Jrtm Posted July 25, 2016 Report Share Posted July 25, 2016 Anywhere except rn group to get a national air filter its a round cylinder about 4 - 5 inches long by 4- 5 inches wide. Or can i just put any filter in as i have a few round filters i thought i would clean mine and found there isnt one! Link to comment Share on other sites More sharing options...
David Mack Posted July 25, 2016 Report Share Posted July 25, 2016 Our National doesn't have an air filter or anywhere to fit one - air is just drawn in from below the inlet valves. Link to comment Share on other sites More sharing options...
Jrtm Posted July 25, 2016 Author Report Share Posted July 25, 2016 My top all needs new fixings as someone has cut and welded diffrent bits to it. Mine has sort of been turned into a mix or national and rn it has bits of both. Link to comment Share on other sites More sharing options...
DavidLS Posted July 25, 2016 Report Share Posted July 25, 2016 All you need is an air intake, no filter needed though it's best to have the inlet facing downwards. Link to comment Share on other sites More sharing options...
Jrtm Posted July 25, 2016 Author Report Share Posted July 25, 2016 Oh ok just seams odd that i have a box with a removable end and a hole in the side but no filter Link to comment Share on other sites More sharing options...
Bob Tidy Posted September 16, 2016 Report Share Posted September 16, 2016 Some Engines have the top air intake as per RNs Others have a different rocker cover and take the air through a filter box via two manifolds over the inlet valves. David Mack's sounds to have this bit missing. the filter is a washable coconut fibre? pad which should be lightly oiled. I have one but don't know how to attach photo's yet. best view I can find is on the Stockton dry dock site. Bob Link to comment Share on other sites More sharing options...
Bob Tidy Posted September 16, 2016 Report Share Posted September 16, 2016 OOOOOh! didnt expect the link to run!! another view showing the rocker covers. https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjcl7WF7JPPAhXII8AKHXuiCNYQtwIIKjAC&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dvq_gTuqnYqc&usg=AFQjCNG7L-SqztnnKqyQ4WmLpV1Q-aTlJA&sig2=JZpYA9fJ7PG6B5hFAZccyQ Bob Link to comment Share on other sites More sharing options...
Jrtm Posted September 16, 2016 Author Report Share Posted September 16, 2016 I took a bmw round fitler and cut the very blank and off and put the hole end over the hole seams to work well ill take pic tonight So why the 2 designs by national was the side intakes a later development or as parts from rn ran out they developed a new system OOOOOh! didnt expect the link to run!! another view showing the rocker covers. https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjcl7WF7JPPAhXII8AKHXuiCNYQtwIIKjAC&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dvq_gTuqnYqc&usg=AFQjCNG7L-SqztnnKqyQ4WmLpV1Q-aTlJA&sig2=JZpYA9fJ7PG6B5hFAZccyQ Bob This will explain the slightly sticking out round blanks then compared to flat ones on mine Link to comment Share on other sites More sharing options...
Jrtm Posted September 16, 2016 Author Report Share Posted September 16, 2016 My air filter setup Hopefully this will work Link to comment Share on other sites More sharing options...
