Skip to content
Fatal accident at Alrewas
Featured Replies
#1
This is not new but I dont think I've seen this on forum.
Certainly worth a read
http://www.awcc.org.uk/images/fatal.pdf
Apologies if this has been raised before.
p.s. the link is to a PDF file
Edited by Amicus
#3
Yeah I read this a while back on NB world, not nice, thankfully as the report says, this is a rare occurance.
#4
Truly awful.....
We were well aware of not just this, but another recent canal death too, when we set of on our main holidays, although this is the first time I've seen this report on it.
Not pleasant reading, but despite the sensible recommendations, it's not at all obvious that anything could have been done to save this poor individual, once he had tipped in with the engine (presumably) running quite hard.
It's a strong warning to us all, NEVER to be complacent.
Fortunately, as Nigel says, it's seldom quite this catastrophic - but makes you think....
#5
. Although guard rails are not required on narrow boats, where they are fitted, they should be of an appropriate height to prevent people from falling overboard near the propeller.
This is why I will not have a cruiser stern.
In this case, I summise, that had the rail not been there
a. he would not have fallen.
or
b. he would have been able to 'jump' and get away from the prop.
#6
you would think they would make a deadmans switch for the tiller,if you fell engine would cut out :angry:
not nice to have to cut loved ones off the prop mkaes you think :)
#7
Yeah, that deffornalty would be possable, the use of a killcord is standard practice with powerboats.
#8
I see that as part of their report the MAIB say that the man was not wearing a life jacket. I would question, in this case, if it would have made any difference.
With our lifeboats onboard ships or rigs etc. to avoid this (and for other reasons) the propeller is encased in a Kort nozzle.
Kort Nozzle
Has anyone thought about fitting one of these to a narrow boat ? They increase speed for slower vessels but more important could save people from injury should they be in the water.
#9
I suppose when you are reversing at high revs, the prop is at its most dangerous. If you fall in behind it, it will suck you in. I don't see any logic in saying that a guard rail makes matters worse as there are probably times when it will prevent you falling over the side. But if it's too low, as in this case, it may simply turn you upside down as you fall in which would be more likely to cause a fatality.
#10
Kort Nozzle
Comes up very regularly Dave, they have been tried on narrowboats but the problem with these and other contraptions is that when fouled up they are impossible to clear from a weed-hatch.
Edited by John Orentas
#11
or
It's the height of the rail that's in question here, not the type of stern. It's just as easy to fall from a trad stern if there's nothing to hold onto or what's there is too low.
My cruiser stern has a 4ft high guard rail all the way around. If you look at the picture in the original message, I don't quite understand how the guy fell over that rail unless he was standing on the bench to get a better view ahead. That's something I sometimes do, although my bench is a foot and a half lower than the rail. Anyway, I will take a bit more care after hearing this.
Edited by blackrose
#12
The report states that the boat made contact with the bank at the time the man was seen to tip overboard...
Obviously I don't know for certain, but It's quite possible that the rudder was knocked causing the tiller to kick across.
This is where good practice comes in by ensuring that the steerer is *always* positioned in front of the tiller
And that's why I sudder when I see folks sitting on cruiser stern rails while steering in reverse - If that tiller kicks with 17 ton of boat behind it, you are not going to stop it from throwing you over the rail or cracking ribs!
It's sad to think that this man died a horrible death which was so easily preventable
I'm sure I speak for many here when I say our condolences and thoughts are with his loved ones
#13
I agree but your rail is unusally high in my experience.
Whenever I have hired, it is usually a 'cruiser stern' (not from choice) and I have always thought the rail to low.
As Breals says it will probably cause you to go in head first as opposed to horizontal or feet first.
I always ensure that I do not get between the tiller and the rail, forwards or backwards.
Edited by bottle
#14
Kort Nozzle
Dave, unfortunately fitting a Kort nozzle wouldn't stop anyone getting sucked into the prop. One of the many reasons why they are not fitted to narrowboats in such shallow water conditions as canals is that they are more likely to attract debris and if large enough - such as bits of timber or other solid objects - they can, and do, jam up solid. The same thing could happen to a person who has fallen into the wter.
