Nightwatch Posted May 14, 2017 Report Share Posted May 14, 2017 3 hours ago, mrsmelly said: Nearly missed this one I do now have a pumpout simply because the numpty who had the boat built had it fitted and I am fed up of removing them and fitting proper boat bogs. I do however have a proper boat bog as well now on the boat. I will add that I am using the silly macerator bog because at present it works very well ( It will go wrong ) and I do not pay for pump outs. As an addition there is absolutely no smell other than when outside the boat pumping out. We put nothing whatsoever in the tank as being a macerator bog it uses eighteen million gallons of water per flush so I dont even flush the tank out between empties as its ninety nine percent water anyway. WHEN it breaks I shall simply remove it and cap it off. Yes, you did nearly miss this one. Hope you don't mind me mentioning you, just to get a different perspective, you understand. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 14, 2017 Report Share Posted May 14, 2017 6 hours ago, Nightwatch said: Yes, you did nearly miss this one. Hope you don't mind me mentioning you, just to get a different perspective, you understand. Not at all old chap............carry on..................Fancy me missing a Bog thread....must be getting old or summett Link to comment Share on other sites More sharing options...
Nightwatch Posted May 14, 2017 Report Share Posted May 14, 2017 Maybe summat?? Link to comment Share on other sites More sharing options...
