Gleniffer DB2 rebuild
RLWP
An occasional series on an unusual engine...
I've just had the block of this engine stitch welded to remove a long frost crack. It's a process I have heard of, this is my first experience of having this done:
I'm very impressed!
Richard
I'm very impressed!
Richard
Ok why that method, rather than what I would consider a normal looking weld?
Welding cast iron is hard because it is a brittle material. If you just run a weld, as the bead cools, it puts the surrounding metal into tension and cracks it. There is an alternative method, which is to get the area to a red heat, then weld it.
Richard
Edited by RLWP
Richard
Ok I didn't know that was cast, I am aware cast is not easy to weld, I can see the point now, thanks
I'm very impressed!
Richard
Way back early 60's the water jacket on my "Seffle" was frost cracked,( that way on purchase) a friend of mine was one of the first (as far as I know) to take on the method of repair which AFAIK was then a sort of franchise,he continued for many years & did many repairs & didn't hear of any failures & the "Seffle" still going in Jem bates"s boat
Nice. Was this a cold process?
Not trying to be klever. but when it is cold, I thought it just "stitched" and not "welded" so I am interested to know if there are other processes.
I wish I knew the answer!
Richard
One of these car make over programmes had an engine block stitched. An old MG if I remember.
I think they showed the process.
I 'think' the programme is/was Car SOS or summat.
Martyn
Edit. Just looked it up. Car SOS. Channel 4. I think it was a MGA.
Edited by Nightwatch