Howard Anguish
#15
Howard Anguish
I seem to remember, donkey's years ago. There was a report of a device similar to this being fitted to a narrow boat. The report was in WW (before it became an A4 publication, which will indicate how long ago it was!) It was quite complicated as it hinged with the rudder. Apparently steering was great in reverse!. I never saw another one reported at all. I guess for the reasons given above, it was impracticable.
Tony :angry:
#16
Tony :angry:
Hi Tony,
I think I remember the article you mention.
There are two ways to fit a Kort Nozzle. The sinplest is to have a fixed nozzle around a conventional propeller. This is particularly beneficial for increasing thrust and therefore is the type that is fitted, for example, in tugs to give a greater bollard pull. It has the downside of reducing transverse thrust (prop walk) and needs a conventional rudder to be fitted directly behind the nozzle. The second is a steerable kort nozzle, which is a nozzle and propeller unit conbined which eliminates the need for an searate rudder but means that the transmission from the engine to the propeller is more complicated. This type is very good for steering and is sometimes fitted to ships lifeboats which is what I think Dave was referring to in his posting.
Howard Anguish
#18
But you still get sucked into the prop, espcailly if it is a rudder-less nossle.
I think you'll find that that is exactly what I said in my first reply.
Howard Anguish
#19
Yes you're right it's more like 3ft high not 4ft.
http://uk.msnusers.com/7kkj4ha9b91rajtslpc...es/Scan0005.jpg
I'm going out on deck to see if the tiller handle could knock me over the rail. This had never occured to me before reading this thread.
I sometimes stand on that bench to guide the boat slowly through bridge holes (obviously never in astern) - it's much easier than trying to look down one side, but from now on I'll be much more aware of the danger involved.
I've never hired a boat but I've often wondered what sort of safety training hirers get for what can be an inherently dangerous pastime for the unwary.
PS) Why don't my posted images ever appear?
Edited by blackrose
#21
Reading this report is quiet frightening. It seems likely he was pushed over the rail by the tiller after the rudder struck the bottom (or even just swung forcibly from going hard astern).
This makes me think - a semi-trad stern must be the safest narrowboat design - the steerer is always much further forward of the tiller than on a trad or a cruiser and is contained within the cockpit where it would be near impossible to be pushed overboard.
From a health and safety point of view a trad stern is a nightmare - the operator stands unprotected about three feet away from a potentialy fatal source of danger, the cruiser being only a little better in that what protection there is does not guard against the most likely accident, the swinging tiller.
#22
Depends how you use them, surely.
I almost invariably am in the hatchway, forward of the moving tiller arm, which passes behind me. I'd say far more people use them this way, than (say) perch on the counter, OUTSIDE the hatchway.
I'm hemmed in to front, left and right, and would have to engineer something quite dramatic to be moved out of that space I think.
I don't understand why you are any further from the rear of the counter on a semi-trad, unless it has a longer tiller arm ? If my tiller arm were any longer, it would risk catching on lock walls if unattended, and it swung fully to left or right.
Not that I'm complacent - this is a potentially fatal past-time however you do it, and we should all be aware that the unexpected can happen.
#23
"I don't understand why you are any further from the rear of the counter on a semi-trad, "
I was thinking of the number of Trad Stern-ers I see stood on the back slumped over their tiller, often with a coiled rope as a cushion.
There are so many things on the canal that would never be allowed if they were being proposed now for the first time - deep, open, unguarded locks for one, throttles without dead-mans cut off...
It has been suggested that the best safety feature you could fit to a car is a big spike sticking out of the steering wheel - Percieved danger being the great regulator. The issue here is that so few people actually percieve the danger of the prop spinning menacingly just below them
#24
It may also be a reflection on the lack of information about safety surrounding a narrowboat. Often people wouldn't think that the tiller would knock them off the edge of the boat into the prop. It certainly wouldn't have occured to me.
#25
Total rubbish. Steering from the counter of a trad boat is a modern phenomenon,as is the coiled rope hung over the tiller pin...... :(
Ignoring those who through ignorance or the bad design of their boat (and we all know there's a few of those about) a properly built trad stern as on an historic boat has got to be the safest design by far as you steer from inside the boat. Old working boats are pretty well always steered from in front of the tiller stick, the leverage required to steer a heavy arsed boat means you can't do it with the tiller hooked under your arm. Also their owners and enthusiasts mostly realise the dangers of doing otherwise. :(
Edited by Hairy-Neil
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
