arlow11
Everything posted by arlow11
  1. i have just won this boat on ebay, https://www.ebay.co.uk/itm/Springer-narrowboat-26ft-/273387230756?ul_noapp=true&nma=true&si=4ZF0op1V62mIrazdbQmU05863C8%3D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557 im concerned that i may get ripped off, i have been and left a deposit,and from the outside the hull ect looks solid,theres a few holes on the back deck but heres the story,it was some guy who was doing it up gave up,sold it to the ebayers dad where its stood for 10 years, he bought it off his dad and has spent 6 months working on it, but he know nothing about boats not even what everything called,but if its stolen surley you would steal a nicer boat,but my main issue is he has an old survey from when his dad acquired it ,its clearly says its a cruiser stern,and it looks semi trad to me,any thoughts
  2. my gunwhales are full of foam and metal i could posibly get a fixing on the one side to a batton,but how can i make a secure fixing for water and gas ect? thanks
  3. not 100 persent what to do think the 6mm will possibly be a little much for selftappers or maybe not? I do have a tap and die set but its draper and has only one tap per size so i think its for re cutting the worse senario is a snapped tap right at the bottom said bottom think i might buy a set from julynians link still theres no room for swingin so will have to be in the cordless thanks guys..........and bones also many more questions like gas pipe how is this normally done is it ok to cut holes on the gas locker some sort of protective gromit through the hull with copper pipe into the galley into hob and cooker using the least amount of fittings,with a gas tap on the pointy end so i can isolate so i dont blow up (i do have some gas and plumbing experience)are solderd fitings more risky due to vibration? thanks
  4. hi all i want to screw down my water tank filling thing my boat has fine long screws to screw down the mushroom vents where do i get these? thanks
  5. have to say people moaning about dog poo caused this problem,people should be encouraged to chuck the poo in the hedge,or chuck the dog in the canal,or just crap every where..........
  6. i have a few fit out questions,my diesel tank currently has 10 litres of fuel in it as i leave it in a rural location and have no locking cap,but judging by the ammout of water from condensation in the water tank i must presume,i have some in the diesel there is a seperator on the engine but how much can this remove and do i have to drain it? Also where in birmingham can i get quality faced ply thanks
  7. scary my boats just arround the bend from there,and have to say i saw a similar coloured boat just outside whittington 2 weekends ago just before the sunken boat hope its just overdue and just left somewhere
  9. so cute it doesnt look real,bet its a bugger gettin the batterys in
  10. hellooo, Iam awating completion of my sailaway and am looking for stuff as you do ,iam considering a 24 volt electics to save on cable are these batteries on ebay as good as they sound, and how would i check if there ok? thanks http://cgi.ebay.co.uk/12VOLT-76-APH-SEALED...A1%7C240%3A1318
  11. ureka i think i have it.....................simply over plate the whole side with 3mm and weld ???????? would this work ?there would be minimal distorsion and heat might take some patching inside
  12. look on ebay they did have a mesh insert like for a sink but simply will not allow a hose down the tanks hole,you could silicone it in to reduce the chance of stuff falling in the tank
  14. in the spec its lists power cut out time 17 hours ,does this mean it will be ok with no power for 17 hours,?? ie if i used a generator when i got home for say four hours would it get down to temp then i could leave it over night and the following day and return and do the same again ice cream would me nice? thanks
  15. arlow11
    Disaster
    you could mark your nuts ie a drop of paint at 12 oclock,not the time..........although doing it at 12 could balance the chi
  18. i have a drainer in my house next to the sink there is no trap and any water left in the pipe goes smelly and takes lots of bleach to stop
  19. what you need is a Canon MP460 All-In-One Photo Printer they are fifty pounds in argos, http://www.argos.co.uk/static/Product/part...t%3EPRINTER.htm but i have one new in the box for 25 with recept if youre near birmingham
  20. think soda blasting is the way to go think you can leave it hours before you need to paint it,as the soda has some protective properties.......google
  23. think it would be easyer to get the builder to paint it round the windows,sure its wouldnt cost that much,and iam sure they dont just screw out ether,or ask the builder to fox them temp until you paint?
  24. arlow11
    Old Age
    so in a nut shell.........dont sell the house rent it out..............but do what youve gotta do as you could drop dead at any time
