Popular Post smileypete Posted January 24, 2014 Popular Post Report Share Posted January 24, 2014 (edited) A useful index of some common CanalWorld Boat Building and Equipment Topics by smileypete A compiled index of some of the topics commonly discussed on Canalworld - the usual technical ones! Hopefully it'll be a handy resource for those with questions, problems or issues in these areas. Or for those wanting to learn a bit more all about this sort of stuff. Also here's a link to a Google Search for CanalWorld Forum: Google Search CanalWorld Forum (Please do link back to this post where it may help in a reply to a question.) Sorted into the following categories: Batteries! - Batt Woes - Batt Monitoring - Charger, Inverter - Alt, Genny - Solar - Lighting - Other 12V - Mains Eleccy Stove, Backboiler - Diesel, Gas Heating - Gas - Pumps - Other Plumbing - Refrigeration Hull, Exterior - Fitout, Interior - Engine - Internet, Wifi, Phone - PC, Lappie, Tablets - Other, Non Boats Please scrooooll down for the relevant category... Batteries! 12 volt battery bank hookups a new set off batteries Adding batterys to a 24 volt bank Advice Re: Traction Batteries Please Assessing The Condition Of A Leisure Battery Bank (Part2!) Balancing the domestic bank. Battery bank wiring Battery cabling Battery replacement Elecsol 220 Battery replacement recommendation in the Rugby area battery replacement tips Bow Thruster Battery Bow thruster battery replacement Can you mix sealed and flooded batteries? How to test and assess a second-hand leisure battery? leisure batteries? Leisure Battery bank connection, SmartGauge and cables. Leoch batteries? Maximum amount a healthy battery can recover after rest? Modern battery technology Need to replace starter battery New T105s safety and care with leisure batteries? Sterling desulphation kit storing old lead acid batteries Trojan batteries Trojan/US Battery's, What next? US Battery XC2200 Victron/battery isolator which batteries? Batt Woes Are my batteries shot? Batteries not holding charge Batteries, what to do next? Battery Issue battery panic-bubbling Boiled Batteries! Can You Explain My Dead Batteries? Exploded battery Flat Battery flat terybat New T105s WTF???!!! Reccommend a battery mechanic Northampton Batt Monitoring Ammeter Batteries and SOC Battery Bank Shunt Wiring Battery monitoring Battery voltage readings. BMV-600 battery monitor help needed Can A Shunt Be Faulty? Confusing Readings Determining the correct ammeters & shunts to buy Digital LED ammeter Fitting Smartbank How to test and assess a second-hand leisure battery? Hydrometer; baffling Mastervolt BTM battery monitor Measuring Amps Measuring consumption? merlin smartgauge battery monitor, how good? NASA battery monitor. shunt needed for victron bmv 501 Smart gauge / smart bank Smart Gauge and Batteries again! Smart Gauge battery Monitor Smartgauge ponderings Smartguage vs Solar Startling electric usage. Sterling power management Tail Current the dark art of battery readings. VDO Ammeter Victron Energy Battery Monitor model 600s HELP!! Voltage Charts / Hydrometer What do battery management systems do and do you need them. When our our batteries full? 4% at what voltage? Will this harm the boat? Charger, Inverter 20amp or 30amp Charger? Alternator Regulator Advice Appreciated Batteries nightmare Batteries permanently connected to charger Battery charger question Battery Charger Recommendations, Please Battery Charging questions Battery Equalistion Battery/Charger Issues Cable size for 1000W inverter (And battery q) Charging 24v Bow Thruster Batteries Charging a whole bank in 8hrs Charging voltage? Cheap Inverters... Dead Mastervolt Charger Dodgy Inverter connections Electrical/ charging problems Faulty charger or Fridge? Fitting Smartbank Having a problem using the washing machine heater installing new batteries and smartguage, and charging Inverter / Charger / Generator Inverter chargers Inverter for fridge Inverter for laptop Inverter Reliability and Service life Inverter to run a washing machine Inverter tripping shore power Invertor Use Mains C/H pump & inverter. Numax charger/ float/ equalise difference and expected behaviour RF earth leakage from Mastervolt combi Shall I charge batteries at a higher voltage during winter? Sinergex inverter Sterling Alternator Controller Failed? Sterling charger question Sterling Combi Low Charger Output Too many volts? Victron charger question Victron Inverter Aborption Light Volt amps? what's next? When is a battery fully charged? Will this harm the boat? Alt, Genny A127 alternator Additional Alternator Alternator and Inverter weirdness Alternator