keelingtom
Everything posted by keelingtom
  1. Hi It would help if you posted the BSSER (fail report) as that will show the failed item number and the explanation verbatim. You should contact the BSS office to discuss if you are concerned. Regards Tom
  2. Hi For the record, the maximum permitted throughput for an Alde bubble tester is 12kw, not 20kw; this is what Alde themselves state. The device should not be installed at all if there is more than 12kw of appliances aboard unless the device is correctly positioned in a bypass set up.
  3. Hi Callum, I can help you get some local experience for a day as a starter for you; 12th Feb at Autherley Junction which is not too far for you. Landlord's inspections mainly with some minor repair and servicing as it arises. Can you send me some contact details please, if you are interested? Regards Tom Keeling
  4. Hi, If anyone can identify the manufacturer of the following GRP shell it would be most helpful. There are no identifying numbers/plates etc. It is a shell with no fit-out, and was previously owned by the demised SVBC. That is all the information available for now. Thanks, Tom.
