Davespirit Posted September 17, 2016 Report Share Posted September 17, 2016 Can anyone help.i have a bmc 1.8 after half an hour running it starts racing at 20 second intervals the racing last for maybe 3 seconds then runs fine then 20 seconds later it races for 3 seconds and so on.any ideas. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 17, 2016 Report Share Posted September 17, 2016 Fuel starvation? Phil Link to comment Share on other sites More sharing options...
bizzard Posted September 17, 2016 Report Share Posted September 17, 2016 Anorexia Nervosa. Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 17, 2016 Report Share Posted September 17, 2016 When a hydraulically governed DPA injector pump suffers a drop in internal pressure it is very common for the engine to rev up. The 1.8 normally has such an injector pump so as Phil says the first thing to check is fro a lack of fuel. Either a problem with the supply ranging from blockages, lift pump problems, tap turned off etc. to air leaking into the system. Make sure the fuel tap(s) are fully turned on, check your filters & any water traps, try blowing back down the supply pipe into the tank as first steps. Best also make sure the stop lever on the pump is fully in the run position as well. Link to comment Share on other sites More sharing options...
cereal tiller Posted September 17, 2016 Report Share Posted September 17, 2016 Can anyone help.i have a bmc 1.8 after half an hour running it starts racing at 20 second intervals the racing last for maybe 3 seconds then runs fine then 20 seconds later it races for 3 seconds and so on.any ideas. Check the fuel Tank breather CT Link to comment Share on other sites More sharing options...
Slim Posted September 17, 2016 Report Share Posted September 17, 2016 I'd vote for air in the system Frank Link to comment Share on other sites More sharing options...
Mikexx Posted September 17, 2016 Report Share Posted September 17, 2016 I'd vote for air in the system Possible but I would also have expected uneven running. I would be temped to crack open the banjo holding the leak-off pipe on the fuel filter and bleed any air that might have accumulated on what is the filter return / input side. If there is no air there, then I don't believe it's an "air" problem. Link to comment Share on other sites More sharing options...
Davespirit Posted September 18, 2016 Author Report Share Posted September 18, 2016 Have just run for hour and 15mins after replacing fuel filter and alls good so far.thanks for everyones imput. Link to comment Share on other sites More sharing options...
bizzard Posted September 18, 2016 Report Share Posted September 18, 2016 Racing BMC 1.8? I reckon Mc Laren F1 cars are using them at the moment and not Honda'. Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 19, 2016 Report Share Posted September 19, 2016 Have just run for hour and 15mins after replacing fuel filter and alls good so far.thanks for everyones imput. For goodness sake inspect whatever the fuel filter trapped. If it looks clean then it was probably a mis-fitted rubber seal. If there is a lot of cloudy fuel, water or gritty dirt then the bottom of the tank needs cleaning (at the very leasts) if you find slime and gel like stuff its bug so the fuel tank plus fuel needs urgent cleaning and a biocide used. Link to comment Share on other sites More sharing options...
Dutchie Posted October 5, 2016 Report Share Posted October 5, 2016 I had the same sort of same problem a few years ago only different was the interval from this fault , with mine T90 it came sometimes after an hour , solved the problem with removing the banjo bolt from the fuel filter return line , in the banjo is a very small whole which was blocked with some dirt , clean it with some petrol and blew the dirt out with some air. Problem was over and never came back . Link to comment Share on other sites More sharing options...
