We're just reached TWO MILLION posts!! Thank you to those who have contributed to Canal World. Read the announcement here
Cpickle
How much Solar v Batteries? What do you have?
196 posts in this topic
1 minute ago, Tony Brooks said:
That will pay for a lot of batteries. On present form I could buy three sets for less and I expect them to last 5 years each set. I will be dead before the payback time is up!!! Or at least no longer able to boat.
Absolutely, and that's why it's aimed squarely at the military. It's used by Enersys (the biggest battery manufacturer on the planet), the UK MoD, the US DoD, the UAE MoD, General Dynamics, Dytecna, Thales, BAE systems and NP Aerospace. They have all tested it, all approved it, and all fit it as standard and no longer bother even auditioning anything else.
It's got to be pretty good ;)
0
Share this post
3 minutes ago, Dr Bob said:
I was thinking about a group of guys doing it for free, ie like CanalPlan
They wouldn't have the knowledge.
0
Share this post
6 minutes ago, Dr Bob said:
No, I was thinking about a group of guys doing it for free, ie like CanalPlan (which I find wonderful) - collecting data sets and seeing how to predict. I only managed a modelling team, rather than did the nitty gritty of the modelling so wouldnt be capable of the model crunching but defining parameters, data collection and model validation are the time consuming things which is within the scope of many of us.
How would that work, all the data collection in the world won't tell you the SoC unless you had something to accurately get the SoC for the data to model against.
0
Share this post
Yes, of course all data sets would have to have a reasonably accurate SoC values and Capacity numbers as I guess they may be the target outputs. I've not thought it through but for each system modelled you would have to log a SoC - maybe via SG - but it could be done via voltage at rest and linked to voltage under load. The trick is to collect a lot of data so that can then be assessed to reject poor data and to get good averages so you dont have to rely on one off numbers that could be inaccurate. Time consuming but not difficult.
0
Share this post
Unless you have a consistent method that all use to accurately get the SoC the data would be useless.
0
Share this post
Fully agree. I think you would have to be consistent across all methods of data collection.
0
Share this post
Gibbo would tell you how easy it is. Test literally thousands of batteries to destruction, cycling them to various SoC until they die, charging them at different voltages, taking relative density readings at all stages, and collating all of the information to arrive at an algorithm. Write a program to make the results self-correcting and put it all in a box for less than a hundred quid.
Dead simple.
0
Share this post
You could release the software for the actual device tho so people can use and come up with there own figures for the algorithm.
Edited by Robbo
0
Share this post
Dead simple.
Yeah, a soldering iron and a few odds and ends from Maplin, job done. Don't know what the fuss is all all about, money for old rope.
0
Share this post
Dead simple.
I wasnt thinking of testing to destruction....and I wasnt thinking of testing thousands of batteries....just a couple.
I also wasnt thinking of an algorithm. For that you need lots of data - and using thousands of batteries - as his model was a global model that had to work for everyone. I was thinking of the newer types of model predictions - viz Topology that uses pattern matching or other advanced techniques. The technique is to get one or two models working on one or two installations during normal running with a limited set of variable inputs and a defined set of fixed inputs. If a relationship can be set up between data in one set up, then the model can be expanded one by one to introduce new training sets. The world has moved on. The amount of data you need is far less.
Please stop reading now if this is boring you.
Let me give you an example of pattern matching models that many of you may have an interest in.
The refining industry make gasoline and sell it to us motorists. They sell to a standard MON/RON value (Motor Octane Number, Research Octane Number). So I buy petrol at RON95. This is tested by an engine test which takes 24 hrs and is accurate to +/- 1 unit. The refineries therefore should make it made to RON96 so that every drop is over RON95 when they sell it ( I think I have RON and MON the right way round) - similar to shops selling a bag of sugar of 1Kg, they always put a little more in to keep them at 1Kg minimum. That 1 unit of RON 'give away' costs refineries over £2M per year. We developed a model to do this on line using Near Infrared Technology (NIR). At one refinery we tested the output from gasoline blending to collect NIR spectra - that were to the naked eye just a wiggley line - and tested a number of Engine tests which were inherently inaccurate.
