spikesy Posted September 11, 2013 Report Share Posted September 11, 2013 It as been recommended that the bottom of the boat should be blacked (57 ft) when next blacking is due, which is quite soon. the problem I have is that the boat sits on rest bars in the bottom of the dry dock, so three sections, about a foot wide cannot be blacked. I was thinking of jacking the boat while I reset the rest bars, but I am a bit concerned about the boat slipping while on the jack, and what sort of supports to use like axle stands, and how to stop the boat sliding backwards. Does anyone else have this problem, and how did you get round it?, and would one jack at the bow be OK , or should I use two jacks and a stretcher plank. Any advice much appreciated. Link to comment Share on other sites More sharing options...
RLWP Posted September 11, 2013 Report Share Posted September 11, 2013 We don't black the bottom of our boat. Is this a surveyors recommendation by any chance? Richard Link to comment Share on other sites More sharing options...
Guest Posted September 11, 2013 Report Share Posted September 11, 2013 It as been recommended that the bottom of the boat should be blacked (57 ft) when next blacking is due, which is quite soon. the problem I have is that the boat sits on rest bars in the bottom of the dry dock, so three sections, about a foot wide cannot be blacked. I was thinking of jacking the boat while I reset the rest bars, but I am a bit concerned about the boat slipping while on the jack, and what sort of supports to use like axle stands, and how to stop the boat sliding backwards. Does anyone else have this problem, and how did you get round it?, and would one jack at the bow be OK , or should I use two jacks and a stretcher plank. Any advice much appreciated. Our boat is being blacked next month and we aren't having the base plate done as I understand the vast majority of boats don't and that it's not a requirement really and will be readily removed as you bump along the bottom in some of the shallower bits. Link to comment Share on other sites More sharing options...
spikesy Posted September 11, 2013 Author Report Share Posted September 11, 2013 Thank you for the reply's, Your right,this is a surveyors recommendation, but I know a couple of boaters that have done it and they said they got a lot of rust off the bottom and was worth doing. I have never black the bottom in the past though I am now wondering if I should. Link to comment Share on other sites More sharing options...
Timleech Posted September 11, 2013 Report Share Posted September 11, 2013 Blacking the bottom (occasionally - not necessarily at every docking) is often recommended for older boats with thinner bottom plates than are currently fashionable - especially if there is evidence of significant pitting. Usual practice is not to worry too much about the areas obscured by the bostocks, but to try to make sure the boat sits in a slightly different place at the next docking. Yes jacking up and moving stands is quite feasible, but I suggest you get advice from someone (the dock operator?) who has experience of doing it and can see the actual setup before trying. Tim Link to comment Share on other sites More sharing options...
bigste Posted September 11, 2013 Report Share Posted September 11, 2013 Whilst a base will always rust it is not a big problem. In order to rust the metal needs oxygen. There is little oxygen down there but at the waterline is the worst place. Link to comment Share on other sites More sharing options...
RLWP Posted September 11, 2013 Report Share Posted September 11, 2013 A surveyor will almost always recommend blacking the bottom as it is better than leaving it unpainted. But - how much better, and is it cost effective? If you discuss that with your surveyor you may get a different answer Richard Link to comment Share on other sites More sharing options...
Bobbybass Posted September 11, 2013 Report Share Posted September 11, 2013 If you have pitting...its an even more comprehensive job.....as simply rolling ( in my experience) makes it worse. You end up with a skin over the pit and there is air trapped in it. You would have to work the black well down into every single pit...with a brush. I've done it...I paid a boat yard to do it once..its nasty..the boat yard said its nasty. Prepare to get well covered..hair....eyes...head.....sense of humour.. Link to comment Share on other sites More sharing options...
pooie4 Posted September 11, 2013 Report Share Posted September 11, 2013 Hi , I've just bought a boat , the surveyor said you can get an epoxy coat for the bottom which is quite tough , but as my boat was built in 1984 and only lost a mil in places I will just do the sides as the boat yard guy suggested. Link to comment Share on other sites More sharing options...
Tim Lewis Posted September 11, 2013 Report Share Posted September 11, 2013 We simply refill the dry dock and move the boat a couple of feet before emptying the dock again Link to comment Share on other sites More sharing options...
Timleech Posted September 11, 2013 Report Share Posted September 11, 2013 We simply refill the dry dock and move the boat a couple of feet before emptying the dock again ...and then wait (could be up to 24 hours) for it to dry out again enough to paint.. Yes, that's the easy way to do it if you have time to spare. Tim Link to comment Share on other sites More sharing options...
bottle Posted September 11, 2013 Report Share Posted September 11, 2013 Gantry crane boat lifted onto dry land, supported two feet of the ground, sides blacked, hoisted six feet onto suitable supports, moved to do the bits that it sat on jobs a goodun Link to comment Share on other sites More sharing options...
