We're just reached TWO MILLION posts!! Thank you to those who have contributed to Canal World. Read the announcement here
Ratkatcher
BMC 1.5 / Thornycroft 90 Glow Pliugs
25 posts in this topic
The glow plugs in my engine are getting tired so I thought "order some on Ebay"   - a seller had them listed at £8.00 each so promptly ordered and paid for.  Received a 'dispatched' notice from the seller, all good.
The next day I receive an 'order cancelled by buyer - refund' notice, obviously not cancelled by me but by the seller.  The same day he is listing the same glow plugs at £113 each!
If anyone finds they need some, about the only place in the UK that has genuine Champion ones (AG32) at a half reasonable price is: John richards Surplus at £18 each with free delivery (assuming that I don't receive another out of stock notice!)
The equivalents from other manufacturers appear to be suffering a lack of stock or massive price inflation which is the sole reason I thought to post this littlle tale, if you feel you need spares, just in case, this may be a reasonable choice.
David
0
Share this post
Report the incident to Ebay.
0
Share this post
Posted (edited) · Report post
BMC 1.5 and 1.8 heater plugs are readily available ASAP Supplies do them for £15 each, Calcutt Marine will sell you a set of four for £28. OK they may not be Champion plugs, (do they still exist?) but both suppliers only seel decent quality sp[ares, so they should be fine.
NOTE:- Check that any you order will fit your engine, as there are at least two variations.
Edited by David Schweizer
0
Share this post
5 minutes ago, David Schweizer said:
BMC 1.5 and 1.8 heater plugs are readily available ASAP Supplies do them for £15 each, Calcutt Marine will sell you a set of four for £28. OK they may not be Champion plugs, (do they stuill exist?) but both suppliers only seel decent quality sp[ares, so they should be fine.
I did try both of these first, they have no stock currently - Calcutt Marine offer a set of 4 with a long drill bit to ream out the holes too, but sadly no stock.
The Champion are surplus so are likely to be quite old...  apparently unused though.
Thanks for the suggestion though - I'd prefer supporting the 'boaty' places whenever possible.
Edited by Ratkatcher
Typo, oops!
0
Share this post
Hi,
Are you sure your glow plugs are cream crackered? I have a 1986 boat with a 1500 BMC and recently planned to replace my plugs. On removing them  and reaming out the glow plug hole (11/64 inch drill or metric equivalent (best go for slightly smaller)) I found that there was a lot of carbon. The resistance of a new Champion CH32 is approx 2 ohms - easy to check with a multimeter and all my plugs were close to this. There is lots of info about checking glow plugs on You Tube
The plugs are now replaced and starting is a lot better.
Share this post
15 minutes ago, alvicchas1 said:
Hi,
Good point, they do last a long time, but getting them out can be a challenge, as it is easy to break the thin heater shroud. The best way is to undo them a quatere of a turn, and re-tighten, then undo half a turn and re-tighten, then three quarters of a turn and re-tighten, continuing this pattern until they are loose enough to remove without a spanner.
0
Share this post
Good advice. Also when replacing the plugs a smear of copper grease on the threads to help easy removal next time. Make sure that you ream the holes until all the carbon is removed and there is no resistance to moving the drill backwards and forwards in the hole.
0
Share this post
Hi,
Been doing a bit of "googling". www. arc-components.com based in Wakefield have Durite 0-130-12 - listed as a Champion  CH32 equivalents and the website shows them in stock for £15.62 including VAT. Delivery is free for an order over £50. Could be worth giving them a ring.
0
Share this post
16 hours ago, alvicchas1 said:
Hi,
I missed that one!  I spent a long time searching for a supplier with stock of equivalent plugs too...
Bar 1, the glow plugs on the boat must have been out quite recently as they came out quite easily ( I had read the info suggesting the 1/4 turn method and watched a couple of useful youtube videos before tackling the job) and the holes were quite clean - the last had a little carbon in.  (and a Champion plug!)
Heat up time for all of the plugs is around 17 seconds (which seems to be about right) and current draw close to 5 amps (resistance is nearly 3 ohms) each but starting the engine, even with 90 seconds of heater plug on before cranking is difficult.  Once started and warmed up a little it is fine for the rest of the day and starts very easily (turn the key and running in about a second) so the feebly glowing plugs are my first item to tick off.
Any other suggestions what dreadful cold starting my be are most welcome!  I'll be getting the injectors checked as soon as possible too, just in case.  The injector pump was replaced with a refurb unit less than a year ago.
Thanks for all of the the suggestions so far.
0
Share this post
Assuming you have at least 400 psi compression on all cylinders, but I rather suspect you may not.
The BMC 1.5 used pintaux injectors that have a small auxiliary spray hole to one side that is used to direct fuel into the hottest part of the pre-combustion chamber to aid cold starting. These block up over time and occasionally am idiot will fit a pintle nozzle instead of a pintaux. Both cause poor cold starting.
If you can beg, borrow or steal a compression tester I would do that first and report back. Otherwise maybe get the injectors overhauled and tested. Any decent FIE specialist will probably do them on an exchange basis. However take a good look at the manual because their are several parts "down the hole" that may come out with the injector and must go back, the crimped washer and copper washer require renewing.
