Canal World
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more!
This message will be removed once you have signed in.
Sign in to follow this
Followers 0
Sweeny Todd
water pump identification needed please
4 posts in this topic
Hi
I am looking for a replacement water pump for our engine which I believe is a Ford D 4 cylinder with a Parsons Pike conversion. Any one know where I can get one and what part I need to order please. I have googled but none of them have looked quite right. I have attached photos below. Thanks in advance for any help on this.WP_20170405_18_10_22_Pro.jpg.a8d28d2ada13808f78294691e04256fc.jpgWP_20170405_18_10_15_Pro.jpg.27bb7e70196f506dd03766105c4c640a.jpg
0
Share this post
I don't know but when it was new it would have been assembled with a bearing and a seal or two, I wonder if its possible to get it apart, if it is then it should be possible to get a new bearing for it. might be a sod to pull the vane off the shaft though.
0
Share this post
Ford 4D & 6D (might be the same pump) were used in a wide variety of lorries (thames trader IIRC, amongst others), tractors, pumps, generators etc, so possibly one could be sourced or overhauled from that direction - vintage tractor parts suppliers would possibly be the best bet
Springy
0
Share this post
Followers 0