Charging Voltage Alternator loose wire? alternator performing poorly Alternator temperature Alternator w/internal regulator & remote sense Aluminium generator locker lid Can somebody advise me which is the better, generator or engine? Charging batteries with generator Cocoon Generator Cooked wiring from Alternator Energy production logistics Fried Travel Power Generator Grounding Generator wattage for charger How many amps does an engine add to batts New Alternator Advice Needed Please Petrol Generator storage Portable Generator Sizing Power generation Split charge relay Twinning up alternators unhappy generator pulsing Vetus Generator Question. Got me puzzled Victron genny & water pump issue Solar 24v Dual solar panel connection A different approach to solar and batts etc A year of real world solar panel data Another clueless solar power post (sorry) Are these Solar Panels any good? Cable required for two solar panels Electrical voltage drop solar charging battery question! Final decision on my solar panels and controller High voltage readings with solar panels Immersion and Solar Interference from solar power My solar panels are installed....except..... Need help choosing solar gear New Solar Installation Quickie Solar Question Series or parallel for solar Solar controller MPPT or PWM Solar hot water solar hot water systems Solar MPPT Charge Controllers Solar Panel Charging Quirk Solar panel connected direct to battery bank Solar panel connections solar panel tax? Solar panels solar panels Solar Panels... where do I start? Solar performance solor controler wiring Three solar panels, connect in series or parallel? Tilting Solar Panels Tracer mppt wiring connectors Tracer-4215RN MPPT Controller What solar panel should I buy? Whats the difference between mppt and pwm Winter Solar Performance Wiring in solar panels with different voltages wiring solar panels Lighting Changing to LED constant 12 volt supply to lights ? (flickering) L.E.D.s are coming Led Lighting Led Wiring Radio Interference Other 12V 12 volt battery bank hookups 12v Advise needed 12v cabelling advice please 12v circuit problems 12v current limiter to slow 12v fan 12V DC to 14V DC Adapter 12v or 24v? 12v three pin plugs 4 way MAXI blade fuse holder Are bow thrusters worth the money ? Boat Monitoring System Cable size Confused about fuses converting a tv to 12v Fat cables! Ideally 70mm sq Fitting Smartbank Fuse HOW ?*!? much? Is there an alternative? Getting electricity through a bulkhead Glow plug relays High current fuses and circuit breakers High Volts or High Amps? Installing 12v system- advice for someone who can't understand electric Insulating A Bus Bar My Boat Elecrical Plan new water pump Oil filled radiators PWM DC Motor Controller Resettable blade fuse Sky HD+ Box on 12v? Soft Starting My Fridge Startling electric usage. Switching. Another newbie question Too many volts? Volt amps? what's next? Voltage Sensitive Relay Wiring diagram Mains Eleccy 240V Install Advice Needed 240v/12v electrics ideas sought Auto switching from 12v to 240v Best Laptop advice Change over relay Cheap galvanic isolator Consumer Unit Correct RCD Dongle Advice Electric heater for unattended use Electrical/galvanic Isolator Query foil bubble insulation / radiant barrier ?? Galvanic Isolator Galvanic Isolator GI Leak with inverter Having a problem using the washing machine heater in-line electricity meter Installing mains electric Is this electrical cable suitable for my boat? Masterboard for behind fire My Boat Elecrical Plan Quick question RCDs and isolation transformers Shoreline cables shoreline switch Wiring a 240V MCB box Stove, Backboiler 12v circulation pumps Back Boiler Back Boiler and pumped CH Back boiler heating? back boiler set up... Back boiler system design Back boiler/Hot Water problems Back Boiler/How Water Woes..... back boilers Backboiler problems Burning Foraged Wood Calorifier on gravity system Calorifier to stove backboiler Central heating plan central heating pump Circulation pump speed Fireboard packing? Fixing a pumped Back Boiler system Flue advice Gravity fed heating, good but not quite right! Gravity feed system pipe heating yet again Heatproof silicone and high temp stuff in tubes, what's good for stove reassembly? Is a backboiler a good idea? Is there a simpler way... Keeping boiler stove in over night Mains C/H pump & inverter. Morso squirrel back boiler safety help plumbing Quietest CH pump Radiator circuit install Radiator problem Redirecting hot water to rads via stop cock Sfs installation Size of Multifuel Burner Small radiators stove back boiler central heating install Thermocycling questions