Don't ask me why yet. That'll come later, but I am trying to find out who's on the board. I've tried here but veryone seems to have resigned except Edward John Helps. And had a look here as well but that doesn't have a lot to do with ABC.
Is Mr Helps the person in charge or is ABC collapsing in a heap?
Does anyone have any information?
Nick
That, to me as an ex physics teacher, looks all wrong. Iron does not concentrate current. It has a higher resistivity than copper or aluminium but the current will be distributed through iron in the same way as through other metals.
Hm...
I had ignored the skin effect. Thanks all. As said, more research required.
N
I have been cogitating on the idea of an induction hob on the boat. We have recently bought a new cooker for our house kitchen with an induction hob for the house and have fund it completely excellent.
I have looked up the literature on how they work and all the articles say that they work by the induction of eddy currents in the base of the pan. If this is the case they should work perfectly well with any metal pan. This is not the case. They don't work with thick or thin ground based or otherwise aluminium pans. AFAICT they only work with ferro-magnetic based pans. We have one or two cast le Creuset pans and they work perfectly. The new ones that we bought are, presumeably, a ferro-magnetic stainless steel.
This indicates to me that eddy currents pay little part in the heating. It also indicates that a more likely heating effect is by the repeated magnetic cycling giving rise to hysteresis "losses". When we use our new pans on our induction hob they make sometimes make a low buzzing noise as the coils in the cooker are energised.
I would be really interested to hear other people's views on this.
Nick
Sorry to be really late replying, Tony
The bearing is really loose. There's lots of lateral play, but, and this I don't understand, it's not leaking around the bearing. Very strange.
Nick
I'm going to bite and be prepared to be shot down.
We have 50ft chain and 40ft rope. I do wonder if that it really enough on the Severn but I hope that as we approach the weir the water get shallow enought for the anchor to bite.
Having just come up the Severn and the Avon the fact that my cooling water pump has just failed emphasized how important it is to have an anchor ready to be deployed.
We are on the North Stratford now and the engine cooling water pump is defunct but it is a manageable problem. If it had happened on the Severn and we hadn't had the anchor ready it would have been life threatening. On wide rivers like the Severn and the Trent we have the anchor at the front. On these rivers, if you are going downstream there is room to be brought up and swing round head to the current. On narrow rivers like the Avon and the Soar we have the anchor at the stern if going downstream. Not ideal but better than being unable to turn and wedging right across the river with the current trying the capsize us.
I know that this topic has been aired before but I think that it's worth saying again that on a river an anchor is an essential piece of safety equipment and needs to be ready for deployment in an emergency.
I frequently pass boats with the anchor neatly stowed on the roof with nothing attached to it. Even if the crew know exactly where the chain cable and warp is it will take several vital minutes of panicky work to get it ready to deploy.
N
