TheBiscuits
TheBiscuits last won the day on July 17
TheBiscuits had the most liked content!
    Not Telling
  • Boat Name
    Good Times
24,410 profile views
TheBiscuits's Achievements
Veteran II
Veteran II (12/12)
7.4k
  2. That's a very good point. Did the flyboats ride a soliton wave that was deliberately created by a different boat behind them, or did they simply not ride the wave? As you say, if they created their own wave it would probably be ahead of them and useless.
  4. But neither of those things is a BSS fail, as long as the generator and the fuel are correctly stored. Ideally in a locker that isn't the gas locker but is built to the same standards with vents etc. A plastic petrol can is fine in the gas locker, a metal generator that could theoretically create a spark isn't. Some people also choose to have a LPG generator that connects via a special fitting to the gas system and that's fine too.
  6. Running a little 40 amp alternator into a mostly charged lead acid battery is pretty much zero load, and as you rightly say is bad for the engine. With big enough alternators and a lithium battery, running in neutral for charging isn't usually a low load on an engine. Dumping 200 Amps at 14.4 Volts is delivering just under 3 kW of electrical power, so around 4 horsepower - not accounting for inefficiencies in the input power. That's more power than you'd use for passing a line of boats while cruising, and nobody claims that's bad for an engine.
  7. And that's why you will continue to receive possibly more advice than you would like on here. It's a very pleasant change from the all too frequent sulking some posters do if they get sound advice from experienced boaters but not the answer they wanted. Asking for clarification or more details is fine, ranting at the forum members who are giving their time and knowledge trying to help you is not.
  8. Quite. All the comments about just getting used to them won't help at all if it's a true phobia. You already know it's irrational, you already know they are better residents than mosquitoes. But that doesn't matter, because it's a phobia. Honestly if you are severely affected by it then boating isn't for you because they will always be present.
  9. Slightly better than a thick nail hacksawed to fit but not by much!
  10. And of course the easiest and cheapest way for CRT to collect this would be to combine it with the licence fee. We wouldn't want them to have to waste staff time and banking fees collecting an extra tenner from everyone ...
  12. And limited point if you hoick it out and run it frequently...
  13. Yes, unless you know something I'm not aware of. Add a bit: For clarity, the L&L is shut from Wigan Junction to Leeds. Leigh to Liverpool via Wigan Junction (the 72ft locks) is open.
  15. It's doable, but it's a much trickier crossing than you'd think. Ship Canal to Pomona and then Bridgewater and L&L to Liverpool is a much less demanding but far longer route. At least it's currently navigable!
