mango
Everything posted by mango
  1. mango
    RCD
    Of course. The Uttoxeter is closed until further notice.
  2. mango
    RCD
    Is that the uxter plate or somewhere in Staffordshire. :-)
  3. mango
    Spiders
    Ah yes, I remember being on a mail list and participating in online discussions in the mid-90s, when few boaters were online and probably only from home via a dial-up modem. Happy days. http://www.canals.com/maillist.htm
  4. That's it. Scraping a hull is not much fun, but it must have been a dirtier job in the days before pressure washers to remove the worst of the muck.
  5. It is essential to get rid of all the water and grot in the tank or you are likely to suffer from diesel bug. It's also important to prevent water getting into the tank, for example through a deck filler. The seal should be in good condition and the cap tightened down. Even a poorly sited vent can allow water to enter a fuel tank.
  6. If mrsmelly prefers a cassette I reckon it must be mr smelly rather than mrs melly.
  7. As I explained above, halogen lamps are not much more efficient than ordinary incandescent bulbs and the 'eco' designation is no more than marketing spin. The colour temperature is a bit higher and the life could be 50 or 100% longer. As you say, the fixtures make a significant difference. Hopefully we will see more fixtures designed for LEDs and if properly designed the LEDs should not need to be replaceable.
  8. It is best to look at the brightness in lumens rather than the power consumption when comparing lamps. Incidentally, halogen lamps are often quoted as using 70% of the power of old fashioned bulbs, so are not much more efficient even if labelled 'eco'. It's worth buying one or two lamps for testing, or borrowing them from another boater for test purposes. One thing to watch out for is radio interference, since it is not uncommon with LED lighting especially when the radio signal is weak. To find suitable replacements for the styles of bulb used on boats, you might need to look at a specialist supplier, for example: http://www.bedazzled.uk.com/12v_LED_Bulb_Replacement.htm
  9. mango
    Fuse size
    I wonder how often a 200A fuse would blow in practice. I have spare megafuses, which are readily available, but if I recall correctly, Victron use a type that is more difficult to get hold of.
  10. mango
    Fuse size
    The fuse in the Victron would not offer protection if their was a short-circuit between the battery and inverter.
  11. mango
    Fuse size
    How often does a 200A fuse blow on a 2kVA inverter in normal use? Each to their own.
  12. mango
    Fuse size
    I would go for 200A unless the inverter is used on full power. The fuse can always be replaced with a 300A one if it fails.
  13. Are you asking us to check our stools.
  14. It might be because other boaters run generators and engines late into the evening. Sadly we live in a selfish world.
  15. Are you trawling? Fishing for predictable comments from Hudson owners?
  16. Is that not part of the service? An elderly friend said that they were going to take their car into the garage because the windscreen washer had stopped working. It could have been a wind-up but I don't think so.
  17. This sort of problem is a matter of general maintenance and will not be covered by a guarantee, warranty or the Consumer Rights Act 2015. It is vital to focus on the key issues.
  18. mango
    Spiders
    That seems a reasonable possibility. Garden sheds seem to attract spiders, so I wonder if humidity is a factor. Boats can be fairly humid because of people living in a confined space and use of unflued gas cookers, and often left unheated over the winter months.
  19. mango
    Spiders
    Does anyone know why spiders like being in boats when they usually stay outside houses? I suppose people like being in boats too.
  20. In biochemical terms, carbon monoxide is a competitive inhibitor for oxygen:
  21. Absolutely. At risk of being misunderstood.
  22. Sorry. My humour is not to current standards but hopefully not immediately dangerous.
  23. CRT cannot win. They are constantly criticised for lack of essential maintenance.
  24. mango
    Waste Oil
    I see what you mean. I think the only answer is to include a realistic charge for safe disposal of goods when they reach the end of their life and to make it easy for us all to dispose of our rubbish to avoid fly tipping and pouring oil down the drains.