Thermostatic Calorifier valve Victas Fire Cement Which Fireboard? Why is my heating not working? Diesel, Gas Heating ALDE boiler test and repair job Alde Pump Clatters After Water Temperature Rises Confusion over gas water heaters Diesel Heater Eberspacher for quick heat Eberspacher problems Frost Stat mikuni heater sensor Mikuni issue in newly acquired boat Morco boiler installation Morco D61 or F11 Morco D61 wont fire up Morso gas heater won't light Paloma water pressure problem Paloma woes revisited Professional install of diesel central heating Propex heating unit Replacing Eberspacher fuel pipe coupling Running rads straight from the engine Webaso Thermo Top Z/C WEBASTO ECU WARRENTEE? Webasto Glow Plug webasto installation for heating only Webasto only getting water warm Webasto Thermo 90/s/st Webasto wont start Gas Connection of gas appliances Flexihose on gas cooker Gas bubble tester Gas engineer near Harlow/Roydon area? Gas Fittings gas ovens and hobs... Gas pipe alongside coal stove Gas Pipe Clips Gas piping sizes Gas regulator sizing Gas water heaters Locating a gas leak Propane gas regulators. Low pressure acceptable on boats? Pumps 12v circulation pumps Alternatives to Shurflo water pump? Another broken water pump question... Banging Pressure relief valve bilge pump float sensor bilge pumps Cabin Bilge Pump anyone? float switch bilge pump not working NOW working Flojet Shower drain Pump Fresh water pump. Hot Hot Flojet Water Pump Installing a bilge pump from scratch Jabsco water pump Shurflo Pump Shurflo water pump Victron genny & water pump issue Water pump issues Water pump pressure switch failure Water Pump Problem? Whale Gulper Pump problem Which hose is best for whale gulper 220 pump Other Plumbing 12v gate valve. 15mm required A question of PTFE tape BSP to hose fittings butler/belfast sink waste fitting Calorifier confusion Calorifier Help! Candy Washing Machine Problem Cold water plumbing question Composting Toilets Connecting plastic pipes to copper Expansion Vessel for potable hot water Fitting an immersion heater to calorifier Flexible Sanitry Hose Frost Stat Has anybody installed a urinal on a narrowboat? Help help finding immersion boss Immersion Heater, thermal cut out (not thermostat) LEAK! (plumbing) Morco boiler installation Poppy's Petulant Plumbing (again) Porta Potti 265 repairable? PRV for Calorifier Replacing a radiator valve Replacing Thermostatic Shower Majiggey Smaller Calorifier? Solvent Weld ABS Pipe for Narrowboat Pump out Fittings Storing Heat T port ball valve tecma silent plus toilet Thermostatic Calorifier valve Thermostatic mixer valves for showers on boats....single lever or bar mixer type Thermostatic Shower Mixer Thetford Cassette Twin Calorifiers Water pressure issue Refrigeration 12 v fridge fettling 12 volt Fridge 12 volt fridge problem 12v freezer Circulation for the Fridge? Cooling Fridge with air from bilge. Damn Fridge External Gas Fridge Vent Faulty charger or Fridge? Freezers Fridge Not Turning Off Fridge Power Consumption Fridge/freezer problem. Gas fridge freezer on a boat. LEC 12v fridge misbehaving mysteriously Possible fridge/freezer to suite a boat soft start for fridge/freezer? technical 230v fridge question Hull, Exterior Aberdeen, we have a problem. (What a mess!) Anchor size Best jigsaw blade for cutting through roof Blacking over Comastic with cheaper bitumin. Blanking off a skin fitting Boat Painting Cheap timber supplier? cladding cabin exterior on 70s cruiser Dealing with boatyard/contractors Do you really need windows? Eyebolt for anchor fixing Filling in dents on a fibreglass top Galvanic Corrosion harborough marine GRP roof How Many Ways Can A Boat Sink? New Windows Fitting. overpainting owatrol oil with toplac? Overplating needed 2.5yrs after good survey? Plank Prepping surfaces for painting RCD? Rear Deck Boards removing paint Repairing hatch Replacing the engine cover Romoving rust and sealing around mushroom vents Roof Colour In This Heat Wave.....dark Roofs Must Be Dying? rust bullet Rusting windows screws (stainless steel?) Self Tapping Screws Sikaflex 290DC Deck Caulking some more advice please Toplac paints on wood?? Two painting questions: silicone and rain. uPVC Wheelhouse Vactan vs Owatrol? Waterproofing marineply Welding Equipment What grit to add to deck paint which dehumidifier for CC'er with no electric hook-up?? Window One Way Mirror Film Window Refurbishment Wood on Rails around Cruiser Stern Wood to Metal Would you buy a springer thats been plated How Many Ways Can A Boat Sink? Edited January 25, 2014 by smileypete 14 1 Link to comment Share on other sites More sharing options...
