Roxylass Posted January 6, 2017 Report Share Posted January 6, 2017 I need to change the gear oil for the above engine. The smell tells me that it is ep 80 90 in it. It should be 20w50 instead Can you tell me where the drain plug on this gear box is I know that it is on the bottom but it is connected to the engine I am lying on the deck feeling about Thanks in advance. Link to comment Share on other sites More sharing options...
Nightwatch Posted January 6, 2017 Report Share Posted January 6, 2017 In my,limited, experience drain plugs are rarely used to remove oil from a gearbox. The filler can is used with an oil extractor pump. Link to comment Share on other sites More sharing options...
bizzard Posted January 6, 2017 Report Share Posted January 6, 2017 (edited) Is the gearbox a Lister LM100 OR LH150 or has it been fitted with a Hurth gearbox which were later fitted when Lister discontinued the former two. Anyway, if it is either of the Lister boxes the drain plug doesn't screw upwards into its bottom like most, it is screwed into the gearboxes front casting, the circular part that attaches to the engine via its front plate. The plug is situated underneath in the centre of this front circular part of the casting and is screwed in facing forward at 90 degs from vertical. Hypoy EP 80/90 gear oil is fine for both Lister boxes. Edited January 6, 2017 by bizzard Link to comment Share on other sites More sharing options...
Tony Brooks Posted January 6, 2017 Report Share Posted January 6, 2017 See above, especially as if its the Lister box (which it may well be with EP 80 oil in it) it could well have a separate reduction box that will also need draining and refilling. If you do not know a photo will solve it or a description of its shape. Link to comment Share on other sites More sharing options...
mross Posted January 6, 2017 Report Share Posted January 6, 2017 (edited) Can you tell me where the drain plug on this gear box is If you can't see it I suggest you use the camera on your phone to take photos from a few different angles. I often do this when I need to see details that are awkward to get at. My varifocal lenses make it impossible to see fine detail unless it's in front of me. If you photograph the gearbox nameplate and post the maker and model number someone is bound to know the answer you seek. Edited January 6, 2017 by mross Link to comment Share on other sites More sharing options...
Roxylass Posted January 6, 2017 Author Report Share Posted January 6, 2017 The gearbox is lm 100 I have the st 4 which is identical as a spare I managed to locate the drain plug on that one. Tried with the spanner to undo the drain plug on the box drip tray in the road plus no room for leverage. Try a socket tomorrow with a short bar. Let you know what happens. Link to comment Share on other sites More sharing options...
Tony Brooks Posted January 6, 2017 Report Share Posted January 6, 2017 If there is something that looks like a sort of oval /off heart shaped box thing between the gearbox itself and the coupling it is a reduction box with its own drain, filler and dipstick. Link to comment Share on other sites More sharing options...
bizzard Posted January 6, 2017 Report Share Posted January 6, 2017 (edited) The SL4 and LM100 gearboxes are not identical. The rear end of the castings are different, where the reduction box fits on. The LM 100 box uses a different, beefed up reduction box which attaches with 7 studs and nuts. The SL4 boxes reduction box, although similar is not so hefty and is attached to the gearbox with only 4 studs and nuts. The SL4 box and reduction gear was really only intended for use with the lower powered SL engines. LM100 and red/gear is intended for the more powerful SR or ST engines. If it is identical its probably an LM100 box with a SL4 top cover plate which would fit. The reduction box is the give away. The actual drop of an LM reduction box is about 1/2'' more than a SL reduction box. Meaning both 2.1 reduction boxes, that is. Edited January 6, 2017 by bizzard Link to comment Share on other sites More sharing options...
Roxylass Posted January 6, 2017 Author Report Share Posted January 6, 2017 Where the drain plug is the fan shroud sits almost directly above. So I don't know if it has a reduction box Can't really see past the shroud. Link to comment Share on other sites More sharing options...
RLWP Posted January 6, 2017 Report Share Posted January 6, 2017 Reduction box is where the propeller shaft attaches And EP80 is the correct oil Richard Link to comment Share on other sites More sharing options...
bizzard Posted January 6, 2017 Report Share Posted January 6, 2017 Where the drain plug is the fan shroud sits almost directly above. So I don't know if it has a reduction box Can't really see past the shroud. The reduction box is at the other, back end where the prop shaft is attached. You may or may not have one, it is nothing to do with the engine end of the gearbox where the main gearbox drain plug is, which is under and just behind the fan housing. Link to comment Share on other sites More sharing options...
Roxylass Posted January 6, 2017 Author Report Share Posted January 6, 2017 I shall try and post pics tomorrow if i can figure out how to. Link to comment Share on other sites More sharing options...
Roxylass Posted January 6, 2017 Author Report Share Posted January 6, 2017 I know how to take pictures i know how to send them. I just need an address to send them to. Link to comment Share on other sites More sharing options...
mross Posted January 7, 2017 Report Share Posted January 7, 2017 You need to 'share' them to Google Drive, Imgur or similar and then post a link here. You can also add to the CWDF 'Gallery' and link to that. Link to comment Share on other sites More sharing options...
BWM Posted January 7, 2017 Report Share Posted January 7, 2017 Use the 'more reply options' button, this will allow you to attach pictures. Link to comment Share on other sites More sharing options...
Roxylass Posted January 7, 2017 Author Report Share Posted January 7, 2017 Test Link to comment Share on other sites More sharing options...
Roxylass Posted January 7, 2017 Author Report Share Posted January 7, 2017 Pictures at last. Link to comment Share on other sites More sharing options...
Roxylass Posted January 7, 2017 Author Report Share Posted January 7, 2017 Another one. Link to comment Share on other sites More sharing options...
RLWP Posted January 7, 2017 Report Share Posted January 7, 2017 No reduction box on that gearbox Richard Link to comment Share on other sites More sharing options...
Roxylass Posted January 7, 2017 Author Report Share Posted January 7, 2017 Picture of boat Link to comment Share on other sites More sharing options...
RLWP Posted January 7, 2017 Report Share Posted January 7, 2017 Have you got a picture of the engine too? Richard Link to comment Share on other sites More sharing options...
Roxylass Posted January 7, 2017 Author Report Share Posted January 7, 2017 Can't even get a socket on to the drain plug. Have to get a sump pump. To dark up here now will post a few tomorrow. Link to comment Share on other sites More sharing options...
Roxylass Posted January 8, 2017 Author Report Share Posted January 8, 2017 Pics of engine. Link to comment Share on other sites More sharing options...
RLWP Posted January 8, 2017 Report Share Posted January 8, 2017 Thank you. I like the anti-rattle spring on the hand start chain Richard Link to comment Share on other sites More sharing options...
Roxylass Posted January 8, 2017 Author Report Share Posted January 8, 2017 Would the sl4 gear box now do as a spare since there is no reduction box Link to comment Share on other sites More sharing options...
