Canal World
Join us absolutely Free in just two minutes to gain access to all our features. Once registered, you will be able to submit new content and get answers to your all your canal & boating questions all for absolutely Free!
richardofaccrington
Lister TS2 Air Filter query
11 posts in this topic
Can anyone help me source a decent replacement air filter for my Lister TS2, which has a round flat air cleaner box a bit like a frying pan in shape. the old filter element is a strip of black foam between two metal mesh rings. size is 75mm high or 3 inch, 160mm outside diameter (6 .1/4 inch), and 110mm inside diameter (4.1/4 inch).
Suggestions please.
0
Share this post
We probably have them in stock
Give Sue a ring on 01926 56200
Richard
0
Share this post
Suggestions please.
RLWP a member of this forum is yer man. Send him a pm and he will sort you out. ( In a nice way that is )
0
Share this post
Well, his wife will anyway
Richard
0
Share this post
Richard
Blimey we cross posted have you missed a number off the telfone number?
0
Share this post
Damn! 01926 356200
Thanks Tim
Richard
0
Share this post
Thanks very much for the rapid response. Am I allowed to extend the enquiry by asking about an exhaust flange and gasket for the same Lister TS2. the attached photo shows the exhaust flange coming off the manifold, facing sternwards. The silencer assembly has 1.1/2" flexible pipe with   two bolt flange attached with U bolts. (see second photo attached) any sources for these items would be most appreciated.
0
Share this post
That should be a standard part, do you want us to do a stock check?
Richard
0
Share this post
366-01287, we have four in stock
Richard
0
Share this post
Sorry for my confusion, but is this part you are quoting
1. the air filter
2. the exhaust gasket or
3. the stub pipe with mating flange (RHS of second pic)
0
Share this post
The gasket.
The gasket is 366-01287
The filter is probably 366-07188. What you describe doesn't sound like an oil bath or one of the big, cyclonic filters
I'm not sure what you need for the rest of the exhaust. It looks like a pretty standard outlet with the pipe stuffed up a bit of flexible tube and jubilee clipped in place
Richard
Edited by RLWP
0
Share this post
  • Similar Content
    • By lampini
      Does anyone know if there's an equivalent air filter available from an ordinary motor factor? Or anywhere I could order one online to be delivered before 3rd June?
      Thanks for any help...
      Jane x
    • By BriarRose
      Hello there! I am new to this forum but see people are very helpful, so thought I'd try my luck and see if anyone can offer advice. I've recently bought my boat and done a fair amount of cruising over the past three weeks. Today as I was reversing, I tried to change to forward and the engine was stuck in reverse. It would not go into neutral or forwards at all. I stopped the engine. When I re-started it was still in reverse. It's a Lister Petter Alpha with a Delta 20 Gearbox. I read on another post in here that it could be something to do with oil level, but I have been in the engine bay with my headtorch for the past half hour and cannot see a dipstick for the gearbox oil. Does anyone know where this might be or if I am even on the right train of thought here? I don't know much about the engine yet but am learning as fast as I can. Thanks in advance to anyone who can help as I am currently stuck on the Shropshire Union.
      Sophie
    • By Johny London
      I seem to have trouble sourcing basic engine service parts - typically ordering at Chandlers with lengthy delays and high prices.
      Can anyone advise either for an online place or good local (I'm in Rickmansworth at the moment) supplier? Should I try to source parts from motor factors or places such as local car shops/halfords? I'm never quite sure about oil, often being offered oils slightly different in spec to what the book recommends.
      I feel like I haven't nailed a good steady supply of correct items, it must be simple surely?
      thanks
    • By mykaskin
      Hi Folks,
      In case you are missing your boating fix in these dark and cold days, here's a video I made, aboard Victoria, last summer boating up the North Oxford:
      https://www.youtube.com/watch?v=gOsv7Vu2A6U
      Hope you enjoy,
      Mike