Ray T Posted January 24, 2014 Report Share Posted January 24, 2014 Wow, that's been a labour of love, thank you. Need the mods to "pin it". Link to comment Share on other sites More sharing options...
Popular Post smileypete Posted January 24, 2014 Author Popular Post Report Share Posted January 24, 2014 (edited) Fit out, Interior Adhesives, wood blocks to steel Alternative to Aquapanel for shower construction Bathroom refit Best varnish for indoors and out Boat Monitoring System Composting Toilet Question Custom made spring mattresses. Damp issues Dehumidifier Dehumidifier crystals Dried wood and peeling varnish around windows inside Interior painting mdf v plywood Need advice about sink skin fitting Odor for pump out toilet system Painting Over Tongue-n-Groove Quadrant Shower Refitting costs Retrofitting Insulation Rockwool for welding? rustproofing engine bilges and inside of hull Self fit-out: should I? Shower pod Spray Foam and deck fittings? Spray foam or cavity injection. UFH Under mattress mesh Varnish for Oak Ply Varnishing or wood staining interior woodwork Ventilating Wardrobe Water in cabin bilge- update What Glue to stick wood battens to metal Hull Wooden floor split Measuring Roof Curve? Fire Extinguishers Smoke Alarm Tests When Clocks Go Back smoke alarms Engine Blown head gasket (again!) BMC 1.8 Wiring Diagram or Pre-made loom needed Damp (very) starter motor emergency gasket seals in nuneaton Engine bay repaint. Engine oil My overheating problems. Sensible place to plumb in oil coolers Un-seizing screws Internet, Wifi, Phone 02/. orange . 3 . virgin etc 3 Mobile internet 3G signal boosters 3G wireless routers with an external antenna port. Another .mobile broadband solution. Charging mobile phone external phone connector Getting the best internet connection inside the boat Giffgaff conned us all! Hifi iPhone 3G iOS and apps....... iPhone signal repeater Mobile internet Non Time Limited Broadband Sim? Phone Cable Problematical internet connection on narrowboat resolved Recommendation for internet on boats Sim for dongle T-Mobile "SMPT" code needed for web and walk Wifi WiFi Reception WiFi Signal booster PC, Lappie, Tablets 12v adapter for laptop and good speakers required. 12V laptop adapters Any Top Tips For HP Colour Inkjet Where A Colour No Longer Prints ... Best Laptop advice Best laptop for extended usage on 12v Card readers for on line banking.... Computer problem Computer virus? Dell PC eBay not working in Firefox HP Sleekbook laptop- does anyone have one? Kindle Fire HD £99 Laptop Charging Laptop Power Choices Low wattage pcs Ripping DVD's and playing them.... Tablet Ubuntu and WIN 8 USB Extension cable Which Tablet For "productivity"? Windows 7 Laptop Power Choices Other, Non Boat Another new toy Any Top Tips For HP Colour Inkjet Where A Colour No Longer... Calor Gas Prices 6/1/14 Candy Washing Machine Problem Cheap drill alert! Cheap winter hat on Ebay. Close coupled toilet (domestic not boat) Grrrrrrrr.. Cordless drills DeWalt battery unit recovery Domestic (land lubber) shower cable Domestic Combi Boiler Problem Electric saws Festool battery How Do You Discourage Glis Glis If you thought an Eco fan was expensive.... Issues connecting to the site? Makita BHP453 drill repairs. Metal hulls and GRP hulls Mini Rig Scaffolding poles in a flood Stainless Steel Narrowboat for Sale Supermarket internet shopping deliveries The Thames Tool Box Size and Contents Washing machine making strange noises Weird bicycle freehub Wet Vacuum cleaners Worst insect bite or sting ever Boat Fire Regents Canal Edited January 24, 2014 by smileypete 10 Link to comment Share on other sites More sharing options...
Beaker Posted January 24, 2014 Report Share Posted January 24, 2014 (edited) Someone's already said it, but WOW! Excellent resource. Edited January 24, 2014 by Beaker Link to comment Share on other sites More sharing options...