Teadaemon Posted September 11, 2013 Report Share Posted September 11, 2013 I've had the discussion on whether or not to recommend blacking the bottom with a number of surveyors. We all agreed that in an ideal world, blacking the bottom plate is better than not blacking it. We also all agreed that it is not usual practise, because it's difficult to do (it gets even more difficult if you want epoxy on there and need to shotblast the bottom before blacking it). It's one of those things that some surveyors will recommend, because it's a lot easier to put a couple of lines in a report than it is to actually do the job. Personally, I've stopped recommending that it's done routinely, although I will mention that a baseplate hasn't been blacked. If OTOH, I were supervising a new build, or a boat was on dry land for a considerable period of time for major work, with a crane handy for all the moving around, then I'd probably mention doing the whole hull including the baseplate with epoxy as an option. Of course, blacking the uxter plates (and if the bottom plate curves up towards the bows) is a lot easier, and given their position nearer the surface, is worth doing. Link to comment Share on other sites More sharing options...
nb Innisfree Posted September 11, 2013 Report Share Posted September 11, 2013 (edited) Best way is to thin the blacking until its runny so that it runs into all the nooks and crannies. Oh yes, forgot to mention, you also need to turn the boat upside down. Edited September 11, 2013 by nb Innisfree Link to comment Share on other sites More sharing options...
David Mack Posted September 11, 2013 Report Share Posted September 11, 2013 ...and then wait (could be up to 24 hours) for it to dry out again enough to paint... It was extemely hot weather when we last did it so we didn't have to wait that long. And since you are only going to be painting three or four strips across the bottom it is more practical to apply some heat locally to speed the drying if necessary. 1 Link to comment Share on other sites More sharing options...
Speedwheel Posted September 11, 2013 Report Share Posted September 11, 2013 I would, and always do, black the bottom but most people don't. It's not as bad as people make out. Link to comment Share on other sites More sharing options...
ditchcrawler Posted September 11, 2013 Report Share Posted September 11, 2013 Gantry crane boat lifted onto dry land, supported two feet of the ground, sides blacked, hoisted six feet onto suitable supports, moved to do the bits that it sat on jobs a goodun Debdale Link to comment Share on other sites More sharing options...
furnessvale Posted September 11, 2013 Report Share Posted September 11, 2013 I would, and always do, black the bottom but most people don't. It's not as bad as people make out. My surveyor, sadly recently deceased, gave me this useful advice. If the bottom is shiny because it has rubbed on the bottom, don't waste your time blacking it as it will only rub off. However, if the bottom is rusty, clean and black it as you will obviously do some good. George ex nb Alton retired Link to comment Share on other sites More sharing options...
Speedwheel Posted September 11, 2013 Report Share Posted September 11, 2013 My surveyor, sadly recently deceased, gave me this useful advice. Mr Lorenz I presume. Well, he should know better than most. Link to comment Share on other sites More sharing options...
bottle Posted September 11, 2013 Report Share Posted September 11, 2013 Debdale Yes and looking forward to next year, to see their new system. Boat will be on a remote controlled 'trolley' that will take it to a unit at the rear, no weather problems. Link to comment Share on other sites More sharing options...
ditchcrawler Posted September 11, 2013 Report Share Posted September 11, 2013 When I was at Debdale they had a boat out for blacking and I was invited to look under the base plate, what I saw has convinced me that black will not get rubbed off, it was covered with different forms of Crustaceans and they hadn't been rubbed off. Link to comment Share on other sites More sharing options...
PhilR Posted September 11, 2013 Report Share Posted September 11, 2013 When I was at Debdale they had a boat out for blacking and I was invited to look under the base plate, what I saw has convinced me that black will not get rubbed off, it was covered with different forms of Crustaceans and they hadn't been rubbed off. I was told recently that it is best to leave the crustaceans on the bottom plate ............ Link to comment Share on other sites More sharing options...
Taslim Posted September 12, 2013 Report Share Posted September 12, 2013 I was told recently that it is best to leave the crustaceans on the bottom plate ............ Unless they are zebra musels? I seem to remember a forum member having to steam them off before transporting a boat. Link to comment Share on other sites More sharing options...
Timleech Posted September 12, 2013 Report Share Posted September 12, 2013 Unless they are zebra musels? I seem to remember a forum member having to steam them off before transporting a boat. I'm pretty sure that would be true if taking the boat to Ireland, where they are not yet established inland. Boats around here which don't move much can build up layers of zebra mussels inches thick. Removing them should certainly save fuel, for boats which do move. Tim Link to comment Share on other sites More sharing options...
ditchcrawler Posted September 12, 2013 Report Share Posted September 12, 2013 I was told recently that it is best to leave the crustaceans on the bottom plate ............ Do they protect against rust then> Link to comment Share on other sites More sharing options...
