richardf
About richardf
  • Birthday 25/02/1959
  • Occupation
    Retired
6,256 profile views
richardf's Achievements
Proficient
Proficient (7/12)
5
  1. richardf
    Kelvin P4R
    I feel your pain! We bought a boat with P4 in - it smoked like no other engine I have ever had, then I bought a reconditioned engine that was probably worse than the first one. Eventually I gave up and we put a Perkins AD3 in its place and that was a huge improvement. The P4 has a bad reputation, certainly in narrowboats, maybe they just don't get hot enough. I think you would be better just getting rid of it. Spares are very few and far between, especially for the gear box where they have often rotted out due to sea water causing corrosion of the cooling jacket. Interesting that you say it runs like 'crap' - mine always started well and sounded nice - it just laid a smoke screen down wherever we went. Actually thinking about it, it did coke up the heads with monotonous regularity! Get rid,
  2. Lets hope that this one actually works at the end of the project - despite paying many thousands of pounds to get the hydraulics right to enable the bridge at The Ocean to actually swing - they eventually gave up.
  3. I used to moor next to a Quercus on the River Wey - pretty sure it wasn't a Brumtug, although I do believe it had been lengthened
  5. I had a Wilsons sofa bed reupholstered in leather by them a few years ago - didn't seem a problem
  6. My recommendation would be John Sanderson at Dadford Wharf http://www.narrowboatpainting.co.uk/Pages/default.aspx 5 years on and our boat still looks great following a back to bare metal repaint
  7. Has anyone else been wondering about the state of the hull? Did he actually check that before starting the work? What caused the sinking originally?
  8. Have you thought about CT1 sealant (http://www.ct1ltd.com/en/ct1.html) - its awesome stuff! It will seal even as it is leaking
  9. Or half closed, so there is enough over time to fill the filters up, but not enough to keep them from emptying when under load. I have known that
  10. I think I know the noise you mean - we always call it 'singing'. You can often hear it on craft coming past when you are moored up. Ours seems to do it sporadically and it seems to be linked to shallower canals somehow. Its definitely not cavitation as in our case as the counter is well underwater and we don't rev that high - although it gets worse at higher speed It used to drive me mad, but I ignore it these days!
  11. I had this problem a while ago, in the end we managed to source a new replacement (for a Perkins) - but prior to this I did speak to R N Diesels in Wolverhampton and they confirmed that they could get one made up
  12. There are a lot of boats being overplated these days - how does this get carried out without causing cooling issues - anybody know?
  13. I've seen a surveyor use a self tapper and rawlplug
  14. Has this one been posted before - Ling? http://narrowboats.apolloduck.co.uk/feature.phtml?id=432372
