We're just reached TWO MILLION posts!! Thank you to those who have contributed to Canal World. Read the announcement here
Froggy
Advice sought re. battery replacement
166 posts in this topic
Posted (edited) · Report post
We currently have four 6 volt leisure batteries and they seem to be in a bit of sorry state, with one of them bubbling acid and therefore potentially dangerous. Two of these batteries are Trojan T-105 and the other two appear to be cheaper unbranded alternatives. Due to other ongoing expenses on the boat we're looking to replace these with minimum cost and are thinking of putting in two 12v batteries instead. I'd be grateful for any advice on this and recommendations regarding specific batteries that would be suitable alternatives. As far as i understand the Trojan T-105 batteries have a very high 225ah capacity, giving us a total capacity of 450ah if replaced like for like, compared with probably about half that if replaced with two reasonable quality 12v alternatives, but I suspect we could probably get away with this. We've only been boating for a couple of months and it would be interesting to read the advice of others and to learn what set-ups they use themselves.
Edited by Froggy
0
Share this post
Best would be full traction. Second best would be semi-traction like the T105s. Third best would be Gel. Fourth best would be wet lead-acid.
How long they would last will depend entirely on how well you look after them but cheap lead-acid are unlikely to give more than 2 years service even with the best of care.
You might like to check out this thread: http://www.canalworld.net/forums/index.php?showtopic=89391#entry1947906
0
Share this post
We currently have four 6 volt leisure batteries and they seem to be in a bit of sorry state, with one of them bubbling acid and therefore potentially dangerous. Two of these batteries are Trojan T-105 and the other two appear to be cheaper unbranded alternatives. Due to other ongoing expenses on the boat we're looking to replace these with minimum cost and are thinking of putting in two 12v batteries in instead. I'd be grateful for any advice on this and recommendations regarding specific batteries that would be suitable alternatives. As far as i understand the Trojan T-105 batteries have a very high 225ah capacity, giving us a total capacity of 450ah if replaced like for like, compared with probably about half that if replaced with two reasonable quality 12v alternatives, but I suspect we could probably get away with this. We've only been boating for a couple of months and it would be interesting to read the advice of others and to learn what set-ups they use themselves.
Is yours a 12 or 24 volt system?
0
Share this post
If I were the OPs I'd replace them with 4 Trojan T105s. 2 x 110Ah 12v batteries only allow a useage of 110Ah if you don't want to go below 50% State of Charge.
0
Share this post
It's a 12 volt system.
The trouble is, the T105s would cost about £600 compared with less than £200 for two 110-120ah 12 volt batteries. Unless the engine was run every day to keep them maintained wouldn't the T105s become an expensive luxury? One, moreover, that we can't really afford given other expenses on the boat.
0
Share this post
I have 3 x 110 Ah Exide open cell wet lead acid leisure batteries on a holiday boat and so far I have had three or four years out of them so far but then I do try to look after them. They are not the cheapest but cost less than £100 each (I think it was around £75 but can't find the invoice).
You say that money is tight so as long as you buy towards the quality end of the price range, have enough capacity and also sufficient charging I feel wet leisure batteries (12V) will be fine for at least two years. Remember however much you spend on a battery of whatever type you will kill it just as easily if you over discharge them and never fully charge them.
As long as you keep them near fully charged batteries with pocketed plates will usually last longer than non-pocketed and AGMs will probably have a longer life than open wet cells. The pockets or the wadding in an AGM help to keep the plate material on the plates so its harder for it to drop off and short the bottom of the plates.
It is really all about you balancing battery life, your way of using them and what you can afford. Perhaps we do not all want to risk damaging expensive batteries so are happy with cheaper ones that have a shorter potential life nad may well be far easier to diagnose when faults occour.
Share this post
I am of a similar opinion because, although we are on the boat at least part of each week, it's not 24/7 and therefore it won't be possible to run the engine ever day. Additionally, i can't help thinking that running an engine daily just to charge batteries, with no cruising involved, is likely to cause more wear and damage to the engine than the cost of replacing batteries, even on an annual basis.
If there were 6 volt batteries available that were considerably cheaper than the T105s i might reconsider going for 12 volt alternatives.
Alpha batteries seems to be a major online supplier. If anybody can point me to cheaper alternative sources I'd be grateful.
