zen rajab
    lattakia, syria
  • Occupation
    architectural engineer
zen rajab's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. This is the specs pdf mitsubishi_brochure.pdf
  2. The specs pdf does not mention watts or horsepower
  3. I looked it up It is a 16200 btu mitsubishi split a/c unit With a minimum ampacity of 16 amps
  4. Depending on your experience is it capable to run a 3ton split air conditioner?
  5. I used the rev counter on the fly wheel end of the shaft (The coupling between the alternator and the engine is exposed and not covered or protected by a cover or any thing)
  6. I am using a 12kw synchronous alternator close-coupled to the engine but never load it more than 30 amps
  7. That did the trick Thank you very much for your help I owe you bigtime guys
  8. I have made the slot cut in the rod But i have noticed that the rod when revolved comes out and when thightening the inner nut the rod is not moving in or out the casing
  9. So please give me the short version of what to do to fix the problem
  10. I have loosened the nuts and rotated the thread by hand clockwise and anti-clockwise but nothing happened it just kept on turning
  11. could i just grab it with a lock pliers?
  12. I have checked the control rod and it has no screw driver slot cut in it
  13. i did use a rev counter and the reading was 1412 rpm OFFLOAD and at 50% load the reading was 1386 rpm
  14. My lister is sr2 twin cylinder I am using it with a generator that is 1500 rpm but apperantly the engine is set to 1000 rpm
  15. Can any one please instruct me through increasing the rpm of my lister sr2 engine
