Leaderboard
Popular Content
Showing content with the highest reputation on 10/10/12 in all areas
  2. With the evenings drawing in there is a little more time to put captions to photo's, possibly not enough time to answer xadmx's question of “why?” To be honest it would be easier for a man to explain the inner workings of a woman's mind, certainly scared me off the keyboard for a while. So the next plank, this “should” be an exact mirror image of the one just fitted, however if the original builder had to work around a fault in his timber stock there could well be a variation side to side, common sense says to work to the original intent. On “Progress” the length is slightly longer side to side but other than that identical. Should the next board in the pile be suitable it would be good to mark around the first plank to ensure the two are as alike as possible. As it happens the next board wasn't suitable, or the next, or the next,........... SPA50230 by chriscollins1, on Flickr SPA50231 by chriscollins1, on Flickr With the first strake in on both sides I could start putting in another pair of frames, it's all a bit of a balancing act at this point, obviously the number one priority is to to copy the original shape and construction as accurately as possible, one piece out and a new piece in would be ideal, unfortunately pieces are falling off quicker than I can replace them – hence the big hole on the port side, not ideal but still enough to get a good copy of the original. SPA50233 by chriscollins1, on Flickr SPA50238 by chriscollins1, on Flickr Over the years I have tried dealing with cutting the hoodings in the stempost in different ways, the easiest is to cut them using what is left of the original as a pattern, unfortunately this is normally the least accurate. Working the rebate as you go up the stempost using a batten hung on the frames to give the angle of the plank landing is far more accurate but generally involves a deal of balancing, contortions and ambidexterity. Once the angle has be accertained a block planed to the same pattern can be cramped to the post to guide the cutting. SPA50241 by chriscollins1, on Flickr
    1 point
  3. Yes it looks very much like an Uxbridge boat to me. The front end is right, also the rudder and skeg but the swim doesn't look as "shapely" as other Uxbridge motors I've seen though this may be the camera angle.
    1 point
  4. Awww well done you for taking on a rescue! Lurchers are lovely dogs . I dont know what id do now without my boy ( a great dane cross) I had him from a pup and crate trained him for the first few months and i can proudly say ive never had a problem with him.. beautiful nature and well behaved. Good luck .. im sure you will all love boat life together lucky dog
    1 point
  5. I also miss my boat heaps when I am not on her. Even if I have had a bad day at work as soon as I step on board, nothing else matters. I am where I need to be. I am very lucky to be able to live aboard, but even when she was a shell I would just sit inside her and "think", I found it realy helped. I think part of the feeling is that she is all mine & NO ONE can take her away from me. If that makes me bonkers, fair play!
    1 point
  6. I often have fenders down and up. The up cos I remembered, the down cos I forgot/have an altruistic bent towards les and co
    1 point
  8. Radiomariner did my Bss in July can't recommend highly enough
    1 point
  9. Once upon a time I was leaving Portsmouth harbour the night after a strong blow. Going the other way into the harbour was a boat flying a yellow Q flag indicating she was arriving from international waters. At some time during the night's gale she had been dismasted, the mast snapping off about 5' above the boom. The crew had jury rigged a storm jib as a mainsail by turning it through 90 degrees with the foot of the sail to the stump of the mast. Shrouds had been sheepshanked down and tightened by spanish windlass. We stood at the rail and applauded her crew in. Now THAT was seamanship! Fenders down is the kind of thing that upsets dickheads with club burgees and peaked hats who lean over the side yelling "Wahtah, wahtah" if there is another boat on the same tack within a mile and call for a helicopter if the gin runs low.
    1 point
  10. The amount you would have to pay C&RT is equal to one-half of the mooring fee of a C&RT-provided offside mooring in the same area (not off-line, that means a marina). There used to be a price list on Waterscape but I don't know if it's on the C&RT website.
    1 point
  11. greeny :lol: I am sure this is a much better way to get to work.........especially if you pick up the secretary and staff up on the way.. .
    1 point
  13. Just buying a boat originally priced over 50K but got 10% reduction. Not sure how this stands up against other experiences but having looked at a lot, this is the only one that really said "buy me". My first boat. Like buying a house. Look at a lot that are OK but you knoa when you eventually step onto "the one".
    1 point
  14. They would have to make the diving platform easier to use as clearly that poor girl upside down on the canal path has missed the water altogether. But why not give it a go - I can see Boris now taking the inaugural plunge dressed in a victorian blue and white stripped swimsuit. Get him more supporters to take over from Dave the Broom.
    1 point
  16. Well, each to his own indeed. However, in this case, there are documented cases of fenders left down causing damage to infrastructure, or blocking the job for an extended period. There is also the fact that fenders left down leave nasty dirty marks on the side of the boat. I don't get too stressed about other people doing it, but I wouldn't do it myself, and it does colour my initial perception of the likely ability of the steerer.
    1 point
  17. No chance - you don't need any more wives Richard
    1 point
  18. I am personally far more concerned with the potential danger of people navigating with their head up their arse over other peoples fenders. if you want to buck for membership of the royal yacht squadron then it's the kind of thing to get upset about but if you're not a poseur then what the hell.
    1 point
  20. The difference between a dog and a wife? Lock them both in the garage for two hours then see who's most pleased to see you when you open the door!
    1 point
