket one side and bolted direct the other side gives enough tilt to run the water off. m@
They are for playing dominoes on.
Swinton Insurance brokers managed to find me an insurer who was happy to cover the car kept at a different address. There were a lot of insurers who wouldn't. The policy is with AXA Insurance UK m@
What Length of Ropes and is there a best type
Mat B replied to DandGNWales's topic in New to Boating?
Can do exactly the same with a bow rope.
