Roxylass Posted January 14, 2017 Report Share Posted January 14, 2017 Bought a sump pump as i couldn't get the drain plug on the box. Used the pump till it was sucking nothing. Refilled with fresh oil ep 80/90. Started the engine up let it run five minutes. Took the gear box cover of and the oil is the same colour As the emulsified oil that i had just removed. Link to comment Share on other sites More sharing options...
bizzard Posted January 14, 2017 Report Share Posted January 14, 2017 (edited) Bought a sump pump as i couldn't get the drain plug on the box. Used the pump till it was sucking nothing. Refilled with fresh oil ep 80/90. Started the engine up let it run five minutes. Took the gear box cover of and the oil is the same colour As the emulsified oil that i had just removed. If its been submerged it'll need flushing a couple or more times. If its a LH 150 box be very careful with the top plate gasket, its crucial that its not damaged. They are also quite expensive. Edited January 14, 2017 by bizzard Link to comment Share on other sites More sharing options...
Creel Posted January 14, 2017 Report Share Posted January 14, 2017 Bought a sump pump as i couldn't get the drain plug on the box. Used the pump till it was sucking nothing. Refilled with fresh oil ep 80/90. Started the engine up let it run five minutes. Took the gear box cover of and the oil is the same colour As the emulsified oil that i had just removed. had this on my gear box had to renew the oil seals front and back Link to comment Share on other sites More sharing options...
mayalld Posted January 14, 2017 Report Share Posted January 14, 2017 If its been submerged it'll need flushing a couple or more times. I'd also suggest using something lighter than the EP80/90 for flushing. Trying to flush with thick oil may not get round all the galleries to loosen the emulsified oil. Give it a good overfill with straight SAE 20 and run in forward and reverse until warm. Then drain, add EP and repeat. Fill correctly with the correct grade and start using the box. May need to be repeated a few months later. Link to comment Share on other sites More sharing options...
bizzard Posted January 14, 2017 Report Share Posted January 14, 2017 I'd also suggest using something lighter than the EP80/90 for flushing. Trying to flush with thick oil may not get round all the galleries to loosen the emulsified oil. Give it a good overfill with straight SAE 20 and run in forward and reverse until warm. Then drain, add EP and repeat. Fill correctly with the correct grade and start using the box. May need to be repeated a few months later. Yes, I use a 50/50 mix of paraffin and cheap engine oil and run engine slowly in gear gently changing now and then between fore and aft gears for about 10 mins, drain out and repeat if needed. The paraffin cleans everything up nicely too. Some folk do a diesel fuel mix which I'm not keen on, clutches seem to slip a little for a while after using it. Link to comment Share on other sites More sharing options...
bizzard Posted January 14, 2017 Report Share Posted January 14, 2017 Yes, I use a 50/50 mix of paraffin and cheap engine oil and run engine slowly in gear gently changing now and then between fore and aft gears for about 10 mins, drain out and repeat if needed. The paraffin cleans everything up nicely too. Some folk do a diesel fuel mix which I'm not keen on, clutches seem to slip a little for a while after using it. Also while the top plate is off I'd check and adjust both fore and aft adjustments, bet yer life they've never been done. Link to comment Share on other sites More sharing options...
RLWP Posted January 14, 2017 Report Share Posted January 14, 2017 I'd also suggest using something lighter than the EP80/90 for flushing. Trying to flush with thick oil may not get round all the galleries to loosen the emulsified oil. Give it a good overfill with straight SAE 20 and run in forward and reverse until warm. Then drain, add EP and repeat. Fill correctly with the correct grade and start using the box. May need to be repeated a few months later. Diesel is much cheaper for flushing out with Richard Link to comment Share on other sites More sharing options...
Mikexx Posted January 14, 2017 Report Share Posted January 14, 2017 Some folk do a diesel fuel mix which I'm not keen on, clutches seem to slip a little for a while after using it. Yet diesel has more lubricity than paraffin. Link to comment Share on other sites More sharing options...
Roxylass Posted January 15, 2017 Author Report Share Posted January 15, 2017 So take the gear oil back out. Fill to the highest level on the dip stick with diesel. Run engine for 10-15minutes gently selecting forward-astern. Use the pump to empty then repeat again. Link to comment Share on other sites More sharing options...
RLWP Posted January 15, 2017 Report Share Posted January 15, 2017 So take the gear oil back out. Fill to the highest level on the dip stick with diesel. Run engine for 10-15minutes gently selecting forward-astern. Use the pump to empty then repeat again. Yes. If you use a pump, it isn't easy to get all of the emulsified oil out. If the box has had years of abuse (like many Listers have) it takes a few flushes to shift the oil You are doing the right thing, your gearbox will appreciate it Richard Link to comment Share on other sites More sharing options...
Mikexx Posted January 15, 2017 Report Share Posted January 15, 2017 Bought a sump pump as i couldn't get the drain plug on the box. Used the pump till it was sucking nothing. Refilled with fresh oil ep 80/90. Started the engine up let it run five minutes. Took the gear box cover of and the oil is the same colour As the emulsified oil that i had just removed. The problem is you don't need much water in the oil to form a visible emulsion. Most oils have detergents such that water is slightly miscible with the oil. In the good old days the water would simply stay at the bottom of the sump under the oil. How confident are you that you're truly emptying the sump? I wouldn't like to run the gearbox with just diesel with any sort of load. EP oil is chosen for a good reason. Diesel is not miscible with water. Some years ago I recall a concept where oil-water emulsions kept their lubricating qualities. The issue was stability under high temperatures. However I can't find any info on the web that might support those assertions. By now you would have removed all but the last bit of water. I would be more tempted to buy a cheap 5 litres of EP89/90, say: www.ebay.co.uk/itm/Triple-QX-EP-80w90-Gear-Differential-Oil-5-Litre-5L-GL-5-/231098794321 And after each time making the gearbox work and making sure it gets hot, empty and refill. Link to comment Share on other sites More sharing options...
Roxylass Posted January 15, 2017 Author Report Share Posted January 15, 2017 Took three flushes moving the gear lever ahead and astern 15min each flush. Didn't want to come out of ahead first few times persevered with it. Slipping in and out of gear no problem now. Checked the oil on the dip stick not a drop of emulsified oil to be seen. Many thanks for all the excellent advice. Kind regards. Link to comment Share on other sites More sharing options...
RLWP Posted January 15, 2017 Report Share Posted January 15, 2017 Took three flushes moving the gear lever ahead and astern 15min each flush. Didn't want to come out of ahead first few times persevered with it. Slipping in and out of gear no problem now. Checked the oil on the dip stick not a drop of emulsified oil to be seen. Many thanks for all the excellent advice. Kind regards. Good stuff! Richard Link to comment Share on other sites More sharing options...
