BriarRose Posted April 17, 2017 Report Share Posted April 17, 2017 Hello there! I am new to this forum but see people are very helpful, so thought I'd try my luck and see if anyone can offer advice. I've recently bought my boat and done a fair amount of cruising over the past three weeks. Today as I was reversing, I tried to change to forward and the engine was stuck in reverse. It would not go into neutral or forwards at all. I stopped the engine. When I re-started it was still in reverse. It's a Lister Petter Alpha with a Delta 20 Gearbox. I read on another post in here that it could be something to do with oil level, but I have been in the engine bay with my headtorch for the past half hour and cannot see a dipstick for the gearbox oil. Does anyone know where this might be or if I am even on the right train of thought here? I don't know much about the engine yet but am learning as fast as I can. Thanks in advance to anyone who can help as I am currently stuck on the Shropshire Union. Sophie Link to comment Share on other sites More sharing options...
WotEver Posted April 17, 2017 Report Share Posted April 17, 2017 Welcome to the forum soneone will be along shortly who knows the Delta. Link to comment Share on other sites More sharing options...
bizzard Posted April 17, 2017 Report Share Posted April 17, 2017 It should be what looks like a plug on the top, towards the rear on the port side of the box, hexagon spanner to undo. Dipstick attached to it. Link to comment Share on other sites More sharing options...
adrianh Posted April 17, 2017 Report Share Posted April 17, 2017 (edited) The dip stick is attached to the brass hexagon headed filler plug, remove the screw to check the level. The oil is the same as your engine as this has hydraulically operated clutch plates. If you are stuck in a gear then it is more likely the morse connecting cable or its outer sleeve has come loose Edited April 17, 2017 by adrianh Link to comment Share on other sites More sharing options...
WotEver Posted April 17, 2017 Report Share Posted April 17, 2017 Port is the left when stood on the stern and facing the front of the boat. Hey, I'm just sayin'... not everyone knows If the level is correct, can you move the lever by hand? Link to comment Share on other sites More sharing options...
bizzard Posted April 17, 2017 Report Share Posted April 17, 2017 6 minutes ago, WotEver said: Port is the left when stood on the stern and facing the front of the boat. Hey, I'm just sayin'... not everyone knows If the level is correct, can you move the lever by hand? That's it. No port left at the party. Link to comment Share on other sites More sharing options...
WotEver Posted April 17, 2017 Report Share Posted April 17, 2017 2 minutes ago, bizzard said: That's it. No port left at the party. Yep, plus Port wine is red. Link to comment Share on other sites More sharing options...
BriarRose Posted April 17, 2017 Author Report Share Posted April 17, 2017 Hello! Thanks very much for your help. I am calling it a night and will try again tomorrow. I have seen that when I move the gear lever, there is no movement at the mechanism where the cable joins the gearbox. However, if I manually move the part to other position then try reverse with the lever, the cable moves the part to its original position. This may make little sense without knowing the name of the 'part',sorry! It makes me think the cable going from gear lever might have snapped? Hm...hopefully all will become clear in the morning. Thanks again Link to comment Share on other sites More sharing options...
bizzard Posted April 17, 2017 Report Share Posted April 17, 2017 10 minutes ago, BriarRose said: Hello! Thanks very much for your help. I am calling it a night and will try again tomorrow. I have seen that when I move the gear lever, there is no movement at the mechanism where the cable joins the gearbox. However, if I manually move the part to other position then try reverse with the lever, the cable moves the part to its original position. This may make little sense without knowing the name of the 'part',sorry! It makes me think the cable going from gear lever might have snapped? Hm...hopefully all will become clear in the morning. Thanks again Sounds like an outer cable retaining clip has come adrift. Link to comment Share on other sites More sharing options...
WotEver Posted April 17, 2017 Report Share Posted April 17, 2017 20 minutes ago, bizzard said: Sounds like an outer cable retaining clip has come adrift. Yup. Link to comment Share on other sites More sharing options...
