Hi there,
I am in the process of buying a narrow boat, sail away hull. I have been trying to do many calculations to figure out all of the electrics in the boat. Please tell me if i have got any of the following wrong as im finding that i'm a little stuck.
The residential mooring i am planning on using has a 16 amp pylon for a power supply.
I have been looking at an Alde 3020 for the heating system attached to a 40l Calorifier for the hot water. The Alde system uses around 1000w which is around 4.3 amps, the Calorifier has a 1kw heating element in it so that's another 4.3 amps. Would you need to use the heating element or would the alde heat provide enough to heat the water on its own.
I also have been looking at a standard fridge to cut down on the cost. These at their max they are 750w so that's another 3.3 amps. Then with a microwave oven using 1850w in use max so thats 8 amps.
In total that's around 20 amps. That's not including all of the little things in the boat. The main thing i am asking is
a) Has anyone got an alde and does it use less current than my calculations.
2) Would i have to use the heating element to heat the hot water up all the time or is the adle enough.
3) are the pylons at the CRT residential moorings defiantly 16amp
Thankyou in advance. For extra information. I am getting a 50ft Sail-away to live in the centre of Birmingham
