Tony Fuller
    Suffolk
  • Occupation
    Engineer
  • Boat Name
    Tamsin
  • Boat Location
    Crick
2,402 profile views
Tony Fuller's Achievements
Engager
Engager (3/12)
0
  1. After years of smelly pump out tanks I finally found the cause. It is a build up of semi solid effluent on the bottom of the tank, this is left after each pump out as the outlet hose does not reach the bottom. This sludge is anaerobic & causes the smellIt can build up if the boat has been left for some time with 'content' in the tank. I solved the problem by making up a length of 15mm copper pipe with a 90 degree bend & jet on the bottom & a hose fitting on the top, connected to an outside tap. After pump out, pause the machine & insert the pipe via the 'eyeball' flap. Turn on the tap & 'pressure wash' the inside of the tank, this will loosen all the solid sludge & will be pumped out upon restarting the pump out machine. In bad cases it may need a further squirting with a second pump out. If you repeat this procedure maybe a couple of times a year it will remove all of the 'sludge' & cure the 'bad smells'. Tony
  2. It may be OK on an older heavy transformer based battery charger, but I don't think that the modern 'multistage' electronic chargers are going to like the waveform & the unregulated voltage supply
  3. I bought one of these a couple of years ago. They are cheap mass produces Chinese generators. They are just an engine driving a 3 phase alternator. There is no regulation of the Power Supply, so the Voltage will be 'all over the place' depending upon the 'load'coupled up to the machine. Will work OK with a Welder or Power Drill but not good to run, Boat battery Chargers, TV's or charging Phones or other sensitive equipment. Use with Care!!! Tony
  4. Hi Neil, Yes, I suspect that is what many of the 'boat builders' do & probably get their local Blacksmith to make them up in batches. My hinge definitely has a 'blacksmith' look about it & as I said before the curved bit if the hinge did look a bit thin & maybe 'over hammered'. I will have a word with Tim Tyler, he may have these available 'off the shelf'. Thanks Tony
  5. Hello Cheshire Cat, I think I can just beat you, our Tim Tyler shell is 21 years old this year. Built in 'the black hole of Calcutta (as it was called locally) ' in Hixton. I suppose that I can't really complain at the locker hinge rusty through after all this time, I suppose I should have oiled or greased the hinges more often!!! I will make contact with Tim & see what he has to say, he will probably want measurements or a drawing as I don't think accurate build records were kept in those days. I am too busy to visit the Boat at the moment so when I do I will take some pics & measurements so that he can see what we have. Thanks Tony
  6. Hi Larry, I tried drilling & Tapping new threads & fitting a new smaller hinge on top (Message 5). Unfortunately the new hinge had a different 'arc of travel' to the unbroken one & the hatch lid jammed about half way open. I could cut through the good one & fit a 'piggyback' hinge each side but with the different hinge pivot point (raised up by maybe 8mm) I am afraid that the hatch might jam (2inch drop on the sides all round & very snug fitting) as I feel that position of the hinge pivot point may be critical to obtain the correct arc of movement of the hatch lid for smooth operation. If I cut through the good hinge & the piggyback hinges don't work then I will find myself a bit stymied. I can wiggle it open on one hinge at the moment & don't want to 'burn my bridges' Also the piggyback hinges will look a bit of a 'bodged job'. This is why I am trying to find some new matching hinges. Thanks Tony
  7. Hi David, Welding is not the problem, as a retired engineer I can weld (or rather I can stick two pieces of metal together) & I have a reasonable mig welder. What I think you are actually saying is that you don't believe that the locker hinge is a 'bought in' item, but fabricated on site from two pieces of fancy metal with a butt hinge centre piece. You may well be right but from the general appearance of the hinge it appears to have a 'blacksmiths forge' type of hammered over hinge joint, with little actual engineering, the hinge metal looks quite thin (over hammered) which is why it has rusted away. I suppose the only way to really find out is for me to ask Tim Tyler. Thanks for your help. Tony
  8. Hi David, That is actually a good idea, but it would be fine for a steel door & doorpost, my problem is that the hinge section is integral, ie part of the hinge goes to the top section & part to the bottom section. Similar to the left hand hinge if you arrow down in their catalogue. I did try just screwing a smaller hinge over the broken section but due to the different arc's of travel it jammed up & didn't work. Tony
  9. Hi David, Yes, your photo shows the type of hinge, but mine has the 'ornate bit' top & bottom. You would think that Welding would be the answer, but the break is in the actual hinge part itself, it is actually underneath & quite difficult to get at to weld (its actually rusted through so not a lot left to weld on to). So probably means 'grinding off' the complete hinge but if going to all this trouble would be easier to fit a replacement rather than trying to bodge up the rusty one. I was hoping that someone knew where these were available off the shelf or had done this themselves. Tony
  10. Hi, I have broken one of the 'weld on' hinges on the Hatch Lid of the Bow Locker (Tim Tyler Shell). I suspect I will need to replace these as a pair, as getting a match may be difficult. I can't find any online so maybe these are a 'shell builders special'. I think these are welded on but each has 3 'dummy? Rivets top & bottom. Any Ideas how to replace these, anyone done this job. Thanks Tony
  11. For really tarnished brass (whatever polish you use) rub it on using extra fine wire wool. It will tend to make very fine scratches in the brass, but after the tarnish is removed, just polish as normal & the fine scratches will disappear!
  12. Hi Bigcol If the wire has melted near a terminal it would seem that the terminal screw had not been tightened sufficiently or worked loose. This would cause local 'arcing' & overheating & lead to the problems you have observed. If you have enough spare loose cable then re make the connection using a bootlace terminal as recommended. Do check that the screw terminal is not damaged also, as if so it may need replacing also. Tony
  13. Is the Glow Plug working, carefully feel the outside of the Glowplug housing to see if it is hot!! If not, unscrew the terminal nut on top of the glow plug, remove wires & unscrew glow plug from housing. Check glow plug, if they fail then it is usually a broken heater wire. Obtain another correct model glow plug & refit. Tony
  14. When selecting battery cable sizes don't forget about 'heat'. Battery cables do tend to get very hot when passing high charging currents. I have 90mm cables feeding into twin battery banks & they will burn your hands after passing 130 amps for half an hour. So apart from the voltage drop question, the bigger the better. I used multi strand welding cable for battery wiring, it is easy to use & bends nicely. Tony
  15. HI with the NOBELS Bow Thruster, the motor drives a cog wheel & chain ( which is inside the square metal box in the picture) The Propellor is connected to a short shaft with a cog on one end driven by the chain Where the shaft exits the box there is a bearing & a water sealing ring. When you take the top off the box you will see the two cogs & the drive chain, the box should have a bit of grease in it but NO Water. Try running the bow thruster with the top off the box. If it fills up with water then the bearing/seal will need replacing. Unfortunately this is a 'dry dock job' as I don't think that you can replace the seal without filling the boat with water. I have Nobels (Dutch) contact details somewhere if you need to order spare parts. Tony
