Canal World
Join us absolutely Free in just two minutes to gain access to all our features. Once registered, you will be able to submit new content and get answers to your all your canal & boating questions all for absolutely Free!
Sign in to follow this
Followers 0
M-S-D
Lifting / moving an Enfield Z Drive
8 posts in this topic
Hi
Need to lift a zdrive in order to trailer.  Have looked at the old parts PDF but not clear from it what exactly is needed. Could anyone articulate? Assume something needs un-pinning or similar. It looks to be the version without the wheel.
Also, as it probably has not moved for a while, it may need some encouragement - any tools etc you could suggest?
I had taken a picture but seems to have become corrupted, if I recover will post.
Hopefully, thanks.
0
Share this post
If you Google Enfield Z drive there is a PDF owners manual #'s list on PDF to view or Down load From memory the swivel around arla clock hands rather than the Usual OB fore/aft tilt
Edited by X Alan W
0
Share this post
There is a slide pin to pull inboard to release the lock then wind the leg sideways using a starting handle to move the worm drive.
0
Share this post
Thanks for replying. I have only been able to locate a service manual, not an owners manual unfortunately.
0
Share this post
Thanks for replying, I believe is the model without the winder. However, the pin to release the lock is on the inboard side is it?
0
Share this post
If that is your out drive I think the tilt handle fits in the small notched part on top of the pot shaped part on the left,the mech appears enclosed on the one in the photo. Do you have a handle that looks like an old fashioned car starting handle with a peg at right angles at the end of the bar?  If yes this should fit in the notched upstand & be able to wind/twist it around after releasing the locking pin
0
Share this post
10 hours ago, WotEver said:
Thanks, that is a little different to the one I had located, and clearer text too.
Thank you, will take a look.
0
Share this post
Followers 0
