Days Won
3
Everything posted by Hudds Lad
Trent & Mersey Bridge 16 Swarkestone or thereabouts
Hudds Lad replied to Cheshire cat's topic in Stoppages
Wonder if they got the driver? It's incidents like this that make CRT's idea of bridge cameras seem worthwhile. -
@robtheplod I've been bitten by this, if they look corroded consider replacing with new screws and add Copaslip or similar. My efforts to remove the last remaining screw with a sheared off head resulted in a split mounting hole so couldn't drill and tap. Cost me a new door in the end I'll now check them every year and for the sake of a few pence i'll probably replace the screws each time.
Fair enough, just wanted to make sure you weren't being put off doing it by thinking it was too tricky (your mention of lack of skills and tools).
Ouch, £1100 a year to get to your property
If you can pass the cables outside easily through a mushroom vent or similar all it requires is the ability to use a screwdriver to tighten it's clamp onto a suitable pole (we use a short mag mount one on the roof). Guess it depends on your perception of neat and tidy. The cables themselves just screw on so no special tools required. There's a fair length of cable attached, ours passes through a vent into the well deck void where the water tank is then into the cupboard by the doors, so all excess length is coiled in the void.
You could substitute the white or brown mushrooms for Liberty Caps, no slicing required, and makes for an interesting after dinner experience If i was using white mushrooms from the supermarket i'd add them at the last stage of cooking otherwise they'd turn to mush, don't know if they use a different variety these days but they just have no substance like a good chestnut mushroom does.
You can unscrew the stubby aerials and connect an external one, you may need new adapters though as they will be SMA-Female on the back of the router. You'll need to connect to the router with a laptop/tablet/phone to switch the setting to external aerial too for best results (connect to wifi, type 192.168.1.1 in a browser window). Don't think the Huawei app gives you that much control if memory serves. I have the same router paired with an external Poynting aerial.
That's why legal types get paid the big bucks, to sit and come up with guff like that. Admittedly i've only just finished my coffee, but it took two read throughs of that to understand what it was saying, or perhaps i'm just thick
Usually text-to-speech has a slightly posh middle england accent, never heard a Brummy one before. Even if it was, it's not the usual style of wrong intonation you get with a script/AI voice. Very odd.
Well, its not wrong. Very strange voiceover, oddly emphasised.
Subscription items that can be locked and unlocked by Elon. Oh, you didn't renew your navigation package? No steering for you.
If he's based at Dunchurch, i'd guess it's New & Used Boat Co. as they operate from there
The grant received from the Millenium Commission was £12,840,000, they originally offered £15,000,000 but English Partnerships whittled this down. Total estimated cost of the restoration since the formation of the Huddersfield Canal Society in 1974 was £45,000,000 (incidentally the Society is 50yrs old today!!).
A slower speed on the router then maybe? Might have a look for a bit and have a test.
Being a much-maligned marina moorer, ours get a lot of weather Lost one to one of the storms in the marina last year, vanished like an old oak table, fender and all. Then J snapped one last year using it to pull the boat in for some reason (she did once pull an oven door off too, doesn't know her own strength).
Is HDPE easy to work? Can it be machined easily or does it melt? Only ask as the hangers i made are starting to delaminate after two years of service despite being well painted and i was thinking of using a different material once the spares have been used up. Pics for reference, i know the one showing how they tie-on isn't the best but it's all i could find.
I fettled a longer one for the shareboat as a few of us wanted it long enough to stand inside the doors. This assumes you still have the old one to measure from. I measured the original tiller bar for first hole and drilled a pilot hole then enlarged it (don't go too big too soon, i tried to jump from pilot hole to full size bit in one go and it kept grabbing the bit, step up in sizes or get one of those conical step drill bits). I also made a U-shaped box to hold the tiller bar in whilst i drilled to keep it straight as i didn't have access to a vice when on the boat, wedged in with some shims to stop it rotating. Once i had the first hole done, I placed in situ and aligned using the tiller pin, then drilled the next pilot hole straight through whilst on the bar, then continued to enlarge to correct size. The hardest part was getting the new handle in the new bar, both came from Midland Chandlers and were allegedly the correct size. Even after copious sanding the fit was so tight i didn't need to use the wedge. That handle is never coming off, ever Pretty much as @ditchcrawler has said above. I also had to make a new step-side bracket to hold both the old and new tiller bar as some owners wanted it as was, but that's another story and the joy of shared ownership
Draining Rads with a Webasto Top Evo system.
Hudds Lad replied to -Cookie-'s topic in Boat Equipment
I'd deffo look for a valve, we had the opposite problem with our MV Hydro 5-S where we got hot water but rads were stone cold. Turned out to be a closed valve that we didn't notice as the big red wheel had been removed -
They do flollop and vollue beautifully when the mating rituals are in effect, although the mournful globbering of those that don't find a mate can bring a tear to the eye
Surely at that point Sod's Law comes into play?
Possibly refused planning due to all the blue Pagoda's, willow tree planting and little bridges you can't get a boat under
Because most of the "stories" are skimmed from Facebook groups these days, and written by trainee "journalists" in an office in Manchester. Not worth wrapping yer chips in now.
https://www.examinerlive.co.uk/news/west-yorkshire-news/police-cordon-slaithwaite-live-cops-28983123 From what i gather from the local Facebook groups, a boater with mental health and drink issues has attacked another boater with an axe Apologies for the Reach Group link
Yes, as i could see Tufty and his mates in the branches above me. Bingley squirrels are obviously not as sophisticated as the ones in Huddersfield. Our frequent visitors at home, Squizzy Rascal and Nicholas Twitchell, come and tap on the living room window when they want some food