Edited by Froggy
0
Share this post
Yes it's a pity T105s have got much more expensive recently. I suppose it's an exchange rate thing since they are American. If it were me I'd try to get 2 x T105s rather than 2x wet leisure batteries but you can only afford what you can afford, and as has been said you don't want to get expensive batteries and then spoil them in quick time by undercharging them. So on balance you are probably best with medium priced leisure batteries.
0
Share this post
That's an interesting alternative that would then allow us to add two more at a later date. The attached picture shows our current battery configuration. Which leads would I bypass if I just connected two (or, for that matter, if I replaced with two 12v batteries)?
I'm thinking of buying 3 of these. Looked after, I hope they would last 3 or 4 years.
http://www.ebay.co.uk/itm/111004481874?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The 4 year warranty on those is interesting. Surely such warranties come with a lot of strings attached and you can't just neglect the batteries and then claim replacements?
0
Share this post
Mine lasted 3years but that was with shore power and kept at or near 100% most of the time.....
Ill say no more on that.
I replaced them with some of these
https://www.batteryservicehub.com/batteries/pegasus-traction-batteries/pb-flat-plate/
Specificaly the PB12130S
Cost about £350 for 3 if my memory is working.
Edited by Loddon
0
Share this post
But 2 XT105's would give you about the same Ah for about £250 and would probably last twice as long as your also ran's
Share this post
Correct. The warranty usually covers manufacturing defects, not abuse.
Only if correctly charged. You can kill Trojans almost as fast as cheap batteries.
0
Share this post
I would suggest the first thing you do is disconnect the pair with the falt cell in it and see how the other two perform, they may still be good enough to last you a bit longer. At the same time check the condition of all the connections onto the batteries.
0
Share this post
So, please correct me if I'm wrong, looking at the photograph in post #12, if I was to replace the existing batteries with two T105s, the positive and negative leads in the far right of the photograph leading down to the engine bay would remain as in the picture (i.e. the positive lead to the positive terminal of battery 4, being the battery on the far right, and the negative lead to the negative terminal of battery 3), as would the short lead linking the positive terminal of battery 3 with the negative terminal of battery 4, and all other leads would be removed, am I right?
0
Share this post
Yes. Exactly so.
Note that if you have only 2 batteries when BSS comes along you'll need to fill the empty space with something (piece of wood or maybe old batteries) to mechanically secure the 2. It'll fail if the batteries could slide around.
0
Share this post
Yes. Exactly so.
Thanks for the advice re the battery space since the BSS is impending. It's a long time since I studied connecting batteries in series and parallel at school, and I don't understand how the current is flowing in this circuit. With the bank of four in the photograph, the current presumably flows from the positive of battery 1 via the short lead to the negative of battery 2, then via the positive of battery 2 straight to the engine bay via the terminal on battery 4 and back to battery 1 via the negative leads. So how are batteries 3 and 4 involved in the circuit?
Edited by Froggy
0
Share this post
I suspect that all the batteries have been in the boat for some while, but it might be worth a try, and yes, the lead terminals definitely look as though they need a good clean up!
0
Share this post
Series is simple. Pos from batt 1 to Neg of batt 2. You now have 12V between Neg of batt 1 and Pos of batt 2.
If you have another pair (3 & 4) you connect the top Pos's together and the bottom Negs together and you've put them in parallel.
Paralleled batteries will (if of equal size and charge) split the load 50:50.
(Three bats in parallel will share the load 33:33:33, Four 25:25:25:25 etc)
0
Share this post
My bet would be the battery bubbling acid is one of the unbranded ones.
As already suggested, try disconnecting the unbranded ones and running on the Trojans alone. They might outperfom the bank of four once you remove the one dragging the bank down.
0
Share this post
EDIT: Just in case you're wondering why I had to edit the above sentence, it was to configure the smiley correctly! laugh.png
Edited by Froggy
0
Share this post
Ok, so just a bit of spanner work that costs nothing!
It may or may not work, but read some threads on here about deslphating the Trojans to maximisae their performance.
0
Share this post
In the OP's photo the load would be more equally shared between the two pairs of batteries if the red wire to the rest of the boat was connected to the other end of the long red bridging link. i.e. move the wire arrowed to connect to the terminal circled.
Share this post
To operate with 2 T105s you would just "cut down the middle" ie remove the two LH batteries and disconnect and remove the long leads that link the LH and RH pair.