People had tried for years to do this via regression modelling and trying to come up with Algorithms to do it. They never worked. The input data kept changing and the linear regression models although accurate when the new feed was in the training set range, were useless when outside the range. That is akin to having a model based on say a 500Ahr battery bank and then using the model on a 400Ahr bank.
The topology method overcame this and it was possible to come up with a unique system that could cover all feeds with only a little effort with new tests and model validation.
Now when you go to a petrol station, you tend to get 1unit of RON less as there is no give away as the NIR test is accurate to within .05% rather than the 1% of the engine test. If you are into Diesel not petrol, then we did the same for Cetane number in Diesel. Have you ever noticed how sometimes you get a tank of bad petrol (or diesel). Sometimes it is this RON giveaway. Sometimes it is how much Butane the refinery puts in the petrol!!! ....but not all refineries are using this technology - we were selling this technology at £500K a pop.
Maybe Gibbo is using advanced techniques but pattern matching and the newer techniques (ie sparse data) dont require you to determine an algorithm - and the use of that word suggests it is regression (or regression type) technology. The new methods work by collecting live data but in this case you would also need to get some SoC data (but not necessarliy accurate - as long as the method is consistent) and capacity data.
If you wanted to sell such a model then YES you would have to put so much effort in to make it work for everyone that you would be selling at £1K a pop. I was thinking about a model that works for one person, and then training it with data for another etc etc. Data logging is perhaps the biggest challenge but perhaps linking a Raspberry Pie to a Voltage and Ahr counter could be a cheap option. There would be a lot of other inputs to measure as well (engine revs, temp, solar input to MPPT, output of MPPT etc).
It is nice to dream........ this is more a hobby for a bored ditchcrawler......and I am not bored anymore!
0
Share this post
20 hours ago, WotEver said:
I had a look on a site for gels as well, it seemed to indicate that an alternator was ok but for solar I did say buy a quality controller, like in my case a midnite which can be set up for gel easily. For me I think they will be ok for the electric bathtub until sodium batteries become available
0
Share this post
Great - a boat on water, in the rain and sodium! I also understand they need to run at high temperatures.
I think I will stick with relatively safe lead acids for a long time yet!
0
Share this post
When I was looking at the sites they made no mention of high temps in fact that is the plus for them they operate at either end of the scale unlike lithium which seems to like catching fire will have a look at the inventors site later
0
Share this post
Presumably you mean one of the developers' site? Sodium batteries were first played around with in 1981, and it's only recently (last couple of years) that some developers have looked more closely at them.
0
Share this post
25 minutes ago, Tony Brooks said:
The ones I knew a very little about used liquid sodium so it had to be hot.
Yeah, but they're playing about with all sorts of different compounds at present.
The obvious advantage of them is that unlike lithium, sodium is available in abundance. However the three current disadvantages are reliability (which is being addressed with different (solid) electrolytes), low energy density, and short life.
There are a few groups researching them and filing patents every few minutes so if they're going to prove to be viable I'd think we'd see the first commercial applications within another year or two.
0
Share this post
You didn't mention the biggest problem with sodium.
It makes your blood pressure too high apparently, and my doctor says I must stop eating it. The idiot.
He'll be telling me alcohol is bad for me next. As IF. Huh.
0
Share this post
Best advice for a long and healthy life? Stay away from doctors!
Did you hear about the old boy, passed away at 95. He put his longevity down to eating a teaspoonful of dynamite every day. Boy, his cremation went off with a bang.
0
Share this post
Did you hear about the copper who arrested two lads for eating gunpowder and drinking battery acid...??
0
Share this post
  • Similar Content
    • By Barroca Grande 2
      Hi all battery afficionados I am about to take new batteries down to the boat and do the change over.  I have searched the forum and found some interesting things I did not know before.  Now I would like some clarification.  The old set up (six batteries 110Ah) was always a bit higgeldy piggeldy as we couldn't fit all the ends onto the terminals.  When I had to buy new batteries at short notice we basically had to do the same again so
      Set 2 comprises 5 leisure batteries 115Ah I will label them A to E.
