Stuart Davies
Stuart Davies last won the day on March 28 2017
Stuart Davies had the most liked content!
    Bristol
898 profile views
Stuart Davies's Achievements
Explorer
Explorer (2/12)
37
  2. Did you used to have a boat called Rivendell?
  4. ok. 1. whereas msw inverters don't play nicely with transformer based power supplies, because of the harmonics, they are generally fine with the switched mode ones that drive modern electronics ( as alan says ) 2. no-one is going to measure the current on the 230V side of an inverter unless they have a specific goal and the knowledge to match and even then what's the point? no electronic device (especially a tv) uses a constant amount of power so you're as well reading the sticky label. 3. i intensely dislike posts with categoric statements about things they know little about and even less how to explain them properly.
  5. fine. no skin off my nose.
  6. I wouldn't expect Alan to understand this. It's not like he actually read the thread. There is so much wrong with this post that it's best just ignored.
  7. why would you leave an inverter on standby?
