phantom_iv
1,318 profile views
phantom_iv's Achievements
Collaborator
Collaborator (5/12)
92
  1. Yes this was my understanding as well, LFPs are quite happy to sit at 100%
  2. I found that a gas fridge really struggled to keep things actually cool in summer, but works well in the winter. An electric fridge works well in summer when there's plenty of solar, but struggles in winter unless you run your engine regularly. So I figure the way to go is an electric one, and if you run out of electricity in winter you can always put things you want to keep cool in a box outside when it's probably at fridge temperatures anyway!
  3. I looked at one of these then decided that stolen diesel would be less costly than the inevitable leaks of water into the tank from failure to seal it properly.
  4. Domestic car “chargers” don’t do ac/dc conversion at all (well, apart from some low power stuff to run the electronics) the actual charger that does this is in the vehicle itself, the wall box basically just passes through AC to this. Many of them require their own earth rods installed though, so could be some interesting effects there if it’s very close by / depending on ground conditions. If pulling a full 7kw though the voltage does tend to drop a bit, could an out of spec too low mains voltage be upsetting the boiler? Would seem unlikely that their car would need that much charging though, would think it would be quite intermittent if this were the case (e.g only at night time)
  5. I went there late October (I think), it was clean, comfortable, food was good, prices were reasonable, people were friendly, generally a nice atmosphere. I don't recall what the beer selection was like but I don't remember being disappointed for something to drink. Having tried pretty much all of them I might even go as far as to say it was my favourite pub in Kinver at the time.
  6. The obvious solution to this problem is just to buy a boat.
  7. I have a Bosch 18v cordless strimmer at home and it is a most excellent bit of kit - even folds up for easy storage. I've thought I should take it boating many a time!
  12. Yep, I was right about the bleed bolt as per https://betamarine.co.uk/resources/Operators_Manuals/10-115T-KC-OM/#page=36
  13. These pumps are usually connected by a hose to the bottom of the sump, so even if it's mounted next to the gearbox it might still be connected to the engine sump (probably is). Also, re: the fuel filter - apologies if this is a stupid question but did you undo the bolt in the middle of your first photo when you pressed the manual priming button? I suspect (would check the manual though) that this is probably the bleed screw that you're supposed to vent the air out of when you press the priming button. When you stop getting air and get mostly fuel out of this hole then you're good to go.
  14. Can't really see hydrogen on boats being viable tbh. Some combination of batteries, solar, with charging points and synfuel generators as backup seems to be more likely.
  15. Indeed. If you can't see CRT/others installing electric charging points all over the canals then you have to wonder who's going to install all the hydrogen transportation/filling infrastructure.