If you want to run two 12v batteries you just connect their +ves together, connect their -ves together, and connect the long leads from the boat to a +ve on one battery and the -ve on the other (to help balance the current flowing in and out of the batteries).
Share this post
  • Similar Content
    • By firstboat
      What should a new boat DIYer read whilst working on their project?
    • By purple8
      So..
      for the last few days our engine has been kicking out white fumes from the exhaust and seeming much noisier from it too. So thinking it could be water in the fuel I drained both fuel filters and continued on our way. The smoke returned 15mins into cruising and even spat out a little black when going astern into the locks. So We gave her a rest. By the morning our starter battery didn't have enough charge to turn over the engine and we had to charge it from our genny. Even tho we have the starter isolated all the time when not running? The battery isolator is new from amazon? But we remove the key so surely that cannot drain it?
      today we charged the starter off the genny and eventually got her started. She blew white smoke for the hour and a half cruise to bedwyn and we stopped. We decided we could try checking the valve clearances, not easy as we couldn't find the tdc for each valve. But then after only 2 hours moored the engine again wouldn't tick over! And each time the key turned in the ignition you could watch the battery voltage dropping on the starter and even on the leisure battery readers.
      we are baffled! I am guessing they are two separate issues, the smoke and the batteries draining. But it feels so coincidental to all happen at once.
      any advice or ideas would be great. Or anyone near bedwyn on the k&a willing to help would be great too!
    • By Pete of Ebor
      Just a shout to the battery experts on the forum. I know it's not a boat, but my firend's mother's car would not start so I went round to jump start it. out of curiosity, I put a voltmeter on it just to see what it said.. it said 9.1V ! I don't know if it is any special type (eg Calcium silver.. or bog standard Lead) but at 9.1V, is it likely to be trashed ? The car did jump start OK, and was left running for 20 mins before I had to go. She did take it for a run later that day and it started OK.
    • By Pompey
      Hi All,
      I have a ford 1.8xld with Bosch alternator, also the boat has a smith industries tacho, which has never been connected. I have searched and found links from other sites, as I understand it the Tacho is wired to ground and to the 'W' terminal of the alternator. See pics.
      As you can see from the alternator picture, the 'W' terminal appears to be missing, I am assuming that I will have to connect my own terminal her, probably by soldering. Is this correct ?
      The second picture is from the back of the Tacho. Assuming this is the wiring diagram, single ind is a single alternator setup, dual ind, for a dual alternator setup. So if I am reading correctly, 'W' connector from alternator, to pin 1 of Tacho, pin 2 of Tacho to Ground. And now if I wanted to connect the second Alternator, then the same for pins 3 and 4 ?
      If any one can just confirm or deny, been a while ( 18 years ) since working on this type of equipment.
    • By jono2.0
      Hello,
      First post here so please be gentle! haha
      OK, I'm literally weeks away from getting my 60' sail away. I will be a continuous cruiser liveaboard and regularly moving around the canal and river waterways. Engine is a Canalline 42 with 1x 50A and 1x 175A Alternators. I'm planning on getting a Webasto water heater/boiler too to compliment multi fuel stove.
      I have done some sums and require around 120Ah a day for things like, 12v fridge, pumps, boiler, laptop, TV, lighting, phone charging etc. (Actual is 80Ah but I wanted a good amount of wiggle room).
      I'm planning on filling my roof with solar and would like to use Victron equipment (apart from solar).
      I'm planning on:
      5x 285w Monocrystalline Solar Panels totalling: 1425w (It has an approx 42' cabin / roof space) 1x Victron SmartSolar 100A MPPT Solar Charge Controller 1x Victron BMV-700 Battery Monitor 1x Victron SmartSolar LCD display 1x Victron Multiplus 1600VA Inverter 70A charger 16A relay 12V I'd like to use solar as much as possible to power my needs but haven't decided upon batteries just yet. I'd like your comments on qty and type of batteries I'd need to keep everything tip-top, if I'll need a generator for the winter months (likely Honda EU2.0i using LPG). Is the above all too overkill or will I struggle in the depths of dark winter? I would like to use a washing machine every so often but if batteries would get hammered I can use Generator for that. (obviously not on hot washes). I'll be getting an electrician to do the install (apart from solar panels on the roof). Thanks Jono