0
Share this post
I had my injectors tested and repaired recently stopped it smoking but not any better for starting so its time to  check the recently replaced glow plugs to see if they are ok
0
Share this post
I found this:
Manufacturer brand Manufacturer ref.
BERU 0100221101
BERU 0100221136
BERU 112M
BERU GV112
BOSCH 0250200035
CHAMPION AG32
CHAMPION CH32
DELPHI HDS227
HKT B-055
NGK Y-302
Calcutt boats also mention BMC 88G443
which might be of interest for comparison/equivalence.
I also found:
  http://www.ebay.co.uk/itm/4-X-ROVER-MARINA-1-5-D-Glow-Plug/131633076250
which seems almost too good to be true. I've ordered some and will report back.
Share this post
Cheers I have ordered a set as well very cheap but you never know do you?
0
Share this post
Grrr!  I missed that one too :angry:
So I ordered a set as well, just in case, at that price they are a gift and can sit around just in case they are ever needed.
Well spotted, thanks :D
0
Share this post
I saw a 1.5 diesel marina in Malta last month I have to say even the mopeds were overtaking it!!
0
Share this post
Both original Champion glow plugs and the ones from ebay have arrived.  The ebay ones are in individual boxes and very clean, I'm impressed, if I hadn't left my multimeter on the boat it would have been fun to compare resistance of the units.
Will fit one of the sets when next at the boat (after a good cleaning of all the plugholes) and hope that they help :D
0
Share this post
Distance selling rules allow you to send unwanted and unused items back if you're happy with the eBay ones.
0
Share this post
I am tempted to send the other supplier's plugs back, they look like they were pulled from an engine or 2 and look (and measure - I used my coil building deck to measure resistance on the plugs) as tired as the ones already in my engine!
The ebay ones are new, shiny and under 2 ohms resistance so should glow a lot brighter than the champion ones, which could mean easier starting...   That and they were only £15 (a bit less) compared to £72!
A refund is going to be requested I think.
0
Share this post
I have fitted the ebay ones they had .9 ohms resistance and the starting is now instant! 3-4 seconds heat and it fires up, out of the 4 old plugs [replaced last year] one was .9 the other 2 were 20s and one was open circuit no wonder it wouldnt start. Dont know where he got the plugs from but calcutt unfortunately in with a shout. As he had died I will never know the answer. I have ordered a set for my mate as well as I am so pleased with the result
0
Share this post
0.9 ohms is more consistent with Tony Brooks' experience than 2 ohms
  http://www.tb-training.co.uk/marinee07.html
It does highlight an issue with the size of cable to drive the glow plugs and starter switch current capability.
0
Share this post
Strange but the ebay ones were very reluctant to go into my engine, the thread appeared larger so for now have not fitted them. But while I was sitting in the engine 'ole I spent a happy hour or so cleaning out the glow plug holes with a 4mm long drill bit and just a little cussing...   Having removed enough hard carbon to have me searching for any missed diamonds and then replaced the original glow plugs there is already a noticible difference in starting from cold, 45 seconds of heating and the engine starts in a few seconds, very encouraging!
When I am next at the boat I'll have a go at getting the ebay plugs in again, just to see if I was being a little too cautious.
For now well pleased anyway.
0
Share this post
Mine screwed straight in and so did Keiths  both now start with 3 seconds heat mine will even start at tickover! Runs rough but does run, it smokes a bit for about a minute then runs clean.
I am going to remove and sell this engine and gearbox as its surplus, the broads cruiser is going to be converted to electric as for me this is the way forward
0
Share this post
I know this is quite a bit later than originally posted...
I put the ebay plugs in the engine last Friday, having sat for a little while making sure the plug holes were really clean (surprising how much carbon had built up!) and applied a liberal coating of copper grease to the plug threads they went in almost effortlessly.
Saturday morning, outside temperature about 11c (so the engine was nice and cold) apply heaters for 30 seconds and try to start engine, white smoke, lots of good speed starter rotation but no start.  Another 30 seconds worth and the same result.  The engine did start after cranking for about 20 seconds with the typical cloud of black smoke rapidly clearing to normal (no smoke) running.
My guess is that either I blew a fuse with the new (lower resistance) plugs or made some other newbie error.  No current clamp meter to check if all is well so I'll have to lay my hands on one.  The operating manual for the Thornycraft 90 shows a fuse in the line but gives no sensible indication of where it is located - happy days :blink:
Hopefully next time I am at the boat there will be one of the neighbours around and I can ask then to turn the key to heat while I play with the plugs...
0
Share this post
I suspect that many 1.5s do not have a fuse in the glowplug circuit. Try searching along the main engine harness that runs up to instrument panel for an in-line fuse holder alongside it.
I doubt that you made a error but the oil on the bores may have drained away if the engine had not run for a while so the compression was lower.
Try it with at least 3/4 throttle, sometimes they need that to start reliably.
0
Share this post
I would like to know the voltage as much as the current. The cabling for glow plugs often seems undersized given the expected currents and can account for a modest power loss.
You can get croc-clip style meter probes for those occasions when you need 3 or 4 hands!
0
Share this post