      Positive side
      Battery A currently has solar cable and one from the Isolator Switch and link to battery B
      Battery B has two links A and C
      Battery C has link to B and D as well as smartgauge
      Battery D has link to C and E as well as one to the Isolator Switch
      Battery E has link to D
      Negative side
      Battery E has link to D and one to Victron and one to the Mikuni
      Battery D has links to E and C and one to the smartgauge
      Battery C has links to B and D and one to the solar panels
      Battery B has links to A and C and one to Victron
      Battery A has link to B and one off to the Starter Battery
      Now the 4 new batteries 160Ah have a M8 bolt type fitting so no need for the terminal clamps as used previously so we hope that it will be easier to fit more cables to a single post.
      The proposed layout is going to be
      Positive side
      Battery A has both the Isolator cables and the link to B
      Battery B has link A and C
      Battery D has Link from C and solar and Mikuni and smartgauge  (ie 4 one large and three small)
      Negative side
      Battery D has link to C and both large cables to Victron
      Battery C has links to  D and B
      Battery A has link from B then the large one to Starter battery and the negatives to Solar Mikuni and smartgauge.
      I am reasonably happy with this BUT which order should I pile the cable ends for best connection (thinking smartguage here)
      (My reasoning for putting both Isolator switch connections to one and both Victron to the other is I am not 100% sure why there are two or if this is immaterial or not and if material and I put them the wrong way around it could mean that they are not going to pass through the whole bank.  If you get my drift.)
      I have printed off the smartgauge info linked to in a previous post about how to correctly interconnect multiple batteries but
      a) this doesn't address the issue of all the other items connected to the bank.  I have basically assumed that by having the charger going one way and the solar and everything else going the other way around that that is okay.  Otherwise Everything would have to go onto two diagonally opposite terminals
      and b   )  we don't have enough extra cabling to do the fancy Methods 3 or 4.
      Battery etc.pdf
      Schematic, what I drew, of current set up since oct 14.pdf
    • By mrsmelly
      Now I have caught your attention I have put this in the virtual pub so it excludes members who are too boring to visit it. I have had my batteries changed today my old ones are sat on the arse end of the boat here at Lower Heyford waiting for later removal. I cant be arsed ever nor can my mate who changed em be arsed to weigh them in so If you can be arsed and are passing by boat pull alongside and away you go. Just let me know who you are if you can be bothered, first come first served so to speak. Oh yes editted to add there are 4 at 24 kilos each in foreign measurements.
      cheers
    • By purple8
      So..
      for the last few days our engine has been kicking out white fumes from the exhaust and seeming much noisier from it too. So thinking it could be water in the fuel I drained both fuel filters and continued on our way. The smoke returned 15mins into cruising and even spat out a little black when going astern into the locks. So We gave her a rest. By the morning our starter battery didn't have enough charge to turn over the engine and we had to charge it from our genny. Even tho we have the starter isolated all the time when not running? The battery isolator is new from amazon? But we remove the key so surely that cannot drain it?
      today we charged the starter off the genny and eventually got her started. She blew white smoke for the hour and a half cruise to bedwyn and we stopped. We decided we could try checking the valve clearances, not easy as we couldn't find the tdc for each valve. But then after only 2 hours moored the engine again wouldn't tick over! And each time the key turned in the ignition you could watch the battery voltage dropping on the starter and even on the leisure battery readers.
      we are baffled! I am guessing they are two separate issues, the smoke and the batteries draining. But it feels so coincidental to all happen at once.
      any advice or ideas would be great. Or anyone near bedwyn on the k&a willing to help would be great too!
    • By Johny London
      Just thinking about how best to bring my solar cabling into the boat - I've seen it going into mushroom vents but I'm doubtful I'll be able to run it inside the roof space without taking half the ceiling down - it's a few metres. So I looked for waterproof junction boxes and found some for solar panels - with diodes already inside. That set me a thinking regarding blocking diodes and whether I need them!
      So, before I order the cheapest little plastic box with a grommeted hole, perhaps I could ask what others have used and whether diodes are necessary!
      ta
    • By DeanS
      Hi all.
      I purchased a 2nd boat which came with 4 solar panels (unconnected) , with the following specs (see image). Do you know what controller I should buy to connect them to 12V batteries ?
      Many Thanks.