Paul G2 Posted January 24, 2014 Report Share Posted January 24, 2014 Way to go Smileypete! What a very nice thing to do! Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 24, 2014 Report Share Posted January 24, 2014 Great - but where is the toilet links ? maybe that'll take to long to put together Link to comment Share on other sites More sharing options...
PaulJ Posted January 24, 2014 Report Share Posted January 24, 2014 Nice one Smileypete. Going to be really quiet in here for a while now as everyone is going to be reading.. Link to comment Share on other sites More sharing options...
keble Posted January 24, 2014 Report Share Posted January 24, 2014 yay! Link to comment Share on other sites More sharing options...
Rebotco Posted January 24, 2014 Report Share Posted January 24, 2014 Superb. Have a greeno! Just need your original post pinned to find in future. Link to comment Share on other sites More sharing options...
Simple Things Posted January 24, 2014 Report Share Posted January 24, 2014 SmileyPete you are legend.... Link to comment Share on other sites More sharing options...
system 4-50 Posted January 24, 2014 Report Share Posted January 24, 2014 Sorry, this is out of order. This is a discussion forum, not a wiki. You are guilty of being helpful in a non-conversational manner. On the step with you. (and a greenie for your efforts) Link to comment Share on other sites More sharing options...
DHutch Posted January 25, 2014 Report Share Posted January 25, 2014 Pinned, and mirrored over into the FAQ section. A great resource. Daniel Link to comment Share on other sites More sharing options...
Bettie Boo Posted January 25, 2014 Report Share Posted January 25, 2014 WOW Somehow a greenie isn't enough for all that effort and thoughtfulness, but have one anyway along with a heartfelt big Thank You from Dave & I. Ta B~ Link to comment Share on other sites More sharing options...
davidc Posted January 25, 2014 Report Share Posted January 25, 2014 (edited) Very helpful but sorry. You miss the point of the forum, many members as well as new ones , when posting a problem already have a good idea how to solve it but due to several reasons including confidence, post for reassurance that there are right are have understood there google answer correctly, that is the strength of the forum .not as a techinal site. and if you think on it all Gibbo's technical answers or on his company site but we still say if Gibbo was here he would help I rest my case Edited January 25, 2014 by davidc Link to comment Share on other sites More sharing options...
KJT Posted January 25, 2014 Report Share Posted January 25, 2014 Very helpful but sorry.You miss the point of the forum, many members as well as new ones , when posting a problem already have a good idea how to solve it but due to several reasons including confidence, post for reassurance that there are right are have understood there google answer correctly,that is the strength of the forum .not as a techinal site.and if you think on it all Gibbo's technical answers or on his company site but we still say if Gibbo was here he would helpI rest my case Well, of course there is nothing to stop any forum member starting a thread to deal with any specific issue if they feel that would be more appropriate, for whatever reason. I think smileypete has done a wonderful job of compiling a list of these threads. I am sure many will find it very useful. Thanks smiley! Ken Link to comment Share on other sites More sharing options...
StarUKKiwi Posted January 25, 2014 Report Share Posted January 25, 2014 Wow that is awesome (if I could give a greenie off my phone, I would - so a virtual one till I'm on the laptop later) Link to comment Share on other sites More sharing options...
rubblequeen Posted January 25, 2014 Report Share Posted January 25, 2014 thank you Link to comment Share on other sites More sharing options...
Tom Richmond Posted January 25, 2014 Report Share Posted January 25, 2014 Brilliant! Thank you. Link to comment Share on other sites More sharing options...
bargemast Posted January 25, 2014 Report Share Posted January 25, 2014 (edited) Great stuff Pete, thank you very much for all your time to produce this very extensive list. Peter. If I find out how to give you a greeny, you'll get one. Edited January 25, 2014 by bargemast 1 Link to comment Share on other sites More sharing options...
tree Posted February 7, 2014 Report Share Posted February 7, 2014 Smiley Pete you ruddy star tankies very muchly for all your hard work making it 'simples' for even a confuddled moi . moi would even give you her last 'rolo' adn thats going some so have given you a greeny thingymebob ... treescrunching huggles from a boatfitter-outer apprentice Link to comment Share on other sites More sharing options...
BlueStringPudding Posted February 7, 2014 Report Share Posted February 7, 2014 Thanks Smiley Link to comment Share on other sites More sharing options...
Terryb Posted January 26, 2015 Report Share Posted January 26, 2015 Top Bannana Nice one Smileypete. What a Goldmine of info here for newbies like me. THank you SOooooooooo Much. Link to comment Share on other sites More sharing options...
