fittie Posted May 1, 2017 Report Share Posted May 1, 2017 I know this might be in the wrong area but I thought that more people would see it. Can anyone help? I'm looking for around a dozen long brass, domed, 3/8 Whitworth nuts for a Lister JP Cheers paul Link to comment Share on other sites More sharing options...
OldGoat Posted May 1, 2017 Report Share Posted May 1, 2017 If you get desparate, i.e no leads then give Namrick (www.namrick.co.uk) a call - they don't go as far as brass, but they (can be) a fount of knowledge. Grovel and they'll be helpful. Link to comment Share on other sites More sharing options...
WotEver Posted May 1, 2017 Report Share Posted May 1, 2017 Looks like these folks might have them: http://brassfactory.co.uk/brass-dome-nuts.html And these: http://www.kwikfast.co.uk/nuts/ 1 Link to comment Share on other sites More sharing options...
WotEver Posted May 1, 2017 Report Share Posted May 1, 2017 And although they don't list them specifically these folk might also stock them: https://www.stationaryengineparts.com/Lister-D-Brass-Dome-Nut-Set-Of-Three.html Link to comment Share on other sites More sharing options...
BWM Posted May 1, 2017 Report Share Posted May 1, 2017 (edited) I believe that you will find them on the stationary engine parts site listed as lister D cylinder head nuts, sold in packs of three. I used them to hold down the rocker covers on my Jp3, they aren't exactly the right size for the studs but close enough if not over tightened. Just noticed the link that wotever attached! Edited May 1, 2017 by BWM re reading the previous post Link to comment Share on other sites More sharing options...
WotEver Posted May 1, 2017 Report Share Posted May 1, 2017 13 minutes ago, BWM said: I believe that you will find them on the stationary engine parts site listed as lister D cylinder head nuts, sold in packs of three. I used them to hold down the rocker covers on my Jp3, they aren't exactly the right size for the studs but close enough if not over tightened. Just noticed the link that wotever attached! Yeah, they're 7/16, which isn't a million miles away from 3/8 so as you say they'd make a sloppy fit. Link to comment Share on other sites More sharing options...
BWM Posted May 1, 2017 Report Share Posted May 1, 2017 45 minutes ago, WotEver said: Yeah, they're 7/16, which isn't a million miles away from 3/8 so as you say they'd make a sloppy fit. Exactly that, ok for retaining things but not for bolting down under too much pressure. I wonder if Tony Redshaw might be worth asking, i've noticed many of his reconditioned engines have what looks like a new set of tall dome nuts. Link to comment Share on other sites More sharing options...
fittie Posted May 1, 2017 Author Report Share Posted May 1, 2017 Thanks one and all, I'm looking for the more...vintage style where the hex nut is just slightly domed if you get what I mean. Is Tony Redshaw on here? Link to comment Share on other sites More sharing options...
WotEver Posted May 1, 2017 Report Share Posted May 1, 2017 16 minutes ago, fittie said: Thanks one and all, I'm looking for the more...vintage style where the hex nut is just slightly domed if you get what I mean. Not really Please post a piccy and source if you find any Link to comment Share on other sites More sharing options...
mark99 Posted May 1, 2017 Report Share Posted May 1, 2017 (edited) 32 minutes ago, fittie said: Thanks one and all, I'm looking for the more...vintage style where the hex nut is just slightly domed if you get what I mean. Is Tony Redshaw on here? I don't think so but he has a face book and web page. http://www.vintagediesels.co.uk/services/ Edited May 1, 2017 by mark99 Link to comment Share on other sites More sharing options...
BWM Posted May 1, 2017 Report Share Posted May 1, 2017 52 minutes ago, WotEver said: Not really Please post a piccy and source if you find any I'll second that, there are quite a few missing from my Jp. Link to comment Share on other sites More sharing options...
frangar Posted May 1, 2017 Report Share Posted May 1, 2017 I ended up getting some made by Mr Redshaw last time I needed some...I dare say it's something any good engineering shop could do especially if a reasonable quantity was involved. Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 1, 2017 Report Share Posted May 1, 2017 http://brassfactory.co.uk/brass-dome-nuts.html Link to comment Share on other sites More sharing options...
