macc
Everything posted by macc
  1. Cheers for info think I`ll be swapping out the Euro 2 pin for UK socket and doing the same.
  2. MominPapa was your Xantrex 1800i one of the models that had the Euro type mains outlet on it where on the inverter did you neutral bond it cheers.
  3. I would wait till 1st September and then you can have 6 month license as a new owner of the boat even if they caught you without a licence you would have 28 days to pay speak to your insurance company explain the situation that you are taking the boat to your home mooring without a licence till 1st September they are normally good.
  4. but the question was asked on a canal forum
  5. I carry spares on my boat for routine maintenance ie filters alternator belts spare alternator would I call them to replace an alternator belt no I would not, this is a part that has failed and like your starter motor is covered in their t & c, like your starter motor would you be happy if your starter motor failed and they told you its not covered due to age wear and tear,they also told me that if its the rubber seals in the injection pump its not covered yet as in their T & c it states rubber seals that require routine wear and tear replacement are not covered yet this rubber seal is not something that you would replace on a regular interval or servicing.
  6. this would have been easy for me to fix but I have heart disease and i`m under Papworth again so look like more stents time I also have to look after wife who is a paraplegic.
  7. diesel is getting into sump and leaking from top of pump don`t want to risk over run.
  8. I`m more concerned about an item that is covered in their parts replacement not being covered due to age and the say gaskets or rubber seals are not covered yet I can`t see anything in the T & C about this , to me if the say they will not pay due to age wear and tear then not unless the engine or parts are new then they won`t.
  9. ok what do you all think to this estimate. the fuel leak is from one of the injection pumps engine is a Isuzu 38. Dear Mr James Maccuaig, Please find below details of the work required. Job Number: 104392 Member Code: Craft Name: Supplier: 210642 Still Game RCR Details: fuel leak from the injectors from the bolts. Pictures below. Notes: Following on form your conversation with the engineer in the office, we have prepared and estimate to undertake the work to remove your injection pump and send to specialist for investigation. If the issue is due 'a unforeseen mechanical failure' then these costs will be covered by your RCR membership with just a £50 excess, and even if we find a broken spring or washer this will activate the claim. However as the pump is leaking and their is diesel in your oil there is a chance this is just a seal issue related to age and deterioration. Attend and disconnected pipes and remove injectors and injection pump/s Take for refurb and return and refit fitting new gaskets Bleed system and test This is an estimate so costs can go up or down depending on parts or labour used to complete your job. Any labour time outside of the estimate will be charged at £22.50 per half hour. All parts are charged at RRP. You will only ever pay for parts or labour that are used. Please note that this is a rough estimate based on a typical installation requirements. Item Name Quantity Unit Price Total Price Injection pump/s 1 £450.00 £450.00 Labour & travel over 2 visits 6 £40.00 £240.00 Canal Contracting Charge 1 £50.00 £50.00 Total Cost: £740.00 River Canal Rescue Ltd trading as Canal Contracting Company Registration No: 4126409 VAT Registration No: 823673325
  10. Were have i implied that they have no rules of course they have rules but they will not be the same as cart all i can find is their Commercial vessel registration charges.
  11. but the boat is on ea waters it has nothing to do with cart.
  12. I own Shropshire Lass 1 it was built by stoke boats Longport same as Shropshire lass two ,you could also speak to Dave at Grahams boats Hillmorton he`s built one and is building anther next year.
  13. Are you sure they need re-tightened thought they had stretch bolts.
  14. there is something already on these lines its called a rod licence.
  15. would you realay, is that from personal experience,having had 3 heart attacks before 39 years old fitted with 3 stents and still suffer from unstable angina is not much fun ether it can also be a long painful death for some with no cure.
  16. never tried running a hover or washing machine from a composting toilet does the methane run a generator.
  17. thanks for reply biggles i posted after your post might have to have a re-think.
  18. thanks for replies my have to change my mind to mastervolt, ely chandlers are doing a good price on them was looking at the http://www.ebcmarineandleisure.co.uk/combi-inverter-and-charger/mastervolt-mass-combi-12v/2000w-100a but is 2000w 2000w or 2000va.
  19. looking at buying a sterling pro-s 2500w combi or would i be better spending my money on a mastervolt or victron. cheers jim
  20. you could try daylock or hartford marina near huntingdon
  21. new boat looks good dave like the layout.
  22. my batts from this place http://trojan-batteries-online.co.uk/index.php?main_page=shopping_cart buy four for a discount
