Hi all,
My missus and I are well into our first winter aboard, and we are struggling to find the best solid fuel to use with our Rayburn. The rayburn provides us with hot water and feeds one radiator.
We have tried several different types of fuel from wood to coal to the reconstituted logs, all with varying degrees of success; Coal is by far the longest lasting but seems to produce the least heat especially when using the smokeless variety. Whereas the Reconstituted logs burn very hot, but the fire dies very quickly if not checked on regularly. We have a 62ft narrowboat and getting all of her up to a comfortable temperature is quite difficult without using the reconstituted logs, especially in the recent cold spell.
I may plan to tinker around in the summer and possibly install a second small stove in the forward end and take out the radiator(It's not particularly effective), disconnect the rayburn and use it solely as a cooker/stove and add finally a gas water heater. However that doesn't help us now.
I was hoping I could use your collective experience and ask what is the best fuel you have come across? and if you also have a rayburn what specifically do you use? Are there particular brands I should steer clear of or use?
Finally, does it sound like I am getting this all horribly wrong and the equipment I currently have should if used properly heat the boat effectively?
I am happy to clarify as I am sure I have rambled.
Cheers.
