Nightwatch
New Format
54 posts in this topic
Hi.
i have tried, oh! How I have tried. But, I just can't get my head round the new format.
its been spoilt in a big way, in my humble opinion.
just saying like!
0
Share this post
Its absolutely fine for me. So what are the particular issues for you?
And if you don't like the new theme, why not just select the legacy theme to get it back the way it was?
0
Share this post
I've not had any issues since being advised how to make a personal activity stream.
The further updates have only improved things and I find it easy to use and virtually identical to the the original in terms of functionality.
0
Share this post
I am very pleased by some of the modifications made since the new format was launched - inparticular, the return of "View New Content". At first, this was "View unanswered posts" which meant that, as soon as one posted in the thread, it disappeared from the leader board until someone else wrote something in it.
Last time I looked, which I think was two days ago, the "Find members" feature needed some attention, as there was no provision to insert a member's name or beginning of a name, making finding a particular member unnecessarily difficult.
0
Share this post
28 minutes ago, Jerra said:
I would agree with Cuthound.
Thank you both for the feedback, glad you are finding the site easy to use. Now we have created the 'view new content' stream and set it as default, members should not have create a personalised stream, can still use the 'unread content' steam (including setting it as their default) or create a custom stream as you have, which will remain default unless you opt to change.
10 hours ago, Nightwatch said:
Hi.
I have tried, oh! How I have tried. But, I just can't get my head round the new format.
just saying like!
Nightwatch, I am sorry you are still struggling with the changes. It is not clear if the issue is with the move to the later version from a week ago you are struggling with, or change in appearance we put in place last night following feedback from members, however if there is anything specific you are having issues with I am sure myself and the other staff and members can help getting the site working as you enjoyed before.
Thanks
Daniel
0
Share this post
I'm a bit puzzled by the new View New Content stream. Now that posts stay after they have been read, how long do they remain there or does the list go on growing forever?
Presumably if you actually want them to disappear from the list when they have been read, you need to create an specific new activity stream?
0
Share this post
This is the system which we had before the changes, and it worked well then. You need look only at the first page, which shows the most recent additions, then it shouldn't bother you how many pages there are thereafter.
0
Share this post
Your puzzled?   So am I for a different reason, posts don't stay after I have read them!    How do you make that happen?
0
Share this post
Posted (edited) · Report post
How do I change to "View Items I have not read" ?
I've just worked it out !!!
Edited by Laurie.Booth
i'm a plonker :)
0
Share this post
46 minutes ago, mross said:
Thanks for that but it doesn't quite replicate what the (to me ) original was like.   On that I saw all the new content threads as thread title those I hadn't read had the blue dot those read didn't.
The fix in the TXT document does this but shows all posts not merely the thread.  Is there anyway to get the result I would like (assuming that is I have explained it clearly enough)?
0
Share this post
are you viewing condensed or expanded?
0
Share this post
Ah!  Good point I was viewing condensed I suspect that has changed.   Thank you.
Edited by Jerra
spelling
0
Share this post
It's worth looking at some of the provided streams as they differ from a custom stream with identical filters!
0
Share this post
Thanks
Daniel
A rather appropriate typo in your case Dan!
0
Share this post
I was wrong!   I am viewing in condensed and see individual posts.   Odd.
0
Share this post
53 minutes ago, mross said:
Are you using a custom stream?
I was trying a custom stream and it wasn't doing what I wanted.  I have returned to the "standard" set up and suddenly it seems to show what I would like it to show.
Many Thanks for your attention and help.
0
Share this post
I am very happy with the stream I am now using.  This is not personal to me, it will work for anyone.  canalworld.net/forums/index.php?/discover/261/
Unless I delete it at some future time  :o
0
Share this post
I was not sure what to opt for.
The old 'View New Content' didnt instantly remove threads after you have viewed them, and I feel showing viewed threads is closer to how I found the list to work under V3, as well as perhaps a better compliment to the existing 'Unread Content' stream that was briefly default when we move to V4.
As you say, if you want a 'View New and Unread' stream, you can easily make you own default stream combining both settings.
Both lists are in effect bottomless, you can go back in time and 'new(ish)' and unread content as long as you like, unless you hit 'mark all as read' , but it also does give nice breaks in the list as you toggle over into 'yesterday' 'last week' etc.
As said, before, you can also share a steam, and in fact each one including the custom 'default' we have added called 'veiw new content' have their one stream number.
Daniel
0
Share this post
It's bloody insane that all this pishing about is necessary to get back what we had before with no effort required.
Re-inventing the wheel was easy compared to subscribing to CWf these days.
0
Share this post
15 hours ago, MJG said:
Why is it so 'clunky' on an iPad when scrolling?
Its one of the improvements to the new software, silly!
0
Share this post
To an extent I agree, Invision should have made it easier for us to perform the major version update, without change in the functionality of the 'new/unread content' button, and the visual appearance changed a little more than I would have changes it.
That said; the software allows us to create the 'View New Content' stream, which in retrospect we should have role out at the same time, and you do have to keep the visual appearance of a site moving to keep it from looking out of date. That is just a factor of life.
Can you be more specific as to what you mean by 'clunky' Martin? Is this new Shift theme, the 'Legacy' theme or both?
Daniel
0
Share this post
