MPPT to battery wiring & shunts
Cloudinspector
I'm about to wire in a MPPT solar charge controller and am unsure whether the negative cable can go direct to the batteries or will it need to go via the shunt that's fitted for the BMV battery monitor. At the moment there are no negative connections to the batteries other than the shunt negative and smart gauge negative.
Rule of shunts, absolutely nothing apart from the shunt should be connected to the battery, including your starter battery negative.
sensor wires can be excluded like your smartguage and such.
Edited by Robbo
It can go direct to the batteries, but more typically should go through the shunt. The only reason I can think you might want to go direct to the battery is due to lack of space on the shunt, in which case you could fit a busbar.
What's the point of the shunt if you're going by pass it and make what it displays totally inaccurate.
Edited by Robbo
So you can charge your batteries, if otherwise you couldn't fit another connection on the shunt.
another reason, i suppose if you only wanted to measure loads only.
Edited by rusty69
You might as well just remove the BMV if your not going to wire it up right.  All of the functions will be incorrect apart from voltage, and it would make a rather expensive voltage gauge.  Even your loads only would be incorrect if your alternator/charger is on the other side.
Im not sure the load current measurement would be incorrect would it?
The question asked by the OP was"whether the negative cable can go direct to the batteries "
Clearly the answer is yes.
What do you mean by 'other side'?  If all charging sources are connected to the battery directly and all loads connected via the shunt then the loads reading would be correct.
I often wonder whether I should connect my solar direct to the battery so when the solar is on I can get a load only measurement on the BMV.
Edited by rusty69
But then you can completely kiss you state of charge indication goodbye. If you aren't interested in your batteries' state of charge and just want to know the current going into the boat's services then fair enough. I think even the AH used value would stop working after a while - the AH used would continuously increase until the software or display gave up.
True, but i tend to ignore the soc on the bm and use the sg anyway,cos I don't trust it. I also find it useful to know what load is on the battery, difficult to determine in the presence of solar.
I suppose the answer is to add an ammeter to the solar, leave it all through the shunt and do a mental calculation if required.
Edited by rusty69
Yes but that would rewiring the alternator and other charging sources rather than just putting the solar on the battery.  Bit hard to do if you have a combi charger/inverter as well.
I wasn't suggesting it as a 'good idea', I was simply asking what was meant by that phrase.
Neither was I which was clear in my post.
I think the first reply kind of answered the question
5 minutes ago, Cloudinspector said:
If I connect via the shunt is there a limit to how many connections can be fitted to a single post? There's already 2 connections on the load side of the shunt.
There's no electrical limit. The limit is purely mechanical. If you can fit five terminals on a stud securely then you can have five connections. However, it is probably more practical (and better practice) to use a decent busbar once you get beyond 2 or 3. See the current thread about buzz bars [sic].
If you have no room for a bus bar, you can get shunts that have more than one connection.  wouldnt be worth it for yourself.   When wiring up the one with the most load goes nearest to the shunt with the one with the least load at the top.
Edited by Robbo
