Dave Payne Posted June 2, 2017 Report Share Posted June 2, 2017 Purchased one of these and it arrived yesterday, the cable that came with it, to me seems a little thin, it says 10mm2 on it and its about 1m long. I dont think its long enough so will need to pick up some new cable, question is how thick should it be, will be about 2-3m from batteries and running at 1200 watts, 12v battery bank. http://www.sunshinesolar.co.uk/prodshow/1200W___12V_Pure_Sine_Wave_Sunshine_Power_Inverter/VP1200.htm Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 2, 2017 Report Share Posted June 2, 2017 1200w would be roughly 100 amp draw from your batteries. Chinese amps are (obviously) much smaller than European amps, as depending on the test method (in conduit, in a 'bundle', in free air, clipped etc) 10mm2 cable would be (European) rated at somewhere between 30 and 65 amps. If they cannot even get the cable size correct, I would be giving consideration as to what other 'cost cutting' may have taken place internally in the Inverter. Link to comment Share on other sites More sharing options...
WotEver Posted June 2, 2017 Report Share Posted June 2, 2017 1200W is about 120A taking into account the inefficiencies. Using cablesize in mm2 = 18*metres*amps/(V*1000) (Where metres = entire cable length there and back and V = Maximum permitted voltage drop). Using 3m as the distance, and assuming 0.3V max voltage drop gives: 18*6*120/333 = 37. So I'd use 50mm2 Link to comment Share on other sites More sharing options...
Dave Payne Posted June 2, 2017 Author Report Share Posted June 2, 2017 Interesting, i wonder why they would send it then with an incorrect cable size? Link to comment Share on other sites More sharing options...
Northernboater Posted June 2, 2017 Report Share Posted June 2, 2017 (edited) Give them a ring and ask them their Help line is 01508 488 188 and if your not happy with their answer send it back and buy a proper one from Mastervolt. I should imagine if they sent the correct size of cable it would probably cost more then the components in the inverter LOL. And you get what you pay for, cheap Chinese, mass produced, re-branded inverter. What are you going to be running off it? 2x 3m lengths of 50mm2 (Red & Black) rated at 345 Amps @ £40-£50 plus crimped connections Edited June 2, 2017 by Northernboater Link to comment Share on other sites More sharing options...
WotEver Posted June 2, 2017 Report Share Posted June 2, 2017 1 hour ago, Dave Payne said: Interesting, i wonder why they would send it then with an incorrect cable size? Money saving. They probably figure most folk won't run it at 1200W and if they did then the voltage drop would be about 1V which the inverter probably wouldn't care to much about. It means you'd be dissipating around 120W down the cable though. Link to comment Share on other sites More sharing options...
Dave Payne Posted June 2, 2017 Author Report Share Posted June 2, 2017 1 hour ago, Northernboater said: Give them a ring and ask them their Help line is 01508 488 188 and if your not happy with their answer send it back and buy a proper one from Mastervolt. I should imagine if they sent the correct size of cable it would probably cost more then the components in the inverter LOL. And you get what you pay for, cheap Chinese, mass produced, re-branded inverter. What are you going to be running off it? 2x 3m lengths of 50mm2 (Red & Black) rated at 345 Amps @ £40-£50 plus crimped connections Hair dryer. Link to comment Share on other sites More sharing options...
Northernboater Posted June 2, 2017 Report Share Posted June 2, 2017 (edited) 15 minutes ago, Dave Payne said: Hair dryer. OK As I said above give them a ring, their Help line is 01508 488 188 and let us know what they say Edited June 2, 2017 by Northernboater Link to comment Share on other sites More sharing options...
Paul C Posted June 2, 2017 Report Share Posted June 2, 2017 Just be sure to mount it somewhere easily accessible with a fire extinguisher. Were you planning on leaving that thing on while the boat is unattended? Possibly, for a mains fridge? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 2, 2017 Report Share Posted June 2, 2017 (edited) Maybe there really are differences (I think there are) between a 1200w Inverter on ebay at £22 inc delivery, and a Victron 1200 w inverter at £500+ It may be worth looking at some of the videos on ebay showing the insides (and the fires caused) with the cheap Chinese inverters. One of the 'less frightening' videos Edited June 2, 2017 by Alan de Enfield Link to comment Share on other sites More sharing options...
Dave Payne Posted June 2, 2017 Author Report Share Posted June 2, 2017 Ok, i understand the cable is wrong, but saying it will set on fire? This inverter wasn't from ebay, it was from a company whom we all know on this forum and who i have purchased solar gear from, it wasn't dirt cheap but £220, i cant imagine they would sell items that would set on fire. It will not be left on, i only purchased it to run a hair dryer, i will use my victron to run tv and fridge as i know this one works well. Link to comment Share on other sites More sharing options...
Paul C Posted June 2, 2017 Report Share Posted June 2, 2017 Twin inverter setup??? Link to comment Share on other sites More sharing options...
Neil Smith Posted June 4, 2017 Report Share Posted June 4, 2017 Just use the victron to dry your hair. Neil Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 4, 2017 Report Share Posted June 4, 2017 25 minutes ago, Neil Smith said: Just use the victron to dry your hair. Neil However - a hair dryer may be more successful. Link to comment Share on other sites More sharing options...
WotEver Posted June 4, 2017 Report Share Posted June 4, 2017 1 hour ago, Alan de Enfield said: However - a hair dryer may be more successful. Oh I dunno... they get pretty warm Link to comment Share on other sites More sharing options...
Chewbacka Posted June 4, 2017 Report Share Posted June 4, 2017 4 hours ago, WotEver said: Oh I dunno... they get pretty warm especially if it is one of those cheap inverters where occasionally the overload shutdown method is to catch fire............. Link to comment Share on other sites More sharing options...
WotEver Posted June 4, 2017 Report Share Posted June 4, 2017 25 minutes ago, Chewbacka said: especially if it is one of those cheap inverters where occasionally the overload shutdown method is to catch fire............. Yeah, those get particularly warm Link to comment Share on other sites More sharing options...
Dave Payne Posted June 19, 2017 Author Report Share Posted June 19, 2017 Bit concerned now with this bit of kit, mrs used it all last week with her hair dryer, had the washing machine running a couple of times and ran the fridge and tv, oh and hair straighteners.. No fire, should i be worried, when do the experts believe it will go up in flames? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 19, 2017 Report Share Posted June 19, 2017 20 minutes ago, Dave Payne said: No fire, should i be worried, when do the experts believe it will go up in flames? When you least expect it - it will creep up on you as the 2nd rate components age and the solder joints go 'dry' - then - WHOOOOOOOSH. Link to comment Share on other sites More sharing options...
WotEver Posted June 19, 2017 Report Share Posted June 19, 2017 5 hours ago, Dave Payne said: when do the experts believe it will go up in flames? Undoubtedly at the most inconvenient time. Such is the way of these things. Link to comment Share on other sites More sharing options...