WotEver Posted May 1, 2017 Report Share Posted May 1, 2017 (edited) 11 minutes ago, ditchcrawler said: http://brassfactory.co.uk/brass-dome-nuts.html That was my first link Edited May 1, 2017 by WotEver Link to comment Share on other sites More sharing options...
Jrtm Posted May 3, 2017 Report Share Posted May 3, 2017 I hurd the problem was solved by fitting a horse Link to comment Share on other sites More sharing options...
Machpoint005 Posted May 3, 2017 Report Share Posted May 3, 2017 On 01/05/2017 at 14:16, BWM said: I believe that you will find them on the stationary engine parts site listed as lister D cylinder head nuts, sold in packs of three. I used them to hold down the rocker covers on my Jp3, they aren't exactly the right size for the studs but close enough if not over tightened. Just noticed the link that wotever attached! Ouch! On that basis you could probably use a metric fitting! Link to comment Share on other sites More sharing options...
BWM Posted May 3, 2017 Report Share Posted May 3, 2017 54 minutes ago, Machpoint005 said: Ouch! On that basis you could probably use a metric fitting! The rocker covers don't need more than a nip to keep them in position, and these ones are a lister pattern and as such look the part. The tpi on metric may work, but the modern dome nuts are fairly squat. I certainly wouldn't use them for a manifold or similar ! Link to comment Share on other sites More sharing options...
Machpoint005 Posted May 3, 2017 Report Share Posted May 3, 2017 17 minutes ago, BWM said: The rocker covers don't need more than a nip to keep them in position, and these ones are a lister pattern and as such look the part. The tpi on metric may work, but the modern dome nuts are fairly squat. I certainly wouldn't use them for a manifold or similar ! I wasn't seriously suggesting the use of anything except the correct size. Near enough ain't good enough, whether metric, Imperial or Chinese. Link to comment Share on other sites More sharing options...
RLWP Posted May 3, 2017 Report Share Posted May 3, 2017 3/8 UNC is extremely near enough Richard 1 Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 3, 2017 Report Share Posted May 3, 2017 On 2017-5-1 at 22:57, WotEver said: That was my first link Its an age thing and wine, I forget what I have read trying to help people Thanks for including the smilley Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 3, 2017 Report Share Posted May 3, 2017 1 hour ago, RLWP said: 3/8 UNC is extremely near enough Richard I was about to suggest that but could not remember the exact size when the UNC & BSW pitches became incompatible. Probably 7/16 or 1/2 inch Link to comment Share on other sites More sharing options...
David Mack Posted May 3, 2017 Report Share Posted May 3, 2017 On most of the JPs I've seen the rocker covers are held down by iron handwheel nuts rather than brass domed nuts. Link to comment Share on other sites More sharing options...
RLWP Posted May 3, 2017 Report Share Posted May 3, 2017 23 minutes ago, Tony Brooks said: I was about to suggest that but could not remember the exact size when the UNC & BSW pitches became incompatible. Probably 7/16 or 1/2 inch I can't remember either, so I googled the two sizes Link to comment Share on other sites More sharing options...
BWM Posted May 3, 2017 Report Share Posted May 3, 2017 38 minutes ago, Tony Brooks said: I was about to suggest that but could not remember the exact size when the UNC & BSW pitches became incompatible. Probably 7/16 or 1/2 inch Pre war whitworth nut measurement changed during ww2 due to scrimping, every little counted in those days. Link to comment Share on other sites More sharing options...
Sir Nibble Posted May 3, 2017 Report Share Posted May 3, 2017 I know what you mean by the vintage style shallower dome but iv'e no idea where to find any. I do have a lister D though. Link to comment Share on other sites More sharing options...
