Speedwheel Posted September 25, 2011 Report Share Posted September 25, 2011 Is this what I think it is? Part of an old bilge pump system? I'm sure that some old boats had an engine driven (Parsons?) pump that was connected to something like this in the bilge. Link to comment Share on other sites More sharing options...
matty40s Posted September 25, 2011 Report Share Posted September 25, 2011 Is this what I think it is? Part of an old bilge pump system? I'm sure that some old boats had an engine driven (Parsons?) pump that was connected to something like this in the bilge. could be one of those foghorn thingies that the captain shouts down to the crew below to make the enjun go faster. Could be adapted for tea and beer break notifications in the galley. Link to comment Share on other sites More sharing options...
Chertsey Posted September 25, 2011 Report Share Posted September 25, 2011 (edited) Doesn't the strainer make it more likely to be part of a water intake system? Although were these not all integrated in GU boats? - using one pump for cooling and for two bilges, with an arrangement of taps/stopcocks to select which was pumped out? Obviously Chertsey now has an air cooled engine but we still have the original pump, albeit not connected to anything, and on Tarporley (also air cooled engine) the engine driven bilge pump is still in use, and volunteers are carefully instructed about which taps and levers not to touch. Ed. to add photo - is this any help at all? Two strainers, both below the waterline - the upper one looking something like yours? Sorry I haven't got a better photo to show their position. I'd be interested to know myself how the system worked and what the plumbing originally would have looked like. Edited September 25, 2011 by Chertsey Link to comment Share on other sites More sharing options...
Batavia Posted September 25, 2011 Report Share Posted September 25, 2011 (edited) I think that you are right - the base seems to have little feet to hold it off the bottom. Is there a non-return valve inside (or havn't you tried unbolting the flange yet)? Does Frank know this is going to be installed (or has he told you where to put it)? Chris G Edited September 25, 2011 by Batavia Link to comment Share on other sites More sharing options...
Timleech Posted September 25, 2011 Report Share Posted September 25, 2011 (edited) Strum box for bilge pump. Here is a modern plastic one. Yes Parsons clutched gear pumps were fitted on some boats. Tim Edited September 25, 2011 by Timleech 1 Link to comment Share on other sites More sharing options...
Speedwheel Posted September 25, 2011 Author Report Share Posted September 25, 2011 I think that you are right - the base seems to have little feet to hold it off the bottom. Is there a non-return valve inside (or havn't you tried unbolting the flange yet)? Does Frank know this is going to be installed (or has he told you where to put it)? Chris G Not been taken apart yet Chris so no idea. Yes he wants to fit it but not yet sure quite how. Engine has been dropped in. We are going down on Friday to start installing. Sneaky peaky below (not attached to boat yet so not in its final position) Strum box for bilge pump. Here is a modern plastic one. Yes Parsons clutched gear pumps were fitted on some boats. Tim Thanks Tim. (I still owe you one! Not forgotten!) Link to comment Share on other sites More sharing options...
Max Sinclair Posted September 29, 2011 Report Share Posted September 29, 2011 Not been taken apart yet Chris so no idea. Yes he wants to fit it but not yet sure quite how. Engine has been dropped in. We are going down on Friday to start installing. Sneaky peaky below (not attached to boat yet so not in its final position) Thanks Tim. (I still owe you one! Not forgotten!) The National 2D on Vesta had an excellent bilge pump. When boating on the river I could take on extra ballast water and quickly remove it when returning to the canal. The only time this let me down was at Stratford in 1964. We followed the Queen Mum on to the Avon and half a dozen suited dignateries climbed on board for the trip to the theatre. They sat on the roof at the front. After a few minutes I was losing drive with the bow lower than the stern.A quick recall recovered the situation.Happy days. Link to comment Share on other sites More sharing options...
